Lenovo ThinkPad T450s - No POST
  • nrcslim89
    • Nov 2019
    • 129
    • Portugal
    Hello everyone, maybe some of you will recognize this issue or thread posted on another platform but i still want to keep trying to solve or get some valid possbile issue.
    Well i have an ThinkPad T450s with motherboard NM A301 REV1.0 (i5 CPU).
    So this laptop power on, but it does't show any signs of image displayed on his internal display and external VGA neither, only a full black screen appears without backlight.
    When i press power on, keyboard backlight bright on and then goes of, i try to use a external USB keyboard and no CAPS and no NUM LOCK.
    I reset BIOS, remove the CMOS and all batteries, remove all power sources and still the same, i reflash the BIOS with lots of available supposed worked BIOS even with Password on RT809F but without success.
    I measure the AMPS consumption on DC PSU and it takes 0.550A steady...
    But no ThinkPad logo and no backlight nothing... always a big black screen...
    I have all Voltages on Coils of board and they resistence seems nice...
    I measure some other points and test the LID Close switch and cicuit is working fine, measure RMSRST and i have 3.3V.
    As well on LVDS connector i have 20V and 3.3V.
    RAM stick is good and tested, Try with another good RAM stick and same thing.
    Could this be an issue of CPU/PCH BGA ?
    Thanks in advance for all your replies.
  • Techtiger
    • Oct 2014
    • 1602
    • france
    Re: Lenovo ThinkPad T450s - No POST
    Check the DRAMRST in the Ram slot & PLTRST
    • nrcslim89
      • Nov 2019
      • 129
      • Portugal
      Ok will do it, but this board have onboard ram and ram slot...
      • Techtiger
        • Oct 2014
        • 1602
        • france
        Follow the Schematic download from badcaps What are voltage on the coil ?
        • nrcslim89
          • Nov 2019
          • 129
          • Portugal
          I have the schametic and boardview already, on RAM rail coil I get 1.35V think it's fine, I have 1.80V for CPU and 1.07V for PCH if I'm not wrong and not saying nothing stupid.
          • Techtiger
            • Oct 2014
            • 1602
            • france
            uplode the Bordview
              • 21869
              https://www.badcaps.net/forum/showthread.php?t=92782
              • Techtiger
                • Oct 2014
                • 1602
                • france
                Thanks SMDFlea check the ram Slot pin1/30/200/202
                • newbee123
                  • Apr 2021
                  • germany
                  Did you find the issue?
                  having very similar problems on t450s with i7
                  • someonenotyou
                    • Feb 2021
                    • 61
                    • LV
                    Hi. I am having the same issue - powers on, keyboard backlight turns on and off, fan spins, then off, but no post. I tried to flash different BIOSes, with clean ME, tried NVRAM from working BIOS, disable onboard RAM. Nothing worked.
                    I made the measurements on RAM slot.
                    Pin 1 (DDR3_VREF_DQ_SB) - 0.68V
                    Pin 30 (-DRAMRST) - 0,13V
                    Pin 200 (SMB_DATA_3B) - 3,33V
                    Pin 202 (SMB_CLK_3B) - 3,33V
                    What else should I check?
                    • mon2
                      • 14662
                      The signal line is active LOW (denoted by the tilde prefix) so if the voltage is ~0v (ie. as you are measuring @ 0v13) - the DRAM is parked in the RESET state.
                      • someonenotyou
                        • Feb 2021
                        • 61
                        • LV
                        I checked the -DRAMRST is connected to RAM and CPU. Then it goes through R9130 resistor (470ohm) to VCC1R35A.
                        What I noticed is that VCC1R35A to ground is only 183ohm. Is it not too low? And the -DRAMRST is +470ohm = 653ohm
                        I desoldered the R9130 resistor and VCC1R35A was still 183ohm and -DRAMRST was 11kOhm.
                        One more strange thing - while the board was still warm from removing the resistor, the VCC1R35A to ground went to 24ohm. As the board cooled of, the resistance was climbing slowly back to 183ohm.
                        So, is the 183ohm resistance to ground on VCC1R35A too low?
                        Where should I look? I removed U70, Q162 and Q163 and there were no difference.
                          Lenovo ThinkPad T450s Notebook T Specification for Upgrade or Repair
                          This specification for the Lenovo ThinkPad T450s Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T450s boardview and T450s schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo ThinkPad...
                          09-06-2024, 05:30 AM
                          Lenovo ThinkPad X1 Carbon + ThinkPad USB 3.0 Pro Dock Notebook X Specification for Upgrade or Repair
                          This specification for the Lenovo ThinkPad X1 Carbon + ThinkPad USB 3.0 Pro Dock Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X1 Carbon + ThinkPad USB 3.0 Pro Dock boardview and X1 Carbon + ThinkPad USB 3.0 Pro Dock schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                          09-06-2024, 11:40 AM
