macbook air 820-3024-B green light no fan spin
  • kingskie
    • Oct 2014
    • 249
    • indonesia
    I have a problem with macbook air 820-3024-B. there was a liquid damage on U7021 around pin
    22 P5VP3V3_VREG3
    23 PPBUS_G3H
    24 P3V3S5_DRVH
    25 P3V3S5_LL
    26 P3V3S5_VBST
    27 P3V3S5_DRVL
    after that i clean and change the U7021 but still no fan spin.
    here is the measurement after i change the U7021
    22 P5VP3V3_VREG3 -- 3.37V
    23 PPBUS_G3H -- 8.4V
    24 P3V3S5_DRVH -- 0V
    25 P3V3S5_LL -- 0V
    26 P3V3S5_VBST -- 0.64V
    27 P3V3S5_DRVL -- 0.64V
    U7021 is hot even i change for the second and third time. i even changed Q7260 but still the same
    can anyone help?
    thanks in advanced
  • Askic
    • Sep 2018
    • 187
    • BIH
    Re: macbook air 820-3024-B green light no fan spin
    Your PPBUS_G3H is a bit low. When SMC is turned on it will boost PPBUS_G3H voltage from 8.1/8.2 to 8.5/8.6V.
    Open schematics and boardview and measure all power rails on page 7/74.
    • kingskie
      • Oct 2014
      • 249
      • indonesia
      here is the measurment
      PPBUS_G3H 8.41v
      PPBUS_S5_HS_COMPUTING_ISNS 0V
      PPDCIN_G3H 17.39V
      PP3V42_G3H 3.41V
      PPVRTC_G3H 3.41V
      PP5V_S5 1.6V
      PP5V_SUS 0V
      PP5V_S3 0V
      PP5V_S0 0V
      PP3V3_S5 0V
      PP3V3_SUS 0V
      PP3V3_S3 0V
      PP3V3_S0 0V
      PP1V8_S0 0V
      PP1V5_S3 0V
      PPVCORE_S0_CPU 0V
      • Askic
        • Sep 2018
        • 187
        • BIH
        PP5V_S5 1.6V
        Most probably, you have a short on S5 5V line. Did you check for short circuit on this line (check both in resistance mode and diode mode on your multimeter)?
        What is the value of SMC_BC_ACOK?
        • kingskie
          • Oct 2014
          • 249
          • indonesia
          Originally posted by askic
          ppbus_s5_hs_computing_isns 0v
          pp5v_s5 1.6v
          most probably, you have a short on s5 5v line. Did you check for short circuit on this line (check both in resistance mode and diode mode on your multimeter)?
          What is the value of smc_bc_acok?
          smc_bc_acok 3.2v
          resistance
          pp5vs5 on c5710 0.393
          • kingskie
            • Oct 2014
            • 249
            • indonesia
            i forgot to tell that the U7201 is hot when i plug the charger. before i thought that U7201 is short but after i changed 3 times it is still hot
            • Askic
              • Sep 2018
              • 187
              • BIH
              On your place, I would remove the U7201 chip, inspect pads and test them against ground. If the chip is good and it's getting hot, there must be some other component connected to it that is shorted
              • kingskie
                • Oct 2014
                • 249
                • indonesia
                Here are the measurements to ground after i removed the chip:
                PIN 1 = OL
                PIN 2 = 0.398
                PIN 3 = OL
                PIN 4 = 0.445
                PIN 5 = 0.467
                PIN 6 = OL
                PIN 7 = 0.706
                PIN 8 = 0.404
                PIN 9 = OL
                PIN 10 = OL
                PIN 11 = 0
                PIN 12 = 0.418
                PIN 13 = OL
                PIN 14 = 0.426
                PIN 15 = OL
                PIN 16 = OL
                PIN 17 = 0.261
                PIN 18 = 0.633
                PIN 19 = OL
                PIN 20 = 0.471
                PIN 21 = 0.453
                PIN 22 = OL
                PIN 23 = 0.429
                PIN 24 = 0.261
                PIN 25 = OL
                PIN 26 = OL
                PIN 27 = OL
                PIN 28 = 0
                PIN 29 = 0.427
                PIN 30 = OL
                PIN 31 = OL
                PIN 32 = 0.410
                PIN 33 = 0
                • Askic
                  • Sep 2018
                  • 187
                  • BIH
                  Everything seems OK. I'm now really puzzled too.
                  • kingskie
                    • Oct 2014
                    • 249
                    • indonesia
                    so am i
                    it is really weird..
                    any other opinion?
                    • Askic
                      • Sep 2018
                      • 187
                      • BIH
                      I'm still convinced that you have a short on a power rail.
                      So, some switch (MOSFET open) closes and drives power rail line to short.
                      I would again pay attention to MOSFETS (60/74). Inspect Q7840 for example. On pin 29 of U7201 you should have 5 V, this voltage is later used to create other voltages on the line such as PP5V_S5, P5VSUSFET....
                      It is possible that something heats up of elements shown on page 60. Try to sense it or use isopropyl alcohol.
                      • mon2
                        • Dec 2019
                        • 14667
                        Thanks for the last post with correction.
                        1) The switching regulator is U7201 (not U7021).
                        2) What is the PP5V_S3_REG rail voltage? This is generated by this same dual switcher IC.
                        3) Turn off the power to the board and check the resistance on L7220, pin 1. What is the reading? Maybe a shorted cap on that rail?
                        4) Perhaps Q7220 & Q7225 should be reviewed / replaced.
                        5) What is the resistance reading (with power off!) on L7260, pin 2 ?
                        • kingskie
                          • Oct 2014
                          • 249
                          • indonesia
                          i already watch over that area but no sign of heat comes up...but tommorow i will try to replace that Q7840...i will let you know...thanks a lot bro
                          • kingskie
                            • Oct 2014
                            • 249
                            • indonesia
                            thanks for the reply mon2
                            tommorow i will measure what you asked.
                            • kingskie
                              • Oct 2014
                              • 249
                              • indonesia
                              1. yes correct. i type wrongly
                              2. PP5V_S3_REG is 0V
                              3. L7220 pi 1 resistance to ground is 0.414
                              4. already replaced but still the same
                              5. L7260 pin 2 resistance to ground is 0.271
                              • mon22
                                • Mar 2021
                                Hi. Mon2 here. Was unable to login for the past 2 days. The login procedure appears to be broken, at least for us. To ask for help, you have to login. Yet we cannot log in. Good logic.
                                Ok, confirm that for (3) & (5) of above, that you are in RESISTANCE mode. Not diode mode.
                                Black probe on Ground.
                                Red probe on the requested inductor pins.
                                Assuming these are indeed resistance (ohms) readings, they are very low in value. This would indicate that you have at least one bad cap on that voltage rail.
                                This could be the root cause of your problems. After your confirmation of the readings, the logical step will be to inject a voltage that is under the voltage of the rail.
                                Do you have a voltage injector? Or a good power supply?
                                We sourced a 30A voltage injector which works fine except for a very dim display. Have used it a few times with very good results.
                                Interested for you to inject say 2-3 volts on the 5 volt rail and check the current drawn by your power supply. The idea is to never exceed the 5 volts if on a 5 volt rail. Respectively for the 3v3 rail, try 2 volts.
                                Be sure that you do not see any liquid damage on the PCB - if yes, clean it up with alcohol / ultrasonic cleaner. Personally we find that alcohol cleaning with a q-tip works very well.
                                Also, we spray the bank of caps we suspect to be bad with alcohol. Then watch for a mist of smoke upon the voltage injection and/or heating of a cap. Method works very well and sometimes you can even smell the bad tantalum as it heats up. Seen the part split in 2 pieces / powder as this process continues.
                                Once done, the current drawn on this rail will be much lower and respectively, the resistance will be much higher to denote that the short is removed.
                                Unless someone has better suggestions, this is the approach to consider.
                                • mon2
                                  • Dec 2019
                                  • 14667
                                  OMG - finally able to log in again.
                                  • kingskie
                                    • Oct 2014
                                    • 249
                                    • indonesia
                                    hi mon2,
                                    thank for reply.
                                    i do have 10A 30V power supply sunshine brand (china brand)
                                    i think i measure wrongly. here is the measurement as you suggest
                                    3. L7220 pi 1 resistance to ground is 39.6k
                                    5. L7260 pin 2 resistance to ground is 17.04k
                                    • mon2
                                      • Dec 2019
                                      • 14667
                                      The resistance values look to be ok and do not indicate a shorted capacitor on these voltage rails.
                                      Check that the external pcb traces for this same dual regulator are reaching the actual component.
                                      • kingskie
                                        • Oct 2014
                                        • 249
                                        • indonesia
                                        every traces are ok..
                                        i just measure that PP1V05_S0 is short to ground.. is it ok?
                                        • xalapamac
                                          Macbook air 820 - 00165 fan spin, PPVCC_S0_CPU present, No green Light, No Chime
                                          by xalapamac
                                          Hello, greetings everyone. I NEED YOUR HELP
                                          I got this macbook that doesn't turn on, I don´t have a green light, but it's got a fan spin for a few minutes and after it's off.
                                          This macbook comes in without damage from liquid spill.
                                          The story of the Mac is that the screen closes and left without use for two days. Then they try to turn on and it won't turn on. Then they connect the charger and it doesn't give light.
                                          It´s a Macbook Air 2017
                                          Please help me understand how this works... Correct me if I'm wrong in my way of...
                                          01-09-2021, 12:31 AM
                                        • kingskie
                                          Macbook Air A1466 820-00165 green light no fan spin
                                          by kingskie
                                          Hi All,
                                          I got macbook air 820-00165 with green light but no fan spin.
                                          Measurements:
                                          PPBUS_G3H = 8.14V
                                          PP3V3_S5 = 0V
                                          PP5V_S5 = 0V
                                          SMC_WAKE_L = 3.12V
                                          SMC_ONOFF_L = 3.4V
                                          SMC_RESET_L = 3.38V
                                          should i change the U7501 first?
                                          01-08-2023, 09:54 PM
                                          Acer Spin Spin 511 R753TN Chromebook Specification for Upgrade or Repair
                                          This specification for the Acer Spin Spin 511 R753TN Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Spin 511 R753TN boardview and Spin 511 R753TN schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                          09-07-2024, 02:20 AM
                                          Acer Spin Spin 3 SP313-51N-58JR Hybrid (2-in-1) 3 Specification for Upgrade or Repair
                                          This specification for the Acer Spin Spin 3 SP313-51N-58JR Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Spin 3 SP313-51N-58JR boardview and Spin 3 SP313-51N-58JR schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-06-2024, 09:30 PM
                                          Acer Spin Spin 3 SP313-51N-58LR Hybrid (2-in-1) 3 Specification for Upgrade or Repair
                                          This specification for the Acer Spin Spin 3 SP313-51N-58LR Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Spin 3 SP313-51N-58LR boardview and Spin 3 SP313-51N-58LR schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
