alienware 15 r3 (La-D751p)
  • Pfudaniel
    • Feb 2021
    • 91
    • Netherlands
    Hello people i got this alienware 15 r3 (La-D751p)
    It has some weird issues wich i think is bios related.
    usb ports on either sides dont work, the only usb that works is the 3.1 on the back ( next to charger ) i use a converter to be able to use the normal usb 3.0
    if i wanne update my bios with f12 and ez flash i can select the file and pres Flash upgrade. But then nothing happens. no progress it just stands stil from 0%
    I most also note that the lights on the side and the mousepad light dont work at all!
    Also if i pres in windows shutdown the computer doesnt shutdown ( keyboard light stays on )
    I hope anyone can tel me where to look for the problem!
    for the rest everything works fine, windows runs can do anything without problems.
    Thanks for taking ur time to read this !
    Daniel
  • Pfudaniel
    • Feb 2021
    • 91
    • Netherlands
    Re: alienware 15 r3 (La-D751p)
    Ive tried flashing the bios with a programmer from this forum, same issues still persist.
    There is no visual damage on the mainbord and subboard. Ive checked different forums and this model seem to have this problem alot. But no where is a solution to be found.
    It is definatly hardware related.
      • 20758
      Check UU1 the power share chip . https://cdn.badcaps-static.com/pdfs/...0330b8f3d8.pdf
      • Pfudaniel
        • Feb 2021
        • 91
        • Netherlands
        Originally posted by SMDFlea
        thank u so much for your respond SMDFlea, im gonne check this first thing in the morning !
        Any tips how to exactly measure it ?
        i shoud measure pin 1 and 12 for voltage?
        Greetings Daniel
          • 20758
          Yes check voltage on 1 and 12,also check voltage on UU3 pins 1,3,4,5
          • Pfudaniel
            • Feb 2021
            • 91
            • Netherlands
            Alright done that, added pictures with measurement
            Thanks for taking ur time for me !
            measurements are done with just the charger plugged in.
              • 20758
              Take same measurements on UU3 with the board powered up. Also post your bios backup in the bios requests forum for fixing
              • Pfudaniel
                • Feb 2021
                • 91
                • Netherlands
                done!
                seems al voltage is there, il post bios fix in bios section now
                • Pfudaniel
                  • Feb 2021
                  • 91
                  • Netherlands
                  There is many bios chips on this board it seems. UE2, UT2, UH4. And 2 more next to the gpu, UG13, UG15 . Im not sure if PU1300 is also one. I believe i shud flash UH4 correct ?
                  foto with al bios chips:
                  i took backup of UH4
                  shud the EC also be updated ? im not sure wich chip is that.
                    • 20758
                    Originally posted by Pfudaniel
                    done!
                    Can you check those voltages again ,i think pin 3 should be 3.3V and pin 1 5V
                    • Scotchmist
                      • Apr 2019
                      • 60
                      • United Kingdom
                      I have this board out waiting for mosfet.
                      Do you want me to dump all the bios IC?
                      • Pfudaniel
                        • Feb 2021
                        • 91
                        • Netherlands
                        Hi thanks al for respond, i've solved the problem by putting a new embedded controller (ec) on the board usb + lightning + shutdown works as it shud. again thanks !
                        • Cuzaov
                          • Jan 2022
                          • 5
                          • Brazil
                          Hi Guys, I saw the forum here and I needed your help. My screen is dull (but it emits a very dark image). The part that controls the LCD Blacklight burned out. Could you send a photo or the name of the component. pls <3
                          • mon2
                            • Dec 2019
                            • 14085
                            How did it burn out ? Do you have a picture of the damaged part ?
                            Any silk screen (white text) markings on the circuit board ?
                            Post any pics of the backlight part that may be damaged.
                            • Cuzaov
                              • Jan 2022
                              • 5
                              • Brazil
                              i don't know how to attach the image but i tried
                              • Cuzaov
                                • Jan 2022
                                • 5
                                • Brazil
                                here
                                • mon2
                                  • Dec 2019
                                  • 14085
                                  See attached. Part is QV1 on the logic board.
                                  This is a mosfet.
                                  Part # SI3457CDV-T1-GE3
                                  https://www.mouser.ca/ProductDetail/...content=Vishay
                                  • Cuzaov
                                    • Jan 2022
                                    • 5
                                    • Brazil
                                    Omg, Thnak you so much. I do not know how to thank you.
                                    • mon2
                                      • Dec 2019
                                      • 14085
                                      We will party in Brazil after Covid dies Miss my 500,000 steps walking up to Corcovado (Rio). We rented a helicopter from Sugar Loaf(?) back in 2000 and flew over the beach. Amazing views.
                                      https://www.aliexpress.com/item/1005...a4b6c40fb0fcd1
                                      • Cuzaov
                                        • Jan 2022
                                        • 5
                                        • Brazil
                                        for sure, we are going to have a great party here in brazil and then there in canada UHUH <3. Thanks men, now i will buy on aliexpress ^-^
                                          Alienware 13 R3 Notebook Specification for Upgrade or Repair
                                          This specification for the Alienware 13 R3 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 13 R3 boardview and 13 R3 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Alienware 13 R3 Notebook...
                                          09-06-2024, 06:42 AM
                                          09-06-2024, 06:34 AM
                                          09-06-2024, 06:27 AM
