Hp Probook 650 G2, network port not working
  • saidbe
    • May 2017
    • 42
    • Chilo
    I have HP probook 650 G2 but the network port does not work. It is not a software problem because the installation is done more times and drivers are reinstalled. It is hardware problem, can anyone help with this?
  • saidbe
    • May 2017
    • 42
    • Chilo
    Re: Hp Probook 650 G2, network port not working
    Any one? ��
    • peste
      • 13072
      • ROMANIA
      Originally posted by saidbe
      Any one? ��
      update bios ..
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        Network detected and installs properly in device manager??
        • saidbe
          • May 2017
          • 42
          • Chilo
          yes
          • mon2
            • 14415
            So this confirms that the logic side is working with the PCI or PCIe interface of the ethernet controller reporting their IDs to the host pc.
            Is the rj45 connector for your cat5/6 cable look ok?
            Perhaps the contact pins are mangled?
            Do you see any different ethernet light patterns when you attach the ethernet cable vs. remove the cable?
            Any burn marks near the ethernet connector region? Perhaps an external surge that took this out.
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              I too will suggest to replace the RJ45 Connector.
              • saidbe
                • May 2017
                • 42
                • Chilo
                THANKS for your suggests
                • piernov
                  • Jan 2016
                  • 4437
                  • France
                  Gotta check if it has a valid MAC address, if it detects a cable plugged in and if it negotiates speed and duplex properly.
                  • nabilgo
                    • May 2016
                    • 303
                    • L.A
                    bios probleme buddy
                    • dqtech
                      hp probook x360 11 G4 all usb port not working
                      by dqtech
                      this laptop can turn on normally but all usb pro 2.0 not detected...i try wired mouse on usb port number 1, got light on the mouse but nothing happen and no error pop up....on usb port number 2 no light at all when attach mouse...
                      11-03-2024, 09:25 AM
                    • DynaxSC
                      Stubborn GIGABYTE B365M AORUS ELITE - main PCIe x16 GPU port working only in x8 width mode
                      by DynaxSC
                      I have this board, where I have exchanged the LGA1151 socket. During testing I discovered, that the large PCIEX16 slot won't by no force work in x16 mode, but keeps to work in x8 mode only.
                      I tested this with GPU-Z, also with Render Test (but tried also Furmark and Heaven Benchmark - no effect).
                      Tested on Core i5-9600K as well as on an Pentium G5420 and MSI NVIDIA GTX1070 and 2 other cards, including RTX3060Ti.
                      Board architecture definitely allows x16 mode, as all 16 PCIe lanes are present between CPU and main GPU slot (nearest to CPU).
                      05-04-2025, 12:08 PM
                    • eliemgh
                      Dell Latitude 7410. The USB Type-C port is not working
                      by eliemgh
                      I have a Dell Latitude 7410 with an Intel i7 10th Gen CPU. The USB Type-C port is not working, and since it's the only charging port on the device, I'm unable to charge the laptop.
                      I inspected the motherboard and found that the IC labeled TPS65988 had a short circuit. I ordered a replacement IC from Alibaba and replaced it. The short issue is now resolved, but the laptop still doesn't charge, and the Type-C port remains non-functional.
                      After doing some research, I found out that the TPS65988 needs to be programmed after replacement in order to function properly.
                      04-14-2025, 04:20 AM
                      HP ProBook ProBook 4520s Notebook PC 4000 Specification for Upgrade or Repair
                      This specification for the HP ProBook ProBook 4520s Notebook PC can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ProBook 4520s Notebook PC boardview and ProBook 4520s Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                      09-06-2024, 05:27 AM
                      HP ProBook ProBook 5320m Notebook 5000 Specification for Upgrade or Repair
                      This specification for the HP ProBook ProBook 5320m Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ProBook 5320m boardview and ProBook 5320m schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
