MSI PE62 not working webcam and usb ports.
  • Francisco.s
    • 686
    • Spain
    Hi, this laptop have all usb ports and webcam not working at all.
    It doesn't detect usb mouse or usb keyboard. (doesn't detect pendrives also)
    The usb 3.1 chip (ASM1142) U12, is not mounted. (seems a change from factory)
    Could be a pch (HM175) related issue?
    Thanks for your help.
  • Francisco.s
    • 686
    • Spain
    Re: MSI PE62 not working webcam and usb ports.
    Seems U12 is mounted in version 1.1 (page 33: PCB 1.1 modify)
    It is a bit weird that in version 1.0 the USB3.1 TYPE C (CON3) is controlled By PCH (U15)
    All readings in usb ports are good, there are no shorts and 5 volts are present.
    I have tested some PCH signals and found that USB2_COMP has some weird pulses.
    OTG_ID_JNC circuit in pch (pin AG2) has no voltage and R185 seems good (1K)
    R446 (USB_OC) has 3 volts in both pins.
    Please help.
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      All usb port+webcam not working-Very likely PCH fault. What is the resistance on D+ & D- on usb ports??
      • Francisco.s
        • 686
        • Spain
        Hi mcplslg123, the resistance in those pins are 2 mega ohms, and diode mode readings are 0.540 in both.
        I think it is a PCH issue, but seems so weird to me, (only usb bad) that I want to discard all other possibilities.
        Thanks.
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          Its not wierd and has faced many times specially on acer's. Replacing the SOC/PCH solves it.
          PS: Your camera is also likely to get faulty and may need replacement as well going by experience with acer's.
          • Francisco.s
            • 686
            • Spain
            Hi, bad news for this motherboard.
            After replace the pch***, all usb ports continue with the same problem.
            It is a real weird thing.
            I have reprogrammed pch-bios and ec- bios one more time, just in case.
            The motherboard is a MS-16J91, and The schematic and boardview is posted in this thread:
            https://www.badcaps.net/forum/showthread.php?t=84710
            I am completely lost with this issue. Please help¡¡¡
            *** pch is a HM170-HF.
            • mon2
              • Dec 2019
              • 14265
              Review the attached diagram.
              Which resistors are stuffed on your logic board?
              • Francisco.s
                • 686
                • Spain
                Hi, all resistors going to U12 are missing. This board not mount ASM1142, this port is controlled by the pch.
                I have tested USB_OC signal just in case pch sees an over-current but it has 3,4 volts and nothing changes if this signal is grounded manually.
                I'm trying to find a resistor strap that disables all usb but can't see any.
                • mon2
                  • Dec 2019
                  • 14265
                  Hmm. As a suggestion, consider to remove temporarily the 0 ohm resistors linked to USB 3.1 port 1 and then test to see if port 2 is functional or not.
                  Then repeat this exercise for USB 3.1 port 2. Only to see if USB components are to blame for this non-working condition or not.
                  Perhaps one of the ESD protection device is causing these issues.
                  • Francisco.s
                    • 686
                    • Spain
                    Hi, can not find this 0 ohm resistor.
                    Can you point me how it is called on the schematic?
                    Thanks.
                    • mon2
                      • Dec 2019
                      • 14265
                      See if the attached helps.
                        • 21037
                        Check voltage USB_ENABLE and CAMERA_ON.
                        • Francisco.s
                          • 686
                          • Spain
                          I misunderstand you, I thought you were referring to a a 0 ohm resistor in the USB5V_PTx pin of ESD protection devices.
                          I have removed esd protection devices in order to not interfering the circuit.
                          USB_ENABLE is present in all usb SWITCHS.
                          CAMERA_ON is also present, and it can be switch on and off with Fn+ F6.
                          Do you know if there is a voltage regulator for pch I/O circuit, specifically involved in usb?
                            • 21037
                            What is the full laptop model number is it the PE62 7RD .Can you check R186. Edit: is the card reader,wlan and keyboard backlight working ok
                            • Sametbey
                              • Jan 2021
                              • 229
                              • Turkey
                              Is there any short circuit in any of the usb ports. maybe camera. Perhaps the IO chip itself or its software has flown.
                              I'm not happy to be so strong. because it's not humanly
                              • Francisco.s
                                • 686
                                • Spain
                                The model is Gl62W TRD and R186 is 113 ohms, but I can't tell you if there is a goo connection with pin AG3 of pch. (something to check for tomorrow)
                                The keyboard and wlan are both working. The card reader is mounted on the same pcb as power button, and it is disconnected in order to not interfering. (there is a power pad near the kbc to power it on)
                                There are no short circuit in any of its usb, also i have tested without the screen connector to avoid the camera being causing any problem.
                                IO chip can be programmed by svod programmer or by an app in windows, it have the last update.
                                  • 21037
                                  did you mean the GL62M 7RD
                                  • Francisco.s
                                    • 686
                                    • Spain
                                    Yes, you are right, it is a GL62M 7RD.
                                    • Francisco.s
                                      • 686
                                      • Spain
                                      I have removed R186 and the reading in diodo mode is .475, so no problem with this connection.
                                      I have checked USBSMI# signal has no voltage at all, as consequence of R175 not being mounted in this motherboard.
                                      The ohms readings in all of usb lines are about 2.1 Mega-ohms, but data sheet says that pch integrates 15 kΩ pull-downs resistors.
                                      • mon2
                                        • Dec 2019
                                        • 14265
                                        If I recall correctly, the internal 15k resistor is not a resistor but a circuit that is enabled on demand. For this reason, you will not read 15k on that line. Also, believe that the USB spec notes that it is a 15k value to +Vbus.
                                        • DynaxSC
                                          GIGABYTE X299 AORUS ULTRA GAMING - SATA PORTS 4-7 NOT WORKING ???
                                          by DynaxSC
                                          I have the above mentioned bord after repair, which was related to a lot of missing smd devices on the back of the board.
                                          There were almost 20 devices missing, caps, resistors and some diodes/mosfets.
                                          The board is generally working now, all PCIe ports are working, Windows installs normally.
                                          However I have a problem with SATA ports 4-7 (the board has 8 SATA ports) - disks are not beeing recognized by the BIOS neither by Windows (which is usually normal in case BIOS does not recognize them).
                                          The SATA 4-7 driver network is quite simple chipset<->buffers/drivers<->SATA...
                                          03-10-2025, 12:27 PM
                                          MSI Prestige PE62 7RD-1232TR Notebook PE Specification for Upgrade or Repair
                                          This specification for the MSI Prestige PE62 7RD-1232TR Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the PE62 7RD-1232TR boardview and PE62 7RD-1232TR schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                          09-06-2024, 07:21 AM
                                          MSI Prestige PE62 8RD-023FR Notebook P Specification for Upgrade or Repair
                                          This specification for the MSI Prestige PE62 8RD-023FR Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the PE62 8RD-023FR boardview and PE62 8RD-023FR schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-06-2024, 09:17 AM
                                          MSI Prestige PE62 8RC-021UK + Gaming Voucher Notebook PE Specification for Upgrade or Repair
                                          This specification for the MSI Prestige PE62 8RC-021UK + Gaming Voucher Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the PE62 8RC-021UK + Gaming Voucher boardview and PE62 8RC-021UK + Gaming Voucher schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                                          09-06-2024, 08:41 AM
                                          MSI Prestige PE62 8RC-230ES Notebook PE Specification for Upgrade or Repair
                                          This specification for the MSI Prestige PE62 8RC-230ES Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the PE62 8RC-230ES boardview and PE62 8RC-230ES schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-06-2024, 07:07 AM
