Asus N53SV CPU Power Problem
  • ProSis
    • Jun 2017
    • 87
    • Turkey
    What voltages do I need to have processor voltages to come into play? Without which voltages the processor voltages are not active?
    The device has all of the main voltages, it starts, it stays at 0.40 and the processor does not activate. The device was broken as a result of a fall, I changed the Hm65, but the problem continues. What I want to know is what voltage and signals the processor voltages need to come into play.
    Motherboard Asus N53SV - HM65
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Asus N53SV CPU Power Problem
    3/5V ALW,1.8V,1.5V ram supply,VCCSA-Just some basic rails which are must. It depends on platform and varies from model to model. I've not seen boardview/schematic for this model but these r just basic rules. Could be bad bios as well.
    • Sametbey
      • Jan 2021
      • 229
      • Turkey
      this file can help.
      I'm not happy to be so strong. because it's not humanly
      • lazaro.089
        Asus Zephyrus M16 / GU603ZW problem
        by lazaro.089
        Full name/ Model: Asus Zephyrus M16 / GU603ZW-M16.I93070T
        CPU: Core i9-12900H
        Onboard 8GB DDR5 4xMT60B1G16HC-48B:A
        Problem: This laptop was brought to the shop with the board already meddled with. Last technician (maybe without the right tools) removed an electrolytic capacitor (PCE9203) sensing resistor (PRS9801) and probably flashed both BIOS (U2802) and VBIOS(U7802).
        The laptop's behavior is: When connected, it tries to power up. CPU powers on, and (allegedly) the power sequence finishes and goes to S0 (PLT_RST = 3.3V). It consumes 600mA, ramps up to 1.100 A and...
        08-26-2025, 06:33 PM
      • AtelierRepa
        ASUS X712JA problem
        by AtelierRepa
        I have a problem with the bios, let me explain.
        With BIOS 1, the pc takes +- 30 seconds to display the ASUS logo (black screen) and to boot.
        I did a clear ME, my black screen problem for 30 seconds at boot is solved, it gives me directly the display and boots quickly.
        My problem is that now, once the charger is plugged in and I put a slight load on the processor, it bogs down to 0.39GHz...
        The only solution is to unplug the charger to get the cpu back up to speed. But as soon as I plug in the charger, it goes straight back down....
        06-15-2024, 04:33 AM
      • greg1985
        Asus dabkxmb18b0 rev.b bios problem
        by greg1985
        Hi. I bought a damaged Asus motherboard, model dabkxmb18b0 rev.b. The problem with the motherboard was a faulty processor.
        I replaced the processor, but it arrived without a BIOS chip. I found one post on the forum, but my problem is
        I don't know which chip to program, and I don't have a schematic. Does anyone know which BIOS chip models are compatible with this motherboard? If so, please let me know. Thanks.
        10-20-2025, 11:34 AM
      • boticario
        problem with asus tuf A17 FA707NUR
        by boticario
        I’m trying to recover an ASUS TUF Gaming A17 FA707NUR (Ryzen + RTX 4050, 2023 model).
        The laptop powers on, fans spin, but the dGPU (NVIDIA) is not properly initialized — sometimes it shows up in Device Manager with Code 43, sometimes black screen.
        After several BIOS downgrades/upgrades (versions 300, 301, 303) and EC resets, it thinking looks like the EC firmware (IT5570VG-256) might have a persistent fault or flag stored in flash.
        I already extracted the BIOS .CAP files and DXE sections with UEFITool and IFRExtractor, but I couldn’t find...
        10-18-2025, 04:37 PM
      • boticario
        by boticario
        10-14-2025, 08:38 PM
