Asus P2520LJ : random characters received, mostly nbz
  • Caimano
    • Nov 2020
    • 54
    • Italia
    Model Asus P2520L
    MB P552LA_LJ Rev 2.1 with soldered I3 5010U processor
    Boardview and repair guide found in the forum.
    Received this laptop which could not power on.
    Found +3VA_EC almost shorted (7ohm).
    Tried removing U3001 EC controller IT8585E FXA: still shorted
    tried removing PU9100 dual power switch which activates +3VA_EC :still shorted.
    Found U3101 TPM Chip pin 1 shorted to ground : removed chip and shorted is gone. Replaced TPM chip with another taken from a similar board.
    Replaced U3001 EC controller with a new IT8585E FXS
    Replaced PU9100 with a new one.
    Now +3VA_EC is present and power on sequence starts until VCCIN enable and reboots. Found that PU8000 VCCIN regulator has pin 6 CORE_PWRGD internally shorted to ground. Waiting for a replacement chip I cut the trace of CORE_PWRGD going to EC controller.
    Now laptop starts to POST and BIOS is displayed. Installed Windows 10 and updated BIOS (main and EC) to last available version (207) using EZFLASH utility.
    During installation found that occasionally some characters are displayed and windows are open and updated without pressing any key.
    In Windows text editor most of the times the string "nbz" is displayed randomly. The problem is randomly present even in the BIOS where hour, minute and date changes by itself even disconnecting keyboard ribbon cable.
    Checked the 24 connections from EC controller to keyboard connection both statically with ohmmeter for short or open circuit and dinamically with oscilloscope and everything looks ok. Tried a different keyboard : same problem. Touch pad works well. Sometimes keyboard works fine for minutes and then goes wild.
    Replaced EC controller again with a new one : same problem. Reflashed BIOS with original one : same problem.
    This stupid problem is driving me crazy and while logic would say that it's either a keyboard or EC controller fault, there must be something else.
    I have 2 doubts :
    1) EC controller version as original one is IT8585E FXA while new ones are IT8585E FXS : are they different in managing keyboard (I found out that this motherboard does not have filtering capacitor , nor pullup resistor on keyboard lines. Only has schottky diodes for ESD)
    2) there are interferences or problems on the connection buses between EC controller and processor (SPI or most probably LPC Bus where also the TPM chip is connected)
    Does anybody knows how EC controller sends keyboard data to Controller?
    Any idea where the problem might be or what to check?
  • Caimano
    • Nov 2020
    • 54
    • Italia
    Re: Asus P2520LJ : random characters received, mostly nbz
    Attached Repair guide and boardview zip
      • 21672
      It seems like there`s some corrosion or liquid in and around the CMOS battery area and J3101 .Check all the pins outside and inside the connector, and R2251,D2201,D3101,D3102
      • Caimano
        • Nov 2020
        • 54
        • Italia
        Thanks, SMDFlea for your help and suggestions !!
        When I tried today the laptop was working fine. I hate random problems. Anyway I checked the area and the components you indicated and could find no problem apart some flux residue found after removing the CMOS battery holder. Anyway I cleaned everything with iPA and tested the laptop under Windows for half an hour and everything worked fine. Will let you know how it goes in the next days.
        Just one question: did you have a similar problems or you suggested the checks to perform based on troubleshooting logic? >Do you have by chance the keyboard matrix schematic? Thanks again
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          @Caimano, You may be lucky its working but always change the kbc with exact suffix as in some boards it does works but on many occasions it doesnt work. The difference between suffix is as follows who dont know it:
          01 FXA- The last letter "A" stands for Always
          02.FXS-The last letter "S" stands for Suspend.
          • EvazX
            ASUS ROG G513QY – RX 6800M powered but not detected intermittently + random crashes (Motherboard: 6050A3254002-MB-Axx)
            by EvazX
            I am working on an ASUS ROG G513QY laptop with RX 6800M dGPU.
            Originally, this laptop was completely non-functional. I replaced the motherboard (part number 6050A3254002-MB-Axx), and with the replacement board it started working fine.
            For a long time, the dGPU worked perfectly stable. I played several hundred hours on very demanding games such as Cyberpunk 2077 without any crashes, instability, or detection issues. Performance was excellent and there were no warning signs of failure.
            However, after some time, the replacement motherboard...
            08-25-2025, 06:09 PM
          • Prosatanosz
            Asus B85M-GAMER no hdmi output and random restarts
            by Prosatanosz
            Hi!
            Asus B85M-GAMER absolute no hdmi output (not at start, not at Windows), and random restarts. Everything work, except hdmi and random restarts after 0.1-3 min. Restarts even in bios. On VGA Windows boots up fast, games and apps starts ok. Mem, psu, cpu changed, no luck. I need shematic, because i think the restarts caused by the hdmi failure.
            10-19-2024, 05:27 AM
          • Dreigas
            Asus TUF Gaming FX506LX laptop just stuck at random time
            by Dreigas
            I've got a problem with my Asus TUF Gaming FX506LX laptop. I bought it as a non-working unit it had been completely drenched in a sweet alcoholic drink and was left for a year... When I got it, the motherboard wasn't in terrible shape, but I had to clean a lot of areas—about 1/5 of the motherboard. There was some corrosion, but I managed to clean it up and re-soldered where I saw issues under a microscope.
            One of the two primary MOSFETs was fried (PQ33 fried and PQ34 were fine), so while I was waiting for a replacement, I desoldered it and created a short....
            07-27-2024, 05:58 AM
          • theone111
            by theone111
            3. Problem: TV shuts down
            07-22-2024, 10:36 AM
          • alambrose
            LG GRAM random bsod SOLVED
            by alambrose
            LG Gram 15Z980 picked up on Ebay for $200 (was sold as parts because no M2 drive and bios pw locked), but otherwise intact and working.
            Threw a 500gb M2 in, and was able to install Windows. On Gram, Win activation is stored in the bios, so Windows was automatically activated. I still kept getting random bsod's. Also bought a pw and unlocked the bios.
            Upgraded Windows to 11, still didn't solve the random & frequent bsod's. Cleaned & reseated all cables, RAM, etc... still getting frequent bsod's. Bought & installed a new stick of RAM, still getting frequent...
            02-12-2023, 06:12 PM
