OMEN by HP 15-dc1093tx G3DD (DAG3DDMB8C0) 08574 Power Issues
  • sikocan
    • Oct 2019
    • 343
    Laptop: OMEN by HP 15-dc1093tx G3DD (DAG3DDMB8C0) 08574
    Problem: Charger is not being detected hence it won't supply power to the system ( my diagnosis so far )
    Charger light not turning on on the DC Jack when plugged in.
    MOSFET 1, turns on and off continuously as seen in thermal camera, I have replaced MOSFETs and all the same issue, I have checked all 3 mosfets outside in diode mode and they open and close fine. I have put all mosfets back. The TI738 looks good. I can't located current sensing resistors as I dont have schematics.
    The gate of mosfet 3 connected to Pin 4 of TI 738 which is ACDRV
    bq738 datasheet https://cdn.badcaps-static.com/pdfs/...ab833061ef.pdf
    I have tried different DC jack as well same issue
    Pin 1 and 2 of TI 738 are ACN / ACP and both are 0.35 ohm which I think are fine.
    Battery is not showing any voltage when inserted into laptop - I assume BMS protection has kicked in.
    when I injected 1v into source of MOSFET 1, it's taking in 0.96a at 1V for an N Channel this is fine. when I insert 19v into DC jack 19V pin - the mosfet as you can see switching ON and Off same can be seen on the power supply. see video below
    None of the pins of the DC in jack are grounded except the ground.
    i think problem is elsewhere and not around these mosfets.. i'll dig deeper I suspect something to do with battery area
    All the coils also look good, nothing 0hms
    I'm so tempted to run a wire but I don't want to for Mosfet 1.
    wire is not the solution - any ideas anyone?
    Power Supply Activity Video
    https://youtu.be/RoyAInHnsWM
    Thermal Cam Readings
    https://youtu.be/elV3R0ht2Ms
  • sikocan
    • Oct 2019
    • 343
    Re: OMEN by HP 15-dc1093tx G3DD (DAG3DDMB8C0) 08574 Power Issues
    TU117-750-A1 GTX1650 TI N18P-G0-MP-A1 GPU Coil is showing 0.60 Ohms - I suspect this is the issue. When 1V applied, it takes about 0.8-0.9amps and goes straight to GPU at about 50 degrees
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      Your dc supply readings indicate a possible short in +19V line. Measure the voltage on drain as well as resistance on any high side mosfet to confirm. BQ738 readings for pin4/5 and pin6??
      • sikocan
        • Oct 2019
        • 343
        So you don't think the GPU is shorted even though the coil is showing 0.6 ohms?
        • sikocan
          • Oct 2019
          • 343
          I've assembled the laptop fully back. I'll disassemble again for the sake of troubleshooting again.
          • ktmmotocross
            Boardkiller
            • Feb 2014
            • 3558
            • slovakia
            check all mosfets for short and if u dont have one, inject 1V 10A after SHUNT RESISTOR and check with thermocam for burning component. NEVER inject 19V, because if u have shorted highside mosfet, u BURN GPU,CPU or other expencive IC
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              Yes, GPU is not likely shorted. Low resistance is the norm there.
              • sikocan
                • Oct 2019
                • 343
                Hi all, thanks for the help so far. yes it's the 19V rail is shorted. Attached are more images for your reference in the above post.
                In terms of the BQ738 readings are below:
                Resistance to ground on Pins:
                1 0.4
                2 0.4
                3 3.43k
                4 4.53k
                5 29k
                6 36k
                Voltage:
                1 Constant 0
                2 Constant 0
                3 Constant 0
                4 0.12 Up and Down to 0
                5 0.3 Up and Down to 0
                6 2V
                • sikocan
                  • Oct 2019
                  • 343
                  Thank you for your help ktmmotocross and mcplslg123.
                  I did found a bad cap around Audio IC which I never expected, at 1V 1.5amp I was able to detect around 48 degrees and focused on it to find a dead short cap.
                  • facarr
                    • May 2019
                    • 7
                    • México
                    I had the same Iusse, but when I changed the cap, and Press the power button, The EC burn.
                    • CossaK
                      • Mar 2022
                      • Polska
                      what was the problem? can I get a picture of what needs to be replaced?
                      • android927
                        • Sep 2022
                        I literally had the same issue with the same board, and just like you it ended up being a shorted capacitor near the audio IC. I wonder if there is some sort of design flaw in the audio circuitry.
                          HP OMEN OMEN by Desktop PC - 870-240na OMEN 870 i5-7400 Specification for Upgrade or Repair
                          This specification for the HP OMEN OMEN by Desktop PC - 870-240na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OMEN OMEN by Desktop PC - 870-240na boardview and OMEN OMEN by Desktop PC - 870-240na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                          09-12-2024, 03:44 PM
                          HP OMEN OMEN by Desktop PC - 870-020na (ENERGY STAR) OMEN 870 i5-6400 Specification for Upgrade or Repair
                          This specification for the HP OMEN OMEN by Desktop PC - 870-020na (ENERGY STAR) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OMEN OMEN by Desktop PC - 870-020na (ENERGY STAR) boardview and OMEN OMEN by Desktop PC - 870-020na (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
                          HP OMEN X OMEN X by Desktop PC - 900-077na OMEN X i7-6700K Specification for Upgrade or Repair
                          This specification for the HP OMEN X OMEN X by Desktop PC - 900-077na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OMEN X OMEN X by Desktop PC - 900-077na boardview and OMEN X OMEN X by Desktop PC - 900-077na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
                          HP OMEN OMEN by Desktop PC - 870-050na (ENERGY STAR) OMEN 870 i5-6400 Specification for Upgrade or Repair
                          This specification for the HP OMEN OMEN by Desktop PC - 870-050na (ENERGY STAR) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OMEN OMEN by Desktop PC - 870-050na (ENERGY STAR) boardview and OMEN OMEN by Desktop PC - 870-050na (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
                          HP OMEN OMEN by Desktop PC - 870-117na OMEN 870 i7-6700 Specification for Upgrade or Repair
                          This specification for the HP OMEN OMEN by Desktop PC - 870-117na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OMEN OMEN by Desktop PC - 870-117na boardview and OMEN OMEN by Desktop PC - 870-117na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
