Sony MBX-267 no 0.9/1.0/CPU/MEM voltages
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3627
    • slovakia
    Hello have this Sony MBX-267 board that have only GPU and 3.3/5V active rails. NO 0.9/1.0/CPU/MEM voltage on rails. when i inject enable signal all voltages works. Try to reflash BIOS+EC but no joy
    dont have schema or BW so im just guessing its KBC
  • piernov
    • Jan 2016
    • 4439
    • France
    Re: Sony MBX-267 no 0.9/1.0/CPU/MEM voltages
    Z50CR schematics could help.
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3627
      • slovakia
      will, but i see it only on vinafix
      • lilo2400
        Sony PS5 EDM-020 MIssing voltages near HDMI encoder
        by lilo2400
        Hey guys..I have an EDM-020 and I'm missing these standby voltages marked with blue...I have already replaced the HDMI encoder IC but is still the same I have all the rest of 3v and 5v ...where does this voltage comes from does, anybody knows.
        Thanks in advance
        09-02-2025, 03:58 AM
      • Capacitorial
        Powersupply has all the voltages - Monitor still no power
        by Capacitorial
        Hello guys,
        I have a Philips 240B7QPJEB. The monitor seems completely dead.
        I opened it and measured the voltages of the powersupply. I found that a mosfet was dead and replaced it.
        On the connector, that goes to the TCON board, all voltages 15-19V and 5V are present.
        The small connector on the left of the PSU has two cables with 18V and all the other have 0.2V. It connects on this small connector on the left ontop of the panel. I guess the backlight? Seens fine I guess.
        The weird thing is, that the Power LED is powered over the TCON board.
        On The TCON...
        12-28-2024, 02:12 PM
      • Carlos#2003%
        Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
        by Carlos#2003%
        Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
        02-15-2024, 07:52 PM
      • dkneyle
        Sony KDL-46HX850 Can't upgrade/update firmware
        by dkneyle
        Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
        Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
        09-25-2024, 10:44 PM
        Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
        This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
        09-06-2024, 05:27 AM
