Lenovo Yoga500-14IHW battery not charging
  • Ricgan
    • Dec 2020
    • Malaysia
    Hello there, I have a Lenovo Yoga 500-14IHW laptop which seems to have issues on battery charging. Thought it was battery problem, order and replaced battery but problem remain.
    I'm facing issue on board that battery was detected normally, remaining battery level can be displayed normally. When power adapter is plugged in, it says charging, after a few second, the screen goes bright and dim and non stop repeating (plugged in power connected and disconnected)until the charger is unplugged, battery charging indicator flashes every 1-2 second, battery does not charge at all.
    It works totally fine on plug in power if battery was removed and with battery power, the only problem is that it does not charge the battery.
    I found schematic online for Lenovo Yoga 500-14IBD , nearest model I found. I have checked on some of the chip, this model should share the same board as mine. But I still have no clue on where's wrong with my laptop, can anyone help?
    here's the schematic:
    https://drive.google.com/file/d/1HfQ...LG25GVOoZ8ZBEo
  • Sephir0th
    • Oct 2020
    • 1289
    Re: Lenovo Yoga500-14IHW battery not charging
    Check AD_ID on for voltage on FTP4318 with adapter plugged in.
    FairRepair on YouTube
    • Bowline
      by Bowline
      06-11-2025, 10:13 AM
    • Shinju
      Razor Blade Steath 13" RZ09-01963 plugged in Not Charging (new battery)
      by Shinju
      Hey All!
      Long time forum member here with a problematic laptop issue!
      I got a RZ09-0196 with a bloated battery (still worked and charged fine) I pulled the old cell pack out and installed a new cell pack in its place.
      The laptop would not power on with the new battery installed without the power supply being plugged in.
      When booting into Win10 (all up to date BTW) I saw the battery icon with 49% plugged in not charging.
      TL;Dr version, old battery worked, charged but was bloated, installed a new non OEM replacement, laptop/windows...
      10-20-2021, 04:58 PM
    • coasterghost
      Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
      by coasterghost
      For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
      Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
      Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
      System Hardware:
      Processor: AMD Ryzen 7 PRO 5850U
      Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
      09-08-2025, 10:46 PM
    • Julian Bailey
      HP ProBook 445 G8 Battery not charging
      by Julian Bailey
      Hi all
      We have in a HP ProBook 445 G8 laptop with AMD Ryzen 7 CPU. When power is connected the power LED light blinks 5 times then stops. Normally HP laptops will blink this LED 10 times as it does a self test when the AC adaptor is inserted. So there must be some sort of short somewhere.
      The battery doesn't charge, and is erratic on the MM voltage. Bench PSU LED pulsates when the battery is connected also. So the fault must be on the charging circuit?
      I have gone around the board with a MM and cant find anything
      Windows shows the battery fine,...
      10-11-2024, 10:34 AM
    • serious_electron
      Strange! Acer laptop not powering on but charging the battery (orange light on when charger and battery plugged in).
      by serious_electron
      Hello Everyone!
      I have an Acer Aspire A315-42 laptop. I generally leave it on for long time by closing down its lid (so it enters the sleep mode). Recently, it rained quite heavily in out area. And the humidity and moisture seem to be high. So one late evening, after I opened the lid and turned on the laptop, it did power on as the blue light turned on but after it booted to the desktop screen, just 5-10 seconds after both the screen and blue light went out and laptop shut down (the blue power light turned orange). And after 2-4 seconds that orange light went off and the laptop died.
      06-28-2025, 02:57 PM
