Dell Inspiron 3537 - Powers Off
  • DanFen
    • Apr 2017
    • 201
    • Malta
    I've got this Dell Inspiron 3537, LA-9982P, can it powers on during POST (I'm guessing). Occasionally I get the typical Dell message complaining about not using the correct adapter with the right wattage, but that could be because I've removed the battery.
    First thing I've found was that the original adapter was fluctuating between 12V and 0V, so going from 12V down to 0V, slowly. Then instantly goes back to 12V, and down back to 0V slowly. Tried two different adapters, just to be sure.
    Removed all components I could, left one memory module (one doesn't seem to be working anyway), even removed the screen. Issue persists, shows POST screen, then turns off. So total power on time is like 5 seconds. Won't turn on again unless power button is pressed.
    Would appreciated any help, from where to start looking etc... I'm attaching the schematics Thank you
    MOD Edit: Link to schematic - https://www.badcaps.net/forum/showthread.php?t=122412
  • DanFen
    • Apr 2017
    • 201
    • Malta
    Re: Dell Inspiron 3537 - Powers Off
    Just bumping my own thread, checking if anyone can help me into the right direction. Thanks.
    • Sametbey
      • Jan 2021
      • 229
      • Turkey
      how many volts do you measure in the pr702 resistance. You should see 19v. you can start from here.
      I'm not happy to be so strong. because it's not humanly
      • DanFen
        • Apr 2017
        • 201
        • Malta
        Hey, thanks for the feedback!
        Yes, PR702 seems fine, 19V is present in the area.
        Just to clarify, it powers on fine (by fine I mean that display works, Dell logo is up, boot menu is up, and if it stays long enough you can see the typical Dell complaining about bad battery). It however turns off after a few seconds.
        • Sametbey
          • Jan 2021
          • 229
          • Turkey
          PQ701 dualmosfet in full control. do not short circuit. Check the stadby circuit on page 38. VREG5 and VREG3,3.
          • DanFen
            • Apr 2017
            • 201
            • Malta
            VREG3 and VREG5 seems fine, 3.3V and 5V respectively.
            Am I right to say that this is the voltage step down chip that distributes the lower voltages to the rest of the circuits?
            • RememberTheViolin
              • May 2020
              • 13
              • Greece
              Since you observe this chip.
              Observe if you have VIN, EN1, EN2, SW1, SW2, pins 12,20,6,18,8.
              Voltages. What do you measure?
              • DanFen
                • Apr 2017
                • 201
                • Malta
                VIN > 13.5V
                EN1 > 2.5V
                EN2 > 0V
                SW1 > 5V
                SW2 > 3.3V
                Question for you, how do you know what's the expected voltage? Is this by experience or by analysing the chip's datasheet?
                Voltages.
                • RememberTheViolin
                  • May 2020
                  • 13
                  • Greece
                  I check the datasheet.
                  • DanFen
                    • Apr 2017
                    • 201
                    • Malta
                    Looks complex. Am I right to think that EN2 should output 3V?
                    • RememberTheViolin
                      • May 2020
                      • 13
                      • Greece
                      Yes, this is my thought as well.
                      It should not be zero. Why not measure it again to verify? Still zero?
                      If you see my posts i was working on the same chip the last days.
                      Not output 3v but receive 3V. You see EN1, EN2 stands for ENABLE which is a voltage that tells the chip to output voltage 1, output voltage 2.
                      The outputs are 3.3V and 5V.
                      • DanFen
                        • Apr 2017
                        • 201
                        • Malta
                        You're right
                        EN1 should be 5V right? I can only assume so because the trail says "5V_EN"
                        VIN > 13.5V
                        EN1 > 2.7V
                        EN2 > 3.3V
                        SW1 > 5V
                        SW2 > 3.3V
                        Not output 3v but receive 3v EN is ENABLE which is a voltage that tells the chip to output.
                        The outputs are other pins.
                        • RememberTheViolin
                          • May 2020
                          • 13
                          • Greece
                          Good this chip is then fine.
                          Just out of curiosity what voltage on pin 7 (PGOOD for power is good haha)?
                          • DanFen
                            • Apr 2017
                            • 201
                            • Malta
                            So if I understood correctly, the sequence is more or less:
                            1. Ensure 19V (or whatever the voltage in is) is being inputted
                            2. I am not sure why we checked PR702, but I am assuming that the 19V goes through this resistor, powering the charging chip?
                            3. Check that 3V, 5V are being outputted from the Step down controller.
                            • DanFen
                              • Apr 2017
                              • 201
                              • Malta
                              Now it's nothing, cause it literally exploded on me.
                              But I noticed that the EN2 was 0V again, PGOOD was measuring 0.1V at the time. Then I checked VIN, got 13.5V and it exploded
                              I have some other laptop boards I can look for the same chip, however I'm not confident that I'll find the same exact chip!
                                DELL Inspiron 3671 Inspiron 3000 i3-9100 Specification for Upgrade or Repair
                                This specification for the DELL Inspiron 3671 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 3671 boardview and Inspiron 3671 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                09-12-2024, 03:36 PM
                                DELL Inspiron 5680 Inspiron 5000 i5-8400 Specification for Upgrade or Repair
                                This specification for the DELL Inspiron 5680 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 5680 boardview and Inspiron 5680 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                09-12-2024, 03:30 PM
                                DELL Inspiron 3668 Inspiron 3000 i5-7400 Specification for Upgrade or Repair
                                This specification for the DELL Inspiron 3668 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 3668 boardview and Inspiron 3668 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                09-12-2024, 03:28 PM
                                DELL Inspiron 5680 Inspiron 5000 i3-8100 Specification for Upgrade or Repair
