Lenovo Z570 directfet culprit
  • lezsimply
    The Wanderer
    • 657
    • Philippines
    Hello everyone. Just want to ask if its possible to replace a directfet with an ordinary one? Can't seem to find locally on my area. This is for Lenovo Z570 with board code LZ57. Laptop is shorted on dcbatout which led me to this directFet PU4313 on vcc_core. When removed, short is gone. I will attach schematic and image.Thanks everyone.
  • Sephir0th
    • Oct 2020
    • 1289
    Re: Lenovo Z570 directfet culprit
    Maybe It's possible, but it is Always the Better way to replace Mosfets in switching Power supplies with equal ones and additionally replace Always both (High- and LowSide) of them at the Same time.
    This is a High-Side mosfet of VCORE and It's never good, If this one fails. Are your Sure you have No more short on Source-, Drain- or Gate-Pins onboard?
    Greetings
    FairRepair on YouTube
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      This is a common issue in LZ57 mb. You need to replace both HIGH & LOW side fet plus the pwm for core. I dont know about any alternatives but they are available online. Some russian sites advocate replacing the 4 mosfets at one go for all the phases along with pwm.
      • lezsimply
        The Wanderer
        • 657
        • Philippines
        Thanks for the reply. In source to drain I get 0.079 vice versa in diode mode. On gate pin I get 0.995. I found short on PL4301 0.004 same diode mode.
        • Sephir0th
          • Oct 2020
          • 1289
          Readings from PL4301 to ground in Ohms Please
          I Hope, i'm Not right with my guess...
          • lezsimply
            The Wanderer
            • 657
            • Philippines
            Good day. I got a reading of 6.4 ohms with respect to ground
            • Sephir0th
              • Oct 2020
              • 1289
              This should be acceptable for +VCC_CORE and means, this is NOT a short. So do as advised from mcplslg123.
              • lezsimply
                The Wanderer
                • 657
                • Philippines
                I also found out that PTC4303, PTC4306 and PTC4307 is shorted to ground. These 3 tantalums measures 7.2, 7.4 and 8.8 ohms outside board. now PL4301 measures 22.60k ohms.
                I'm a little worried because I still have 111.8ohms on pu4313 drain side which could still indicate a short on dcbatout. Thanks again.
                • mcplslg123
                  • Jun 2015
                  • 7262
                  • india
                  Have you removed the core pwm?? Its also likely to be bad.
                  • lezsimply
                    The Wanderer
                    • 657
                    • Philippines
                    I apologize for not updating as I have been busy.
                    @mcplslg123 yes I removed all 3 pwms still short is still there.
                    Heres what I did for the past few weeks:
                    I removed all 3 pwms and all 3 irf6721, and short still there. Injected voltage on PR4004 right side based on schematic. I found out pu4003 is getting hot. replaced it with new one now short is gone.
                    Now I manage to salvage 3 used irf6721 which is good and replace all 3 just to make sure. Injected voltage again on PR4004 until 12v, and nothing is getting hot.
                    Now I returned resistor on PR4004 and inserted charger and boom. DCBATOUT is shorted again. but this time all ic that I replaced were not damaged.
                    I'm having trouble finding the short because I traced all DCBATOUT rail and none seems to be at fault. I don't know where to check anymore. I may have missed something. Any inputs? Much appriciated. Thanks.
                    • lezsimply
                      The Wanderer
                      • 657
                      • Philippines
                      Further test revealed, PU4103 (dc5v,3.3v) of page 41 is getting warm on 19.25v and 0.004 amps. I already removed PU4101, PU4104 and all capacitor on pin no.16 VIN and its still getting warmer. I wonder where this ic draw its power to make it warm. The last thing I wanna do is remove this ic but I have no replacement for this as of now.
                      PS. It is warm because I can still touch the ic with my finger even for more than 5 mins.
                      • coasterghost
                        Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
                        by coasterghost
                        For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
                        Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
                        Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
                        System Hardware:
                        Processor: AMD Ryzen 7 PRO 5850U
                        Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
                        09-08-2025, 10:46 PM
                        Lenovo 3000 Series Schematic
                        Lenovo 3000 was a line of low-priced notebook and desktop computers designed by Lenovo Group targeting small businesses and individuals. It was replaced with the IdeaCentre and IdeaPad brands.
                        3000 C100 laptop with Braille keyboard
                        Lenovo 3000 C
                        C100, C200 - 15-inch XGA screen
                        Lenovo 3000 N
                        N100, N200 - 14.1-inch- and 15.4-inch- WXGA models
                        N500 - 15.4 inch screen.
                        Lenovo 3000 V
                        V100, V200 - 12.1-inch WXGA models
                        Lenovo 3000 G
                        G400, G410, G430, G450, G455, G510, G530, G550, and G560...
                        10-04-2024, 06:05 AM
                        Lenovo IdeaPad 120S Notebook 100 Specification for Upgrade or Repair
                        This specification for the Lenovo IdeaPad 120S Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 120S boardview and 120S schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo IdeaPad 120S...
                        09-06-2024, 06:40 AM
                        This specification for the Lenovo IdeaPad 320 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 320 boardview and 320 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo IdeaPad 320...
                        09-06-2024, 06:06 AM
                      • derradji89
                        Need help Lenovo MIX 320-10lCR domaine name SERCOL
                        by derradji89
                        Hi everyone 🤗
                        I have a Lenovo MIX 320-10lCR computer.**
                        1. **Operating System**: Windows 10 ** Education** 64-bit.
                        2. **User Account Restrictions**: The account I'm using has heavily restricted permissions via **UAC** and **Group Policy**. This means I cannot install any software without admin rights, adjust system time, run Command Prompt as administrator, or modify the registry via Regedit—all are blocked.
                        3. **BIOS Password Protection**: The BIOS is locked with a password, preventing me from installing a new operating system.
                        4. **BIOS Chip Reflashing**: Currently,...
                        04-19-2025, 03:04 PM
