Crazy behaviour Acer 573G
  • bagaglia
    • Dec 2020
    • 11
    • Italy
    My laptop has a problem I am having very hard times to identify:
    - No hdd, nor dvd, ethernet and wifi card shown in bios
    booting from usb everything else works fine, audio and other peripherals are working.
    I flashed bios multiple time using also the clean me version, no luck.
    i measured the voltages in any coil and I guess I am getting the right readings,
    I'm lost, I have no clue
  • bagaglia
    • Dec 2020
    • 11
    • Italy
    Re: Crazy behaviour Acer 573G
    update:
    external vga works too.
    the hdd and dvd spin up regularly
    I upload a pictures of the voltages i did measure, they seem fine to me, does anybody have a clue?
    I really can't tell if it's a bios related issue or a hardware malfunction.
    • emestee
      • Dec 2019
      • 228
      • Bulgaria
      Please identify the board correctly.
      4.8 is a little low. Do you have a lab PSU? You should look for a pattern in power draw. What do you mean spin up regularly? Do they come up and down in a cycle?
      Because all the periphery you're describing feeds off 3.3/5 power rails, you should probably start looking there first. Look for things that overheat, low resistances, suspiciously looking elements and solder.
      • bagaglia
        • Dec 2020
        • 11
        • Italy
        Thanks for your reply.
        I mean that i can hear the hdd spin up when i turn the pc on, and then it will stay steady on (electrically), the dvd has voltage because if i press the open button it pops up the tray.
        They don't cycle.
        3.3 is present, 5 is present
        The board is a ZRT DA0ZRTMB6D0 REV D
        UPDATE:
        It "feels" like if a section of the board is off, but it seems logically more than electrically
        • emestee
          • Dec 2019
          • 228
          • Bulgaria
          Here's your schematic https://drive.google.com/file/d/1GtI...bdVAg6pDv/view
          You can start exploring the specifics.
          • bagaglia
            • Dec 2020
            • 11
            • Italy
            I'll take a look, but do you exclude a bios/ITE problem?
            • emestee
              • Dec 2019
              • 228
              • Bulgaria
              Unless for some reason there's an incorrect BIOS version installed, I would exclude it, yes. The chances of a flash chip being corrupt enough to ignore a significant chunks of periphery but nothing else are doubtful. I'm less certain about the ITE but this would be easily testable by checking the enable signals on the secondary power supplies.
              • bagaglia
                • Dec 2020
                • 11
                • Italy
                I finished intalling windows on this laptop via external usb disk, so again i report what is listed in device manager (briefly):
                1) Battery
                2) bluetooth
                3) audio controller
                4) usb controller
                5) webcam
                6) HID
                7) realtek audio
                8) video card
                9) keyboard
                missing:
                1) Controller IDE ATA/ATAPI
                2) wireless network adapter
                3) Realtek GbE controller LAN adapter
                4) DVD drive
                5) HDD drive
                • emestee
                  • Dec 2019
                  • 228
                  • Bulgaria
                  You're reporting conflicting things. Initially you said that after boot everything works fine. Now you are saying that some devices also do not appear in Windows.
                  If the latter is the case, you are looking at power problems or some fault related to PCI.
                  • bagaglia
                    • Dec 2020
                    • 11
                    • Italy
                    Hi again,
                    I said everything "else" works fine, sorry i didn't express myself clearly.
                    i listed the missing peripherals in order to show you what is missing precisely
                    • stingerchamp
                      • Sep 2020
                      • 425
                      • Pakistan
                      Interesting PCI issue
                      Have you checked load default settings in bios
                      Have you tried window ahci driver installation if applicable , mostly corrupted windows also show same issue
                      Tried window fresh install ,it will detect but I am saying all this as it seems to be software related issue
                      • bagaglia
                        • Dec 2020
                        • 11
                        • Italy
                        Yes, weird indeed.
                        windows installation is fresh, so no, i don't think so.
                        To be honest I can't understand why the bluetooth, audio controller and external vga and USB ports are working, while ethernet, wifi card and sata controller not,
                        the only thing i can think about is if they are controlled by the same piece of bios / ITE / voltage while the peripherals that work are controlled by another section. I don't have all this experience to understand it.
                        • piernov
                          • Jan 2016
                          • 4437
                          • France
                          Did you check under Linux with `lspci` to see what shows up on the PCIe bus?
                          The PLLs for these busses are powered from different pins on the PCH, going through different inductors. In general if power is missing on them it causes no POST, but you can still make sure the inductors are good and they have voltage on both sides. They are on the bottom part of page 11 of the schematics.
                          You'll have to use the component placement diagram of the boardview to locate them.
                          It's especially weird for the SATA controller to be missing as it's internal to the PCH, the Ethernet and WiFi controller are external so it could be an issue somewhere else on the PCIe bus.
                          Bluetooth is on the USB bus, audio codec IC is on the HDA bus so they kinda work independently. Although internally inside the PCH the controllers are connected to the PCIe bus.
                          • bagaglia
                            • Dec 2020
                            • 11
                            • Italy
                            did boot in linux,
                            lspci shows no ethernet nor wifi nor hdd
                            I'll try to measure volts in each inductor side, but other than that......
                            could it be a corrupted part of the ITE?
                            • bagaglia
                              • Dec 2020
                              • 11
                              • Italy
                              I retested all coils, voltage costant and regular on both sides
                                • 21417
                                Can you measure voltage on DEVSLP0 ,EC_ODD_EJ pin 94 ,ODD_POWER pin 71, IOAC_WLANPWR# pin 35
                                • bagaglia
                                  • Dec 2020
                                  • 11
                                  • Italy
                                  I'll try, but the pins are so clooooose on the ITE I'm afraid i'll fry something....
                                  By the way, Merry Christmas.....
                                    Acer Aspire F5-573G-77J1 Notebook F Specification for Upgrade or Repair
                                    This specification for the Acer Aspire F5-573G-77J1 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the F5-573G-77J1 boardview and F5-573G-77J1 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                    09-06-2024, 08:00 AM
                                    Acer Aspire F5-573G-7441 Notebook F Specification for Upgrade or Repair
                                    This specification for the Acer Aspire F5-573G-7441 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the F5-573G-7441 boardview and F5-573G-7441 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                    Acer Aspire F5-573G-719X Notebook F Specification for Upgrade or Repair
                                    This specification for the Acer Aspire F5-573G-719X Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the F5-573G-719X boardview and F5-573G-719X schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                    Acer Aspire F5-573G-70BQ Notebook F Specification for Upgrade or Repair
                                    This specification for the Acer Aspire F5-573G-70BQ Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the F5-573G-70BQ boardview and F5-573G-70BQ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                    Acer Aspire F5-573G-72FX Notebook F Specification for Upgrade or Repair
                                    This specification for the Acer Aspire F5-573G-72FX Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the F5-573G-72FX boardview and F5-573G-72FX schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
