hp 840 G3 BIOS adapter
  • fraig
    • Nov 2014
    • 36
    • cairo
    hi my friends
    hp 840 G3
    i have programmer TL866 PLUS but i can not read bios chip for this model
    i need a correct adapter to read this chip
  • emestee
    • Dec 2019
    • 228
    • Bulgaria
    Re: hp 840 G3 BIOS adapter
    Are you placing the chip correctly? Are you trying to do it via 1.8v adapter?
    • mrwab
      Banned
      • Jan 2014
      • 83
      • morocco
      Originally posted by fraig
      hi my friends
      hp 840 g3
      i have programmer tl866 plus but i can not read bios chip for this model
      hello take picture for your adapter and message error
      • fraig
        • Nov 2014
        • 36
        • cairo
        this adapter the normal size but i think this is not a correct adapter
        • fraig
          • Nov 2014
          • 36
          • cairo
          i use the normal size ( SOP 20 ) could you show me the adapter you use
            • 21853
            What is the bios chip, is it SOP8 or WSON .Part number ?
            • fraig
              • Nov 2014
              • 36
              • cairo
              this chip
              • hotcrossedbuns999
                M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
                by hotcrossedbuns999
                My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
                1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
                2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
                3. I could only locate two chips that look like bios chips. Could someone verify this
                01-03-2025, 12:32 PM
              • leezhihao2020
                TL866-3G programmer,bios chip 25B127DSIG which option should I choose?
                by leezhihao2020
                Hello dear friends,
                I download the software for the programmer T48 TL866-3G
                my HP ProBook 430 G5 2VP86EA with
                motherboard model: DA0X8BMB6F0 rev F and
                BIOS CHIP model: 25B127DSIG BIOS
                is showed there 4 times:
                25B127DSIG @DIP8
                25B127DSIG @SOIC8
                25B127DSIG @WSON8
                25B127DSIG @SOIC16
                So I don't know which version should i choose if I used the test clip cable?
                if I choose the wrong option, can it make damage to the chip or to one of the laptops while I used the test clip cable? because I have no experience in soldering....
                01-14-2023, 09:12 PM
                by SMDFlea
                Bad...
                09-02-2021, 04:40 PM
              • capoplays
                Help with BIOS update on Dell G15 5515 after chip replacement
                by capoplays
                Hey everyone,
                I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
                The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
                When I check the BIOS using the F12 menu Flash...
                10-24-2025, 06:53 AM
              • pirati
                by pirati
                Yesterday, 04:20 PM
