HP Elitebook 8470P Dead not Powering on drawing 0 amps.
  • platinumsteel
    • May 2019
    • 234
    • Trinidad&Tobago
    Hi guys hope you all are fine.I have a HP Elitebook 8470P have me confused.Hoping you guys can help me figure it out.It draws 0.00 amps and does not power on at all.I notice something weird on the 19V rail tho.I have 3v and 5v on coils tho.I have no PGOOD Signal on Pin 23 of the 3V/5V TPS51123RGER IC. I have Vreg3 which is 2.4V and Vreg5 Which is 5V. I have voltage on the TRIP1 and TRIP2 lines which I was told that it should not have any voltage there.Or else the IC goes into Protection Mode.Not sure if that is true.But anyway I have attached 2 pictures.One showing the voltages in relation to the schematic.Can you guys check it for me and see if you can pick up anything wrong? I started from the first at ADP_EN to the 2nd mosfet I believe.
    And below I have attached a picture showing between Pin 4 of the mosfet and the resistor in yellow which in diode mode shows to be shorted. Please feel free to correct me if any mistakes. I am a newbie.I suspect that the Mosfet may be at fault.But am having a hard time finding an exact replacement for it.I might have to order that mosfet.But wanted to make sure that's actually the issue.Thanks
    I have attached the schematic for this board below.Thanks
  • qayyum786
    • Aug 2018
    • 1933
    • INDIA
    Re: HP Elitebook 8470P Dead not Powering on drawing 0 amps.
    Remove ''R6000'' and check impedance on both point to make sure which area has shorted
    once got the low impedance point inject voltage to find the short
      • 20952
      Pin 4 is not short,you have 5.9V there which is the correct voltage,as its connected between 2 resistors which is called a voltage divider
      Vreg3 is too low.Do you have a DC power supply to inject voltage with
      • platinumsteel
        • May 2019
        • 234
        • Trinidad&Tobago
        Thanks for pointing this out to me.Yes I do have a DC Power Supply to inject voltage. And also tools to remove components. Possible if you can tell me where to inject voltage and how much voltage and amps I can start to inject? Thanks.
        I would like to try this.But can you tell me how much I can inject if i do find the point with low impedance? I went ahead and removed R6000 and checked the 2 points and below i have posted the results.Hope i have measured correctly.
          • 20952
          Vreg3 is the P3V3AL 3.3V always on voltage.Start by injecting 1V at 1 amp into that line,slowly increase the amperage,if it doesnt rise then slowly increase the voltage up to 3- 3.3V maximum ,if the amperage starts to rise check if any parts are hot to touch .
          • platinumsteel
            • May 2019
            • 234
            • Trinidad&Tobago
            Hi smd I just finished injecting with a minimum of 1V and 1 amp to a max of 3V and 2.5 amps into that line and well i didn't get any amp draw or voltage drop.So it looks like it's time for me to give up i guess.
              • 20952
              There`s only one enable pin for both vreg3 and 5, and the tonsel voltage is too low to issue power good.Don`t give up ,first try to resolder around the U6100 pins using plenty of flux and reflow if you have a hot air,if pin 8 is still only 2.4V after that replace the chip.
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                Give up-Why?? Its not that a difficult problem to solve. its either bad soldering on pins of tps51123 or the IC itself is bad. Vreg3 should be stable 3.3V. Entrip1 and entrip2 are enable for 3.3 and 5v-so you should get voltages there. I dont know where you heard this. ENTRIP=ENABLE(EN)+TRIP . The voltage on entrip lines should be like this roughly-eg if you have 130k resistor connected on entrip,voltage should be 1.3V approx. Without voltage on entrip pins ,you wont get voltage on coils of 3.3/5V
                • platinumsteel
                  • May 2019
                  • 234
                  • Trinidad&Tobago
                  Okay thanks mcplslg123 for your input.I replaced the exact IC from a donor board and am not sure if the IC is 100% ok...But now I have 3.3 on Vreg3 .But as you rightly said no voltages on Entrip1 and Entrip2 and i have no voltages on the coils now. EN0 is present.Still no Pgood. And it's not drawing any amps still.I have 1 more donor board with an exact IC .I will try that one and see how it goes.If confusion I will have to order new chips on ebay and see how it goes.
                  • platinumsteel
                    • May 2019
                    • 234
                    • Trinidad&Tobago
                    I have a final question tho..The original IC for this HP Elitebook on schematic is a TI_TPS51123RGER_QFN_24P . And the replacement chip or donor IC i have used is a TPS51123RGER-GP .Is that a good match?
                      • 20952
                      Its the same. Before you try the new one can you measure R6198 pin 1,and U6104 pins 1,2 and 4 voltage before and after pressing the power button
                      • platinumsteel
                        • May 2019
                        • 234
                        • Trinidad&Tobago
                        Hi guys i just wanted to report back here and close this issue.Ended up in a kind of rabbit hole with this Model Board.Ended up getting the 19V rail and 3v/5v rail working by making a slight mod to the dc jack 3 pins so that it will detect the center Pin..then all voltages came up..Then powered it on and then it stayed at 0.27 amps ..no matter what we did it will always keep drawing 0.27 amps.Spent an entire day troubleshooting looking for issues and nothing.So apparently there is some kind of defect with this model board.When i look online for it on ebay.There are a ton of them selling as parts only.And the issue is ''will not Power on'' ..So i decided to not fight up with this board anymore.So thanks a lot to you all for the help and useful information as always.
                        • mcplslg123
                          • Jun 2015
                          • 7262
                          • india
                          We respect your decision but i still beleive the issue could be resolved with little bit more digging.
                          • Sametbey
                            • Jan 2021
                            • 229
                            • Turkey
                            The general working principle is as follows, TPS51123 comes in 19v and outputs LDO 3.3v. It starts the KBC with LDO and comes with a 3.3v enable signal. TPS51123 sends the POWER_GOOD signal to KBC. It outputs 3.3v ALW and 5v ALW voltages. With the start command, other power units output 1.05v, 1.35v, 0.9v. the processor runs pch and RAM s. Step by step in as little as 0.5ms. When there is a problem, the current drawn can give an idea.
                            I'm not happy to be so strong. because it's not humanly
                              HP EliteBook 8470p Notebook 8000 Specification for Upgrade or Repair
                              This specification for the HP EliteBook 8470p Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 8470p boardview and 8470p schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for HP EliteBook 8470p...
                              09-06-2024, 05:27 AM
                              HP EliteBook EliteBook 860 16 inch G9 Notebook PC Notebook 800 Specification for Upgrade or Repair
                              This specification for the HP EliteBook EliteBook 860 16 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook 860 16 inch G9 Notebook PC boardview and EliteBook 860 16 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                              09-07-2024, 05:50 AM
                              HP EliteBook EliteBook 630 13 inch G9 Notebook PC Notebook 600 Specification for Upgrade or Repair
                              This specification for the HP EliteBook EliteBook 630 13 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook 630 13 inch G9 Notebook PC boardview and EliteBook 630 13 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                              09-07-2024, 05:20 AM
