HP Probook 650 G1
  • Dinneke
    • Apr 2014
    • 154
    • Netherlands
    HP Probook 650 G1
    HP Probook 650 G1
    CAPS lock and NUM lock blinks 5 times, there is a POST and hangs after that.
    Changed the BIOS, changed RAM, no result/no change.
    Any thoughts, please?
  • BL4K3Y
    • Apr 2020
    • 27
    • England
    Re: HP Probook 650 G1
    Have you tried a different CPU fan?
    If this doesn't work, then the system board has probably failed.
    • Stevedb
      Stevedb
      • Feb 2018
      • 624
      • Belgium
      Hi there you said there is post do you see the bios. Are all the power supply present .
      • Dinneke
        • Apr 2014
        • 154
        • Netherlands
        I see POST, then the flashing starts and hangs.
        I will look at Fan and supply voltages.
        Thanks all
        • Stevedb
          Stevedb
          • Feb 2018
          • 624
          • Belgium
          Hi
          You must probably try to clean me Intel region from your bios. If you can not do it self. Put your biosfile with external programmer in bios section. Ask there for to clean your bios and program it back to your board. Tip desolder bios to read the bios. I have the same working laptop here right now.
          Good luck
          Regards Steve
          • Dinneke
            • Apr 2014
            • 154
            • Netherlands
            Thanks,
            I allready tryed a cleaned BIOS from this forum, no improvement
            https://www.badcaps.net/forum/showpo...6&postcount=26
            • Stevedb
              Stevedb
              • Feb 2018
              • 624
              • Belgium
              Ok try a another processor i5 or I 3 4th generation.
              That was by my also the problem. I tried another processor and bird worked with my hp probook 450 g1. They use the same processor.
              Good luck let me know the outcome.
              Best regards
              Steve
              • Dinneke
                • Apr 2014
                • 154
                • Netherlands
                Update:
                CPU changed; no result
                Disassembled the lot, disconnected all FPC cables; got a CMOS RESET Alert, reconnected all, after that problems gone!
                • Stevedb
                  Stevedb
                  • Feb 2018
                  • 624
                  • Belgium
                  Did you use the same processor?
                  Best regards
                  Steve
                  • Dinneke
                    • Apr 2014
                    • 154
                    • Netherlands
                    Original CPU
                    • Stevedb
                      Stevedb
                      • Feb 2018
                      • 624
                      • Belgium
                      And all power lines are present? I will upload later my bios dump . And you can try it. Will be later in the afternoon when I am back home. Are you sure all power lines are present?
                      Best regards
                      Steve
                      • Dinneke
                        • Apr 2014
                        • 154
                        • Netherlands
                        it's solved, see above
                        • Stevedb
                          Stevedb
                          • Feb 2018
                          • 624
                          • Belgium
                          Hi Dubbele
                          That is good news. Well done, good job. 😉
                          Best regards
                          Steve
                          • Dinneke
                            • Apr 2014
                            • 154
                            • Netherlands
                            Turns out it was the ODD thats generates the error and hangs the system
                              HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook 400 Specification for Upgrade or Repair
                              This specification for the HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the HP ProBook 450 15.6 inch G10 Notebook PC boardview and HP ProBook 450 15.6 inch G10 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                              09-07-2024, 07:12 AM
                              09-07-2024, 06:40 AM
                              HP ProBook ProBook Fortis 14 inch G9 Notebook PC Notebook Specification for Upgrade or Repair
                              This specification for the HP ProBook ProBook Fortis 14 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ProBook Fortis 14 inch G9 Notebook PC boardview and ProBook Fortis 14 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
                              09-07-2024, 05:50 AM
                              HP ProBook Prenosni računalnik ProBook 445R G6 Notebook 400 Specification for Upgrade or Repair
                              This specification for the HP ProBook Prenosni računalnik ProBook 445R G6 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Prenosni računalnik ProBook 445R G6 boardview and Prenosni računalnik ProBook 445R G6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
                              09-06-2024, 10:51 AM
