neeed help plz aspire E5-575 zaa2
  • arber1232
    • Dec 2019
    • 379
    • Albania
    hi . i have acer aspire E5-575 zaa2... . aptop does not turn on 19 v is ok. 3.3 v comes on the power button and the battery charge light turns on but does not turn on. I tried the bios I found on this forum but it does not work, do you have any idea what I can measure? And can i help mee .. this is shcematic
    Last edited by SMDFlea; 11-25-2020, 06:31 AM. Reason: Added aspire E5-575 zaa2 to thread title
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: neeed help plz
    @arber1232, make your posts more meaningful by giving as much information as possible. What have you done to solve??What measurements you did?? With no such information, you cant really expect advice from others. Start with Page 43 of schematic where a nicely laid out power sequence is given. Check what you are missing.Next check page 44 .
    • arber1232
      • Dec 2019
      • 379
      • Albania
      Re: neeed help plz aspire E5-575 zaa2
      if i understand you then i'm telling you. I have an Acer laptop as I said above. the problem lies because it does not turn on. when I connect it to the laptop charger it turns on the charging light but I try to turn it on but it does not turn on .... I measured on the board that 19v is present .. The power button has 3.2v and the button is OK. I do not have 3.3v in the bios but when I press the power button then I have 3.3 in the bios ... I tried to program the bios but no change. . In ENE i have 3.3 volts. i do not have short in board.
      • stingerchamp
        • Sep 2020
        • 425
        • Pakistan
        Remove rtc cell and battery and power plug
        In cold state, press power button for 30 sec and release.
        Put rtc cell back and power adapter plug in only.try to turn on.
        Then put battery back and turn on.
        If above fails check voltage on rtc cell and check rsmrst# signal and nbswon# signal
        Lastly for your information bios gets 3.3v when power button pressed only
        • arber1232
          • Dec 2019
          • 379
          • Albania
          nbswon is okay goes to Ene and does the closing... yes 3.3 v is present in bios when i press power button
          • arber1232
            • Dec 2019
            • 379
            • Albania
            rsmrst# signal i have 3.2 v in ENE when press power button
            • stingerchamp
              • Sep 2020
              • 425
              • Pakistan
              It is a active on low signal.
              First verify at CLR you have 19volt
              Verify all rails are present ,+5,+3.3
              Check following signals and verify when you press power button how they react
              1- nbswon#
              2 - rsmrst#
              3- pltrst#
              4- hwpg
              5- dnbswon#
              If you are unable to find it
              Try going in cold check way
              Without any power check all big coils impedance all should be above 300 ohm except core and vccio.
              • arber1232
                • Dec 2019
                • 379
                • Albania
                coil are not 300 0hm. were somewhere at 0.17 ohm .. i have 5 v +3.3 v. nbswon # is ok i have 3.2 volts and when i press power button change voltage ie changes according to the button ... rsmrst # is present an i have 3.4 v and not change whwn i press power button. pltrst # i find in ENE but is 0 v ..and not change when i pres power button .. hwpg is present in tps51225 in pin 7 ,, 3.0 v and in ENE is zero in pin 22 .. dnbswon # is 3,4 v but not change when i press power button
                • arber1232
                  • Dec 2019
                  • 379
                  • Albania
                  hwpg signal En1 i have 3.2 v. En2 3.2 V
                  • stingerchamp
                    • Sep 2020
                    • 425
                    • Pakistan
                    Pltrst# should be inactive means high
                    If it is zero means something wrong
                    You have power sequence at page42 of schematic.
                    Check imvp_pwrgd , check ec_pwrok
                    And list coil impedance here all coils.
                    • arber1232
                      • Dec 2019
                      • 379
                      • Albania
                      motherboard is dead now missing all 3.3v
                      • stingerchamp
                        • Sep 2020
                        • 425
                        • Pakistan
                        That is a bad sign
                        What happened ,did you short pin while checking
                        At page 42 you have power sequence
                        Follow it
                        Check 19v present at first DC Jack connector and
                        • Fernon
                          • Apr 2019
                          • 13
                          • Sri Lanka
                          i have same problem ....my 3v 5v power swtch 3.3V OK ....
                          MY NBSWON# voltage 3.3V DNBSWON# 2.6V When Press Powerkey RSMRST# Voltage not out ...pls give me a solution
                          • mon2
                            • Dec 2019
                            • 14667
                            See attached.
                            Meter in DC volts setting.
                            Red meter probe to pin # 27. Black meter probe to ground.
                            Measure the voltage to ground @ pin #27 with the power switch open on the keyboard.
                            What is the voltage ?
                            Then press the power switch on the keyboard.
                              ACER Aspire Aspire X3910 Aspire E5700 Specification for Upgrade or Repair
                              This specification for the ACER Aspire Aspire X3910 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire X3910 boardview and Aspire Aspire X3910 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                              09-12-2024, 03:36 PM
                              ACER Aspire Aspire XC-330 Aspire XC A4-9120e Specification for Upgrade or Repair
                              This specification for the ACER Aspire Aspire XC-330 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire XC-330 boardview and Aspire Aspire XC-330 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                              09-12-2024, 03:30 PM
                              ACER Aspire Aspire XC-886 Aspire XC i5-9400 Specification for Upgrade or Repair
                              This specification for the ACER Aspire Aspire XC-886 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire XC-886 boardview and Aspire Aspire XC-886 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                              ACER Aspire Aspire X1301 Aspire 620 Specification for Upgrade or Repair
                              This specification for the ACER Aspire Aspire X1301 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire X1301 boardview and Aspire Aspire X1301 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                              09-12-2024, 03:28 PM
                              ACER Aspire Aspire Revo R3600 Aspire 230 Specification for Upgrade or Repair
                              This specification for the ACER Aspire Aspire Revo R3600 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire Revo R3600 boardview and Aspire Aspire Revo R3600 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
