Laptop Dell Inspiron 15, 5570, LCD panel damaged, no backlight, external monitor attached works fine… removed LCD and the 30 pin connector was burned at +BL_PWR. Replaced with new display cable and brand new (similar) LCD panel but same issue. Run the Dell diagnostic test and get the error “LCD cable not connected “. No visible burned components on MB (fuse F1 is ok). Checked the voltage at motherboard eDP connector found the +19VB rail (+DCBAT_LCD) is only 13.1V powered on charger or battery. Is that normal?
					Laptop Dell Inspiron 15, 5570, LCD issue
 Re: Laptop Dell Inspiron 15, 5570, LCD issue
 Thanks mcplslg123 for your reply... what other voltages should I check at that eDP connector ? The +LCDVCC (at U1, pin1) is 3.1V ... beside backlight missing, also I don't notice any video signal on the panel ...the replacement is LM156LF5_Panda screen vs original AOU B156HAN01.2Comment
 +LCDVDD, LCD_BRIGHTNESS, BLON_OUT_C,DCBAT_LCD-These are responsible for backlit issues. Since the error message is lcd panel not connected , i doubt you have missing EDP_TX0/TX1 lines.U1,Pin4-LCDVDD_EN missing?? First confirm these measurements and be careful while measuring.Comment
 Those panda panels are used in gaming laptops,and they are poor quality.Can`t find a datasheet for the exact model so don`t know what the refresh rate is or how many eDP lanes it needs. The AU original panel runs at 60Hz and 2 lanes .Last edited by SMDFlea; 11-19-2020, 07:31 AM.Comment
 Thanks again guys,...agree with you,... the new panel looks cheap but was purchased from laptopscreen.com (matte version)...I will measure those voltages with the LCD panel connected and get back to you!Comment
 So, the voltages at eDP connector are:
 pin7,8, +LCDVDD = 2.95V
 pin27, LCD_BRIGHTNESS =3.20V
 pin28, BLON_OUT_C =3.10V
 pin1,4 DCBAT_LCD=13.11V
 and pin4 U1=3.39V
 My guess is the recommend (Panda) screen is not compatible with original AOU !
 However I did boot up from USB Ubuntu with this new screen connected and "build in display" was listed on control panel with 1920x1080 resolution, but again no video and no backlight!Comment
 With the measurements above,you should have got backlit on even if no data on screen. You are not even having backlit-correct?? If so, doubt goes towards the panel itself being either bad or incompatible.Comment
			This specification for the DELL Inspiron 5570 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5570 boardview and 5570 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Inspiron 5570...09-06-2024, 06:06 AM
			This specification for the DELL Inspiron 5570 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5570 boardview and 5570 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Inspiron 5570...09-06-2024, 12:18 PM
- Loading...
