820-00165 Macbook Air 13" Green & Orange Light No Fan Spin
  • KappaDev
    • Feb 2019
    • 41
    I have an 820-00165 board with no visible corrosion or liquid damage.
    Laptop is a 13" Macbook Air (2017). When MagSafe is plugged in, light goes green and then stays orange without any fan spin after that.
    I took some readings and it looks like PP5V_S4RS3 is missing. It has an odd 20 ohms to ground so seems like its not a complete short.
    PPBUS_G3H - 8.59V
    PP3V42_G3H - 3.439V
    PPVRTC_G3H - 3.333V
    PP5V_S5 - 5.005V
    PP5V_S4RS3 - 0V (20ohm to gnd)
    PP5V_S0 - 0.443V
    PM_SLP_S4_L - 0V
    Charger is genuine, no noticeable areas getting hot.
  • piernov
    • Jan 2016
    • 4439
    • France
    Re: 820-00165 Macbook Air 13" Green & Orange Light No Fan Spin
    20 ohms to ground on PP5V_S4RS3 is a problem, should be several kohms at the very least.
    With 20 ohms you may be able to find something warming up by injecting 5V but it'll not be easy. Thermal camera would help a lot in this instance. When injecting, start at 1V and make sure voltage isn't leaking to PP1V05_S0, then you can increase up to 5.5V max.
    Otherwise you can remove components one by one until you find the culprit. Start by removing L7520 to see which side the short is on. Remove R6414 too to isolate from the speaker amp (and the filter caps) that are good suspects.
    • KappaDev
      • Feb 2019
      • 41
      Originally posted by piernov
      above ^
      Doesn't seem to be leaking into PP1V05_S0.
      Sadly don't have a thermal cam, removed L7520 and it looks like short exists on pin 1 side (PP5V_S4RS3 side). Removing R6414, 40ohms on pin 1 side (PP5V_S4RS3).
      Can't feel anything getting warm (although drawing 180mA when injecting into shorted side of L7520). Anything else I can try or simply leave for a while and keep checking for warm spots?
      EDIT: Left injecting current for a minute or two and U7501 area seems warm.
      • piernov
        • Jan 2016
        • 4439
        • France
        There are not too many components on PP5V_S4RS3 so if you can't find anything getting warm, the other solution is to remove them one by one. Use the boardview, for the components with only 2 pads (capacitors…) you can just shift them off of one pad. For U7501, U7600 and U8080 you have to remove them completely from the board (and at the end you'll have to put them back obviously) which is a bit more work so do them last.
        Still, do a close visual inspection of these components to make sure they're not damaged.
        • zpi
          • Feb 2018
          • 132
          • Lithuania
          How many Volts are you injecting?
          • KappaDev
            • Feb 2019
            • 41
            Started with 1V and after confirming no leak to the PP1V05_S0 moved up to 5V.
            Also realized that the short is only present when MagSafe is plugged in, if that helps any.
            • KappaDev
              • Feb 2019
              • 41
              Short is gone after removing U7501. Guess I'll have to find a donor lying around and swap it out.
                Acer Spin Spin 511 R753TN Chromebook Specification for Upgrade or Repair
                This specification for the Acer Spin Spin 511 R753TN Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Spin 511 R753TN boardview and Spin 511 R753TN schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                09-07-2024, 02:20 AM
                Acer Spin Spin 3 SP313-51N-58LR Hybrid (2-in-1) 3 Specification for Upgrade or Repair
                This specification for the Acer Spin Spin 3 SP313-51N-58LR Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Spin 3 SP313-51N-58LR boardview and Spin 3 SP313-51N-58LR schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                09-06-2024, 09:30 PM
                Acer Spin Spin 3 SP313-51N-58JR Hybrid (2-in-1) 3 Specification for Upgrade or Repair
                This specification for the Acer Spin Spin 3 SP313-51N-58JR Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Spin 3 SP313-51N-58JR boardview and Spin 3 SP313-51N-58JR schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                Acer Spin Spin 3 SP314-54N Hybrid (2-in-1) 3 Specification for Upgrade or Repair
                This specification for the Acer Spin Spin 3 SP314-54N Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Spin 3 SP314-54N boardview and Spin 3 SP314-54N schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                09-06-2024, 07:50 PM
                Acer Spin SPIN 1 SP111-33 Hybrid (2-in-1) 1 Specification for Upgrade or Repair
                This specification for the Acer Spin SPIN 1 SP111-33 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SPIN 1 SP111-33 boardview and SPIN 1 SP111-33 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                09-06-2024, 08:40 AM
