HP OMEN AX236TX DAG35DMBAD0 rev:D NO power no light
  • stingerchamp
    • Sep 2020
    • 425
    • Pakistan
    HP OMEN AX236TX DAG35DMBAD0 rev NO power no light.
    Hi ,
    This is another laptop with same problem in which there is no Power to the system while when checked for first two mosfet switching (19v rail area).
    I am getting 18.2 volts at the gate of first mosfet PQ1002 and it is a P-channel mosfet.
    PQ1002 first mosfet:
    pins 1,2,3=19volts , pin4=18.2 volts , pin5,6,7,8=19volts
    PQ1002 gate is controlled by PQ1004 voltage divider circuit , if we calculate for voltage at gate of PQ1002 it should be around 15volts (due resistors 220K,1M) but i am getting 18 volts.
    PQ1003 second mosfet:
    pin 1 ,2 ,3=0 volts , pin 4= 0 ,
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: HP OMEN AX236TX DAG35DMBAD0 rev NO power no light
    PQ1002 gate voltage is correct. 1M & 220K are not voltage divider circuit. Read the schematic carefully and try to understand it. You are not getting any voltage on PQ1003 pin 1,2,3 and thats your +PRWSRC-means 19V rail. What is the impedance on pin 1-2-3 of PQ1003?? Its likely to be shorted to gnd.
    • stingerchamp
      • Sep 2020
      • 425
      • Pakistan
      Thanks for the input but this PNP Bjt dual array is there for some reason.
        • 22141
        PQ1004 datasheet - https://cdn.badcaps-static.com/pdfs/...6fb3e5c604.pdf
        One area that you can study with a P channel mosfet is the Gate Threshold Voltage ,which can be very misleading. https://cdn.badcaps-static.com/pdfs/...c59cbfa3b0.pdf
        With no power attached chek PQ1002 in Ohms ,
        red lead on drain,black lead on source. Ohms =
        Black lead on source,red lead on drain. Ohms =
        • stingerchamp
          • Sep 2020
          • 425
          • Pakistan
          PQ1002
          with only cmos cell
          red lead on drain,black lead on source. Ohms = display OL
          Black lead on source,red lead on drain. Ohms = display OL
          PQ1003
          red lead on drain,black lead on source. Ohms = 2.2
          Black lead on source,red lead on drain. Ohms = 2.2
          red on pin5 and black on pin4 gate = 195 for 1 sec than reaches L
          • stingerchamp
            • Sep 2020
            • 425
            • Pakistan
            hello
            • stingerchamp
              • Sep 2020
              • 425
              • Pakistan
              In view of your private message , I have to change the multi meter because this one is a cheap one DMM and i can not perform Diode mode test(not supported) with this clamp multi-meter Dt-266 , I do not want to pull out anything from motherboard and have a desire to test the components while they are still in motherboard without any power attached. suggest any good DMM if any.
              • stingerchamp
                • Sep 2020
                • 425
                • Pakistan
                Just to complete this thread
                I successfully repaired my laptop ,vccsa coil was having liquid damage via hp omen SD card slot as it is very close, two caps were shorted and vccsa is attached to CPU therefore I was not getting signal.
                Replaced two caps and pq4012 problem solved
                Thanks all
                  HP OMEN OMEN by Desktop PC - 870-010na (ENERGY STAR) OMEN i5-6400 Specification for Upgrade or Repair
                  This specification for the HP OMEN OMEN by Desktop PC - 870-010na (ENERGY STAR) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OMEN OMEN by Desktop PC - 870-010na (ENERGY STAR) boardview and OMEN OMEN by Desktop PC - 870-010na (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
                  09-12-2024, 03:44 PM
                  HP OMEN X OMEN X by Desktop PC - 900-077na OMEN X i7-6700K Specification for Upgrade or Repair
                  This specification for the HP OMEN X OMEN X by Desktop PC - 900-077na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OMEN X OMEN X by Desktop PC - 900-077na boardview and OMEN X OMEN X by Desktop PC - 900-077na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
                  HP OMEN OMEN by Desktop PC - 870-117na OMEN 870 i7-6700 Specification for Upgrade or Repair
                  This specification for the HP OMEN OMEN by Desktop PC - 870-117na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OMEN OMEN by Desktop PC - 870-117na boardview and OMEN OMEN by Desktop PC - 870-117na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                  HP OMEN OMEN by Desktop PC - 870-180na OMEN 870 i5-6400 Specification for Upgrade or Repair
                  This specification for the HP OMEN OMEN by Desktop PC - 870-180na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OMEN OMEN by Desktop PC - 870-180na boardview and OMEN OMEN by Desktop PC - 870-180na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                  HP OMEN OMEN by Desktop PC - 870-050na (ENERGY STAR) OMEN 870 i5-6400 Specification for Upgrade or Repair
                  This specification for the HP OMEN OMEN by Desktop PC - 870-050na (ENERGY STAR) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OMEN OMEN by Desktop PC - 870-050na (ENERGY STAR) boardview and OMEN OMEN by Desktop PC - 870-050na (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
