Dell Vostro 1550 - 5V_S0 is enabled always
  • IamPritesh
    • Aug 2017
    • 356
    • India
    I have this strange issue where the HDD, ODD gets powered even when the system is in shutdown state. To be more specific the S0 state 3 volt and 5 volt are enabled as soon as ac adapter is plugged in. Ideally it should only be enabled after power-on.
    I am confused as to what is causing the auto enable of S5-s0 state specially for 5v and 3V . I have checked the mosfets u3601 and u3602 and they are not bad. The gate pin has around 7V .
    ..I am attaching the schematic just in case anyone wants to shed some light on this.
    PS- The system does start fine and works fine. But after shutdown the battery gets drained out even in shutdown mode.
  • piernov
    • Jan 2016
    • 4435
    • France
    Re: Dell Vostro 1550 - 5V_S0 is enabled always
    Voltage on all pins of Q3602 when off?
    • IamPritesh
      • Aug 2017
      • 356
      • India
      Thanks for responding. I can access to the board tomorrow. So that's a wait period of 10 hours unfortunately. To save some valueable time, can you please post the voltages it should ideally have for Q3602 and I will check as soon as I can .
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        Q3602 is 2 n channel fets combined in one package where pin1-2-6 is one fet and pin 4-5-3 is another. Your problem is RUN_ENABLE is high on pin3. It should be low in off condition. If you look at pin 4-5-3 part of fet then this is how it should work
        pin5 gate-must be high. N channel fet will pass current from Source to Drain when gate is high. So you have either no voltage or very low voltage on gate pin5. As far as my understanding is concerned, you should get voltage only on pin5 & 6 in off condition. Then it will work as intended.
        Since you have low or no voltage on gate pin5, ground (pin4) is not travelling from source to Drain(pin3) making RUN_Enable go high.
        • IamPritesh
          • Aug 2017
          • 356
          • India
          Thanks. The pin details are as follow :
          Pin1 - GND
          Pin 2 - 0V
          Pin 3 - 12V
          Pin 4 - GND
          Pin 5 - 1.2 V
          Pin 6 - 1.2 V
          Pin 1 - 0v
          pin 2 -
          • piernov
            • Jan 2016
            • 4435
            • France
            Check voltage on both sides of R3606, check resistance across R3606.
            • IamPritesh
              • Aug 2017
              • 356
              • India
              r3606 voltage on input side is 3.3 volt and output end has 1.2 volt. Havent checked the resistance
              • dellxps15
                • Feb 2014
                • 1588
                • italy
                do you have some usb charging option in bios ?
                • IamPritesh
                  • Aug 2017
                  • 356
                  • India
                  No such option . WAKE up on LAN is also disabled.
                  • dellxps15
                    • Feb 2014
                    • 1588
                    • italy
                    dunno if on sandy bridge 5v and 3v always are present only after power on. battery is attached to system ?
                    • IamPritesh
                      • Aug 2017
                      • 356
                      • India
                      The power sequence clearly shows that 5V_S0 should be high only after laptop powered on .
                      R3606 has 3.3 and 1.2V reading. Does that sound OK ?
                      • mcplslg123
                        • Jun 2015
                        • 7262
                        • india
                        R3606 READING IS DEFINITELY WRONG.It should be 3.3V on both sides. Is that resistor 100K?? Take it out of circuit and check. Do check Q3603
                        • IamPritesh
                          • Aug 2017
                          • 356
                          • India
                          Resistor is fine. It shows a reading of 99.5K ohms when taken out of the circuit. I will check Q3603 shortly.
                          • piernov
                            • Jan 2016
                            • 4435
                            • France
                            Any of Q3602, Q3603, Q3701, Q3704 could be pulling it low. R3606 is a very weak pull-up of 100k, so the "short to ground" will also be somewhere around 60k so it'll be hard to measure. You can try removing these transistors one by one and see if PS_S3CNTRL comes back to 3.3V.
                            Of course make sure there's no dirt or corrosion on the board since it could cause this kind of problem as well.
                            • IamPritesh
                              • Aug 2017
                              • 356
                              • India
                              Thanks for your suggestion. Will try it soon and update the results here
                                DELL Vostro 3268 Vostro 3200 i3-7100 Specification for Upgrade or Repair
                                This specification for the DELL Vostro 3268 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Vostro 3268 boardview and Vostro 3268 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Vostro...
                                09-12-2024, 03:44 PM
                                DELL Vostro 3660 Vostro 3600 i5-6400 Specification for Upgrade or Repair
                                This specification for the DELL Vostro 3660 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Vostro 3660 boardview and Vostro 3660 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Vostro...
                                DELL Vostro 3671 Vostro 3600 i5-9400 Specification for Upgrade or Repair
                                This specification for the DELL Vostro 3671 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Vostro 3671 boardview and Vostro 3671 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Vostro...
                                DELL Vostro 3670 Vostro 3600 i3-8100 Specification for Upgrade or Repair
                                This specification for the DELL Vostro 3670 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Vostro 3670 boardview and Vostro 3670 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Vostro...
                                DELL Vostro 3471 Vostro 3400 i3-9100 Specification for Upgrade or Repair
                                This specification for the DELL Vostro 3471 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Vostro 3471 boardview and Vostro 3471 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Vostro...
