Dell Inspiron N5110 3.3v present but not on power button
  • s_henya
    • Jan 2011
    • 480
    • Israel
    Hi Guys,
    appriciate your opinion on this weird case.
    laptop is working. but 3.3v is missing on power button.
    on 3.3 power supply i have voltage and on bios chip.
    if i take off the cmos battery the laptop auto turn on and works.
    i think this laptop had water damage and dc jack replacement before.
    i know the basic concept that 3.3 should be present on power button and on press reduce to 0 and then being read by super io chip and turn on.
    any idea?
  • peste
    • Dec 2016
    • 12627
    • ROMANIA
    Re: Dell Inspiron N5110 3.3v present but not on power button
    Originally posted by s_henya
    Hi Guys,
    any idea?
    check the ribbon between the start button and the motherboard.
    • s_henya
      • Jan 2011
      • 480
      • Israel
      I check the voltage on the mainboard.
      Counting from the left side
      Pin 1-2 are 5v when laptop is on
      Pin 3 should be 3.3 but shows 0. But not shorted to gnd
      Pin 4 is gnd
      Looks like something is lost on the way from the 3.3 line
      Any ideas or schematics?
      • miyagik
        • Jun 2018
        • 21
        • Mexico
        Pin 4 is gnd
        You have a problem over there!
        There must be only 3.3v no 5v in any pins
        Do you have the board no.? here is a picture about the pwon circuit.
        I found one schematic, here it is my friend!
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          WRONG. 5V is correct on pin 3-4(what @s_henya is counting as pin 1-2). Pin2 should have 2.4V approx. This mb has nuvoton sio and it has PSL Logic involved. So pwrbtn will not have 3.3V but should be 2.4-2.5V. On page 27, PSL logic is described. Start from there.
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            Sorry, Just read the entire post. You have 3V ALW on coil-so PSL logic is fine. No need to poke there. It has to be something wrong with RTC circuit.What is the voltage on G2101 Pad with RTC cell inserted?Check Q6001/Q6002 pins voltage.However, 5V on pwrbtn connector on pin3-4 is correct. So dont mess with it.
            • s_henya
              • Jan 2011
              • 480
              • Israel
              Thanks for your reply,
              i didn't find G2101 what is it?
              for the other measurements:
              Q6001: (S43)
              pin1 3.197
              pin2 3.028
              pin3 3.357
              Q6002: (K72)
              pin1 0 short to gnd
              pin2 3.028
              pin3 0 short to gnd
              so something is wrong with Q6002, should i try to replace it?
              i have no idea what is that transistor is, pin configuration, voltage and amps.
              i do have alot of spare boards, but i don't have the exact board to salvage.
              • s_henya
                • Jan 2011
                • 480
                • Israel
                Thank you for the schematic
                • s_henya
                  • Jan 2011
                  • 480
                  • Israel
                  Pin 4 is gnd
                  pin 1-2 has 2.7v not 5v sorry...
                  but pin 3 has 0v not shorted
                  • mcplslg123
                    • Jun 2015
                    • 7262
                    • india
                    Did you checked R6006?? Remove Q6002 and measure resistance on mb pads. Perhaps you are getting voltage at the gate pin. Source is ground anyway. Drain is grounded as well which i think is wrong. Q6002 is N channel fet 2N7002K. You can search this code on other scrap boards with schematics to get one. G2101 is your RTCrst# pad. Its important to find it out.
                    • s_henya
                      • Jan 2011
                      • 480
                      • Israel
                      Thank you for the help, i will try this evening and update.
                      Btw where did u get the info for that mosfet?
                      • s_henya
                        • Jan 2011
                        • 480
                        • Israel
                        i removed the mosfet but the pads are still shorted,
                        i couldn't find the part of the circuit in the schematics.
                        i also tried to inject 2v to the pin on the power button to see what is getting hot, but no current was drawn,.
                        i can do the same on the mosfet pins, but i don't know which pin should go where without schematics.
                        • kodox
                          • Jul 2017
                          • 322
                          • Indonesia
                          i had experienced same symptom but on two unit of acer mainboard, the culprit was the small capacitor near power button. it's not shorted but when voltage applied the voltage gone. hope this help
                          • s_henya
                            • Jan 2011
                            • 480
                            • Israel
                            i have a small resistor there, no cap in that area.
                              DELL Inspiron 5680 Inspiron 5000 i5-8400 Specification for Upgrade or Repair
                              This specification for the DELL Inspiron 5680 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 5680 boardview and Inspiron 5680 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                              09-12-2024, 03:30 PM
                              DELL Inspiron 5680 Inspiron 5000 i3-8100 Specification for Upgrade or Repair
                              09-12-2024, 03:28 PM
                              DELL Inspiron 3668 Inspiron 3000 i5-7400 Specification for Upgrade or Repair
                              This specification for the DELL Inspiron 3668 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 3668 boardview and Inspiron 3668 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                              DELL Inspiron 3650 Inspiron 3000 i3-6100T Specification for Upgrade or Repair
                              This specification for the DELL Inspiron 3650 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 3650 boardview and Inspiron 3650 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                              09-12-2024, 02:15 PM
