DAG75AMBAD0 Fans spinning crazy and BSOD
  • Dinneke
    • Apr 2014
    • 154
    • Netherlands
    HP Pavilion Power - 15-cb000nd
    Processor not heating up, heatpipe good
    Done: bios update(officicial HP file), makes no difference
    EC needs update?
    Also: slow POST/Boot
  • dspok
    • Jan 2014
    • 553
    • Nepal
    Re: DAG75AMBAD0 Fans spinning crazy and BSOD
    What are the voltage measurement?
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      @dinneke, you say slow post/boot on one hand and processor not heating up on another. I'm confused. Is the mb posting or not???
      • Dinneke
        • Apr 2014
        • 154
        • Netherlands
        Voltages shows normal.
        It is going to POST, after a (long) while and starting to boot but shortly after BSOD
        Not heating up but fans spinning like crazy.
        I meant : no abnormal heat (logical with those fans spinning)
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          Ram stick replaced with known good?? Try one ram stick at a time.
          • Dinneke
            • Apr 2014
            • 154
            • Netherlands
            Good RAM, no change
            • emil_t
              RTX3090 working fine but fans not spinning
              by emil_t
              Hello guys. I have a problem with a PNY XLR8 GAMING RTX3090 graphics card. The problem is that it displays and works fine, but the fans don't spin at all. The problem occurred when someone else removed the fans in order to clean it and broke one of the fan connectors. He replaced it himself and after that, it wasn't working anymore. I guess he damaged something else in the process. What i have done so far: I found 2 capacitors next to the connector that were in a bad shape, he must have touched them with his tools - they weren't shorted, but i replaced them with similar ones from a similar card....
              04-12-2024, 06:54 AM
            • sda sad
              my Xiaomi Notebook Pro X laptop fans work like crazy for no reason
              by sda sad
              Hope this is the right place, someone can help me.
              My laptop started having a really strange problem....
              When I turn it on the fans start working at a crazy rate and with random breaks...
              They can work for say 10 seconds and stop for 2 seconds and then turn on again for 5 etc...
              And it's from 0 to 100%. I tried to install AIDA and did the processor chip test and the graphics did not exceed 70 degrees and the fans were not even close to working at the power they work randomly.
              The model of the computer:
              Xiaomi Notebook Pro X 15 OLED (A30)
              04-23-2024, 09:55 AM
            • zaler808
              Macbook Pro 15" Late 2013 A1398 Turn off randomly but after workload it shows black screen with fans spinning
              by zaler808
              Hi guys, this my first post but i want to be brief about it, i recently got a MBP L2013, the problem was that after some use the macbook shutted down randomly, at first i suspected to be the battery, and after connecting it with the charger i noticed that i didn´t shut, but after an hour or so it shutdown, after that i started searching a solution to my problem, but my brother tried to help me to find the problem and it that process to replicate the problem he reproduced a 4k video in multiple tabs and not much time after the macbook shutdown to never power again, what i noticed was that the...
              05-23-2024, 05:17 PM
            • magneh
              Spectre X360 DAX38CMBAG0 - overheating fans not spinning
              by magneh
              Hello all
              Got this Spectre with an overheating problem.
              I verified that the fans start briefly during power up, but never turn on again,
              even when stress testing the machine and CPU at 100°C fans dont spin
              Ive measured and I have 5V, 3.3v and 3rd pin 0.
              When fans spin during start up, the signal at 0v is at 1.6v.
              Probably its Fan2Sig pin and 3.3V is PWM, not sure
              Question is , how to fix?
              I think these signals come from ITE controller am I right?
              Should I bother replacing it?
              Thanks...
              10-04-2022, 03:15 AM
            • b-slayer
              Asus Strix-G15-G513RM fans don't work
              by b-slayer
              I have an Asus Strix-G15-G513RM, who starts normally, but as the fans don't work, it stops and is really really hot,
              The Bios was the latest one, (327), but I managed to downgrade it to version 325 to see if it changed something,
              (as I read somewhere that a corrupted bios can explane my problem), but nothing, it just went full blow during the downgrade,
              (so now, i can say that the fans are fonctionnal), but as it restarted, the fans won't turn at all again.
              ah, and in the Bios, even when the temperature is really hot, the fan are a 0 rpm,...
              09-04-2025, 04:58 AM
