asus x555uq graphic card problem
  • Anethra
    • Dec 2018
    • 70
    • Turkey
    hello there. i have a little problem with asus x555uq. in bios, graphic card seen as intel 640 and nvidia 940mx. but in system nvidia graphic not seen. i tried with bios and after reflow to gpu. but no change.boardview in attachment.
    motherboard model x556uv rev:3.3
    laptop model x555uq
  • Rofix
    Asus H110 M-K network card problem
    by Rofix
    Hello I wanted to kindly ask for advice or this Asus H110 M-k motherboard, which unfortunately does not detect the network card to connect to the internet, I checked some voltages on the REALTEK8111-CG chip, on pins 11, 23, 32 I found 3.3 V
    Thanks to everyone in advance for any advice​...
    11-22-2024, 05:24 AM
  • gerbercage
    Asus GT220 1GB graphic card problem
    by gerbercage
    Recently when I start my PC, the bios will come out 1 long beep then follow by 2 short beep which is "Indicates a video error has occurred and the BIOS cannot initialize the video screen to display any additional information."
    Normally it will keep repeat this 1 long 2 short beep and will not proceed to load OS at all and stuck at there but for my case, it will just simply sound 1 time of 1 long 2 short beep then it pass and start process to load the windows but my monitor don't have display. The indicator at monitor light will keep blinking. I had test the graphic card...
    04-03-2019, 11:43 PM
  • lazaro.089
    Asus Zephyrus M16 / GU603ZW problem
    by lazaro.089
    Full name/ Model: Asus Zephyrus M16 / GU603ZW-M16.I93070T
    CPU: Core i9-12900H
    Onboard 8GB DDR5 4xMT60B1G16HC-48B:A
    Problem: This laptop was brought to the shop with the board already meddled with. Last technician (maybe without the right tools) removed an electrolytic capacitor (PCE9203) sensing resistor (PRS9801) and probably flashed both BIOS (U2802) and VBIOS(U7802).
    The laptop's behavior is: When connected, it tries to power up. CPU powers on, and (allegedly) the power sequence finishes and goes to S0 (PLT_RST = 3.3V). It consumes 600mA, ramps up to 1.100 A and...
    08-26-2025, 06:33 PM
  • AtelierRepa
    ASUS X712JA problem
    by AtelierRepa
    I have a problem with the bios, let me explain.
    With BIOS 1, the pc takes +- 30 seconds to display the ASUS logo (black screen) and to boot.
    I did a clear ME, my black screen problem for 30 seconds at boot is solved, it gives me directly the display and boots quickly.
    My problem is that now, once the charger is plugged in and I put a slight load on the processor, it bogs down to 0.39GHz...
    The only solution is to unplug the charger to get the cpu back up to speed. But as soon as I plug in the charger, it goes straight back down....
    06-15-2024, 04:33 AM
  • pkslowk
    Debug Card Error Code and Solution
    by pkslowk
    Sr. Motherboard Debug Error Code Solution
    1 Intel 845 E9 Bios Related Problem
    2 Intel 845 D4 CPU Socket Related problem
    3 Intel 845 37 Bios Related Problem
    4 Intel 845 7C Bios Related Problem
    5 Intel 945GCPE 34 Bios Related Problem
    6 Gigabyte 845 2 Ram Related Problem
    7 IBM Server A6 A7 Ram Mismatch Problem
    8 Asus 845 29 CPU Related Problem
    9 Lenovo I946 97 C-Mos Jumper related
    10 Gigabyte 845 A0 CPU Related Problem
    11 Asrock G31M-VS D7 Bios Related Problem
    12 Compaq 845 BD-70G B0 CPU Socket Related problem...
    01-28-2021, 12:51 PM
