Acer VX5-591G C5PM2 MB LA-E361P
  • Sebor255
    • Aug 2020
    • Polska
    Hello guys,
    I left my laptop for a few moments leaving my flat. When I come back I noticed my laptop is powered off. I am unable to turn it on. I have measured a voltage on PJP101 connector, it is about 19V. I have also checked PJP201 connector where after holding SW2 (when pressed battery is ON) the voltage is very low - about 0.13V. Could someone give me a hint what to do next?
  • Techtiger
    • Oct 2014
    • 1601
    • france
    Re: Acer VX5-591G C5PM2 MB LA-E361P
    Do some basic stuff remove the battery/ Bios battery / power supply keep holding PWRBTN 10 sec and see if not Dissemble Check the voltage on PR304 +19V Schematic is available 3/5V at page 47 on the Coil Pl402/404
    • popal
      • Jul 2014
      • 30
      • canada
      i got same problem but i am getting 3/5v at pr304+19v and also on the both coil but it is still not powering on
      • emestee
        • Dec 2019
        • 228
        • Bulgaria
        Please see the pinned posts "beginner guidelines" and "charger circuit" on the top of this forum.
        • emestee
          • Dec 2019
          • 228
          • Bulgaria
          If I understand correctly, you get 19v on the current sensor, and 3 and 5 standby voltages. If that is the case, check the CMOS battery >3.0v, presence of power on EC and the flash, and 3.3v on the power button (and that it goes to 0 when it is pressed)
          • popal
            • Jul 2014
            • 30
            • canada
            yes i did not not check the power botton since i dont have the power light or baterry light on
            • emestee
              • Dec 2019
              • 228
              • Bulgaria
              That means the opposite of what you think. The LED control signals are inverse; which means that the LEDs are off either because there is no power, or because the GPIO pins of the EC are in the wrong state (as may be the case if it lost its internal flash contents). Do the checks.
              • popal
                • Jul 2014
                • 30
                • canada
                thanks for reply
                there is power on on the middle led light but it doesnt turn on i will check the led light right now
                • popal
                  • Jul 2014
                  • 30
                  • canada
                  y i am not getting 12v on the battery
                  • emestee
                    • Dec 2019
                    • 228
                    • Bulgaria
                    The battery does not output voltage until its BI pin is shorted to ground (sheet 45 of the schematics). For this to work, the transistor PQ201 that controls it must be intact, and the CMOS battery must have sufficient voltage.
                    • popal
                      • Jul 2014
                      • 30
                      • canada
                      thanks man i changed the pq201 and now its showing the battery light flashing which means charging but the laptop not turning on any solution please
                      • popal
                        • Jul 2014
                        • 30
                        • canada
                        sorry the battery voltage for power is still 0.21v but the middle light is flashing when i put the dc power in.
                        • emestee
                          • Dec 2019
                          • 228
                          • Bulgaria
                          If you mean the CMOS battery is 0.21v, that is to be expected. If the transistor you replaced was shorted, then the CMOS battery would have drained. You need to replace it with a >3.0V one and then see if the main battery charges.
                          If you mean the main battery is 0.21v, then the battery is discharged beyond the safety threshold and its internal controller probably will not allow it to charge. Dealing with batteries requires skill and equipment; I do not advise doing it on something you care about because you will probably destroy the first one.
                          In either case this is good time to go to the "charger circuit" tutorial.
                          • popal
                            • Jul 2014
                            • 30
                            • canada
                            jut wanna update i have 1.23v on power on button
                            • emestee
                              • Dec 2019
                              • 228
                              • Bulgaria
                              That's not ok. It should be 3.3. Start testing LDOs and power rails.
                              • popal
                                • Jul 2014
                                • 30
                                • canada
                                hi to update on my laptop i pull up the pq306 and now i got 3.27v at the power on button and the mosfet is fine.
                                • emestee
                                  • Dec 2019
                                  • 228
                                  • Bulgaria
                                  I hope you mean you replaced the mosfet and not just removed it. Powering up the board with a missing mosfet is dangerous.
                                  What do you mean "the mosfet is fine"? Are you saying the mosfet that you pulled out shows ok on the tester?
                                  • popal
                                    • Jul 2014
                                    • 30
                                    • canada
                                    yes that is what i wanna say
                                    • popal
                                      • Jul 2014
                                      • 30
                                      • canada
                                      i am tired of this and can not give up ether.
                                      • emestee
                                        • Dec 2019
                                        • 228
                                        • Bulgaria
                                        Mosfets can fail in subtle ways. If with the new one the board works, then the old one has failed, even though it doesn't show shorts. Mosfets can fail to half-open and in other ways.
                                        Now you should retest the power rails and see what happens when you try to power up the board.
                                          09-06-2024, 05:27 AM
                                          Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook 3 Specification for Upgrade or Repair
                                          This specification for the Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Swift 3 Ultraschlankes Notebook boardview and Acer Swift 3 Ultraschlankes Notebook schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                          09-07-2024, 05:00 AM
                                          Acer Aspire Acer Aspire 7 Charcoal Black Notebook 7 Specification for Upgrade or Repair
                                          This specification for the Acer Aspire Acer Aspire 7 Charcoal Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 7 Charcoal Black boardview and Acer Aspire 7 Charcoal Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                          Acer Nitro Acer Nitro 5 Black Notebook 5 Specification for Upgrade or Repair
                                          This specification for the Acer Nitro Acer Nitro 5 Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Nitro 5 Black boardview and Acer Nitro 5 Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-07-2024, 04:10 AM
                                          Acer Swift SF114-34-P5YB + Pack Gold Acer 14'' Notebook 1 Specification for Upgrade or Repair
                                          This specification for the Acer Swift SF114-34-P5YB + Pack Gold Acer 14'' Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SF114-34-P5YB + Pack Gold Acer 14'' boardview and SF114-34-P5YB + Pack Gold Acer 14'' schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
                                          09-07-2024, 03:10 AM
