ASUS A442UR No CPU VCORE
  • kodox
    • Jul 2017
    • 327
    • Indonesia
    anyone experienced with this kind of problem?
    things done so far:
    - flashed bios from this thread: https://www.badcaps.net/forum/showth...ghlight=a442ur
    - tried editing the bios downloaded from asus website
    - changing the NCP81236A (VRM Controller)
    all power rails present even on discrete GPU (0.9V) and VRAM (1.35V)
    help would be appreciated, thanks
    mainboard id: X442UQ Rev.2.0
  • Duranitron
    • Jul 2014
    • 544
    • Philippines
    Re: ASUS A442UR No CPU VCORE
    usually bios update can solve that.. try to replace the coil and 2 mosfets connected to the processor.. or if you have the schematics..trace the signal of the gate of mosfet that powers the processor.. or try this at you own risk try to inject 1 volt and see if the processor turns on gudluck...
    Never stop LEARNING because life never stops TEACHING!
    • kodox
      • Jul 2017
      • 327
      • Indonesia
      thank's for the answer... sadly i don't have (yet) the schematic nor boardview for this board and i only have a multimeter to check, what signal should i trace?
      • Duranitron
        • Jul 2014
        • 544
        • Philippines
        processor core voltage is 1 or 1.2 volts depending on processor..you said that you measure all the voltage rails.. usually the core voltage is produced by an inductor coil and mosfet capacitor buck converter located near the processor.. try to check for failing mosfets or the uncommon open inductor coil..
        • kodox
          • Jul 2017
          • 327
          • Indonesia
          this mainboard use i7 for processor, no open inductor or bad mosfet and there were no voltage produced from inductor near the processor. after i trace the mosfet path, the gate is controlled by NCP81236A (no datasheet available) and i've been replace it too. further trace i found that this ic also control buck converter for other two inductor and those three inductor are flat zero volt.
          where should i checked again?
            • 21134
            Post your original bios in the bios requests section. Are there any white/green stickers with the model number on the RAM slot ,X442UQ,X442UR or X442URR.
            • kodox
              • Jul 2017
              • 327
              • Indonesia
              i think i've mentioned mainboard model on my first post, it's a X442UQ Rev.2.0 mainboard
                • 21134
                Yes, but is it silkscreened on the board or on the sticker. Post the part number on the sticker if it has one,and a picture
                • kodox
                  • Jul 2017
                  • 327
                  • Indonesia
                  i've just noticed, the sticker and the silkscreen is different
                    • 21134
                    Yes thats what i wanted to know.If you look at the bios downloads on the asus support site it offers 2 different ones for the X442UR and X442URR ,we got the bios "X442UR" name from your bios backup anyway.Its always worth checking as its easy to get different bios mixed up with asus boards.
                    https://www.asus.com/id/Laptops/ASUS...HelpDesk_BIOS/
                    • kodox
                      • Jul 2017
                      • 327
                      • Indonesia
                      i've tried your bios from https://www.badcaps.net/forum/showthread.php?t=86909
                      the problem still remain, i think the processor is dead anyway
                      • Duranitron
                        • Jul 2014
                        • 544
                        • Philippines
                        the processor is not dead ... there is only no power so u need to figure out how this unit powers the i7 processor.. make sure NCP81236A have VCC focus on these ic..
                        Alternative Parts
                        (Cross-Reference) ISL6265AHRTZ-T; MAX17019ATM+; LTC2950CTS8-2#TRM;
                        https://www.win-source.net/on-semico...1236mntxg.html
                        try that...
                        • kodox
                          • Jul 2017
                          • 327
                          • Indonesia
                          thank's for the support, actually this board had consumed 14 day of my time without any progress and the owner decided to take it back.
                          as far as remember the NCP had 3.3v, 5.2v and 19v input without any output on three inductor, no datasheet avail. also for the chip makes me more frustating after no boardview or schematic found on web
                            • 21134
                            I posted the boardview. https://www.badcaps.net/forum/showthread.php?t=85968 . you could have checked P_IMVP8_EN .
                            • piernov
                              • Jan 2016
                              • 4437
                              • France
                              NCP81246 might be similar.
                              CPU requests its own CPU VCore voltage. Gotta make sure VCCSA is present first.
                              • kodox
                                • Jul 2017
                                • 327
                                • Indonesia
                                thank's for the boardview, saved for later use. cause the unit has been taken by the owner, but, assume i had P_IMVP8_EN signal should i have voltage on VCCSA inductor (PL8104 on boardview)? what if not?
                                • roypinzon
                                  • Sep 2019
                                  • colombia
                                  Hello friends greetings, I have the same failure of the partner with the same motherboard model x442uq rev: 2.0; I already made bios and it remains the same.
                                  Checking the forum I observe that I do not have the * P_IMVP8_EN * and according to the boardview it comes from pin 98 of the kbc but I check and I do not have 3v voltage.
                                  I stay tuned thanks friends !!
                                  • bestechrepairs
                                    • Nov 2018
                                    • 20
                                    • sri lanka
                                    Thank you Sir SMDFlea
