Acer ZRW battery now charging
  • kalilinux25
    • Mar 2018
    • 2089
    • ZAMBOANGA SIBUGAY
    Hi good day to all the problem of this board is shorted I already remove the "PD8, PQ22, PR213" and I just make a jumper from pj2 connector Vin to PR213 pad, now the battery is not working
    Battery connected Checking voltage on pr169 reading is 800mill volt
    PC118- 19V
    PU5
    PIN 18- 800MILI VOLT
    PIN3 -18V
    PIN4- 18V
    PIN 28- 18V
    PIN 6- 2.5V
    PIN5-2.5V
    PIN 11- 2.7V
    PIN12- 3.2V
    PIN 7 -600MILIVOLT
    PIN 8 -3.3V
    PIN 9 - 3V
    PIN27- 0V
    PIN17- 800MV
    DA0ZRWMB6G0 REV G
    Idont know whats wrong on this unit
    schematic and boardview pdf is attached
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Acer ZRW battery now charging
    It wont work. Why you have not replaced those components?? Dont you see PQ22,pin4 is your ACDRV. Without the gate opening of this fet, charging will be disabled.Replace all those removed components first and then observe.
    • kalilinux25
      • Mar 2018
      • 2089
      • ZAMBOANGA SIBUGAY
      NICE . very appricieted sir thansk for the comment a big help to me.. yes!
      • kalilinux25
        • Mar 2018
        • 2089
        • ZAMBOANGA SIBUGAY
        I arlredy tried to change the PQ22 but it work around 5 mins then it got broken Again there is no shorted on board but why the msofet get damage?
        • kalilinux25
          • Mar 2018
          • 2089
          • ZAMBOANGA SIBUGAY
          it will just work for a while the nturn off i already tried 3 pq22 a0n6414al but it just work for a minute then dead
          • kalilinux25
            • Mar 2018
            • 2089
            • ZAMBOANGA SIBUGAY
            iss it the charger ic is faulty?
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              Yes, charging ic can be faulty.
              • kalilinux25
                • Mar 2018
                • 2089
                • ZAMBOANGA SIBUGAY
                nice ill just order the parts and give updates
                • kalilinux25
                  • Mar 2018
                  • 2089
                  • ZAMBOANGA SIBUGAY
                  I tried to cahnge the charger ic but its giving me 3v at PR213
                  • Sametbey
                    • Jan 2021
                    • 229
                    • Turkey
                    If there is no short circuit after PR213 and the BQ24780 chip is properly soldered, the operating voltages should be as in the diagram. PR5 resistance 20oHm is important.
                    I'm not happy to be so strong. because it's not humanly
                    • Bowline
                      by Bowline
                      06-11-2025, 10:13 AM
                    • titomno2
                      Acer A315-41G similar to AN515-42, AC OK Battery OK but not charging
                      by titomno2
                      Hi guys,
                      I currently trying to figure out why the laptop of my friend did not charge.
                      It is a Acer AN515-42 (Ryzen 5 2500U), I manage to make it works on AC and battery but no charging.
                      At first it was not working on Battery, I discovered that PQ201 was knocked off and replace it => work on battery precharged on another computer.
                      I also checked the small resistors between PQ312 and PQ201 and even if they are ugly values are OK.
                      My issue, when I plug the charger computer off, it drains 0.25A during few seconds with amber light on (charging) then amber light blinks...
                      06-11-2024, 11:52 AM
                    • abrahim110
                      [Help Needed] Acer Aspire 5 A517-52G โ€“ Removed Onboard RAM, Now Working But Battery Not Charging
                      by abrahim110
                      ๐Ÿงต [Help] Acer Aspire 5 A517-52G โ€“ Onboard RAM Removed, BIOS Mod Done, Battery Not Charging
                      I have an Acer Aspire 5 A517-52G-53NB laptop.
                      The onboard (soldered) RAM was faulty, so I physically removed the chip.
                      I also successfully modified the BIOS using the SPD Removal Tool โ€“ the laptop now boots fine and works with an 8โ€ฏGB DDR4 SO-DIMM installed.
                      โœ… System status:
                      • BIOS mod is done (SPD removed)
                      • Laptop boots to Windows normally
                      • RAM is detected and stable
                      โŒ Problem:
                      The battery is not charging:
                      • Power adapter
                      Today, 06:15 AM
                    • Julian Bailey
                      HP ProBook 445 G8 Battery not charging
                      by Julian Bailey
                      Hi all
                      We have in a HP ProBook 445 G8 laptop with AMD Ryzen 7 CPU. When power is connected the power LED light blinks 5 times then stops. Normally HP laptops will blink this LED 10 times as it does a self test when the AC adaptor is inserted. So there must be some sort of short somewhere.
                      The battery doesn't charge, and is erratic on the MM voltage. Bench PSU LED pulsates when the battery is connected also. So the fault must be on the charging circuit?
                      I have gone around the board with a MM and cant find anything
                      Windows shows the battery fine,...
                      10-11-2024, 10:34 AM
                    • Source Code
                      Acer Nitro 5 not charging but working with battery
                      by Source Code
                      Hello Everyone
                      First I must say I am trying to learn electronics. I have an Acer Nitro 5. Board is LA-861P. The laptop does not charge but when it has battery life it would power on and work fine. I have use a multimeter to check the charger and I get 19v.
                      Input on PBQ3 mosfet is 19v but no output or very low voltage. The voltage on PCZ65 and PCZ48 is 2v and it keep dropping after putting the charger for a few second. Battery pin would give like 0.200v declining.
                      If I put the laptop off for like 2-3 months it would start charging again but I need to do this...
                      11-17-2024, 12:44 AM
