Lenovo x1 carbon Gen 2 No POST Dislay
  • NiroPall
    • Dec 2018
    • 119
    • Sri Lanka
    Dear All,
    When power on Lenovo X1 carbon Gen 2 laptop then it turns on but no POST display and then after few seconds it boots to windows and works fine .
    Updated with latest BIOS but no POST display and cant enter the BIOS settings.
    Any one can help please,
    Thanks.
  • Duranitron
    • Jul 2014
    • 544
    • Philippines
    Re: Lenovo x1 carbon Gen 2 No POST Dislay
    Originally posted by NiroPall
    Dear All,
    Thanks.
    did you try to press the reset button to enter the bios settings? try to find a button or a hole with this logo...
    • NiroPall
      • Dec 2018
      • 119
      • Sri Lanka
      Thanks dear i will try.
      • NiroPall
        • Dec 2018
        • 119
        • Sri Lanka
        Its not wok. Same problem mean no bios screen displays. any one can help.
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          Press F2 while holding down shift key at bootup.
          • Duranitron
            • Jul 2014
            • 544
            • Philippines
            you need to turn off your unit then press the reset button or try at boot up hold FN +F2
            • NiroPall
              • Dec 2018
              • 119
              • Sri Lanka
              At the startup there is nothing on the display even lenovo logo not appears, . i have reset it by using the button, after that beeps are coming but nothing on the display. and back lights are on but no data on the display.but boot to windows and can work. is this a hardware fault? i connected external display through HDMI but result is the same.
              • grefaldia
                • Jul 2020
                • 21
                • philippines
                mybe the display graphics or try ram.
                • Luaina
                  • Sep 2016
                  • 12
                  • Madagascar
                  Reflash the BIOS
                  • NiroPall
                    • Dec 2018
                    • 119
                    • Sri Lanka
                    i updated the bios on windows, The problem was not fixed.
                    • krawat274
                      • Jun 2020
                      • 53
                      • Poland
                      Hello. Tell me if I understood. You turn on laptop and you want to go inside BIOS Setup, but it not display anything just loading Windows? If that, try to load Windows and then click on restart button on Windows, and when it restarting press immediately F1 key. If not work try the same operation with pressed FN key (FN + F1). If not work, try load Windows and press restart button with Shift key pressed (and all rest the same, F1 or F1 + FN).
                      • Zibbo
                        • Mar 2017
                        • 204
                        • Zimbabwe
                        You may try to flash the bios with a programmer
                        • NiroPall
                          • Dec 2018
                          • 119
                          • Sri Lanka
                          (You turn on laptop and you want to go inside BIOS Setup, but it not display anything just loading Windows) ? Yes you are right, actually the problem is cannot see the bios screen even lenovo logo at startup back light of the display light up but no data at the startup . Can go to the bios using these key combination but cannot see anything. I removed the hard drive and try. not worked. i think this is a hardware problem right?
                          • NiroPall
                            • Dec 2018
                            • 119
                            • Sri Lanka
                            yes i will try. im looking for bios bin for my laptop. FRU PN - 00HN769
                            LMQ - 1 MB 12298-2 48.4LY06.021 this is the model. X1 carbon Gen 2 20A8
                            Tks.
                            • audiomodder
                              • Dec 2017
                              • 54
                              I have the same issue. Boots, keyboard lights, fan spin
                              NO display backlight, post, or sound..
                              after 2 seconds it does a hard shut off.
                              Tried reset and battery disconnect.
                              Suspecting GPU or RAM... anyone repair one?
                              • piernov
                                • Jan 2016
                                • 4439
                                • France
                                @NiroPall 's issue is different. His machine can boot into Windows.
                                There is a widespread motherboard issue on X1 2nd gen which seems related to the CPU. Some people say that giving some heat to the CPU (not reflow) brings it back to life for a short while.
                                • audiomodder
                                  • Dec 2017
                                  • 54
                                  thanks so much!
                                  Heat but no reflow tho...? Seems a bit strange. Sounds like this is fixing cold solder joints, classic reflow issue. If it's not reflowing, what would "heat" do?
                                  Any links to this known issue? I couldn't come up with anything.
                                  Really appreciate your help
                                  • audiomodder
                                    • Dec 2017
                                    • 54
                                    Okay, I attempted to reflow… Results are mixed.
                                    Now the system gives me a blink code for the battery no longer enters an endless power on/off boot loop.
                                    However, I get nothing on the screen (no post) and it will not shut off if I push the power button again, I have to hold it down to do a full system shut off.
                                    I tried hooking it up to an external HDMI monitoring got nothing there as well. Same with display port
                                    Keyboard lights up and keyboard dimming controls work.
                                    Any ideas? This does seem to indicate a more classic symptom of bad RAM..wondering if a chip is bad, maybe I can remove 4x of the ICs for a 4GB mobo lol. sucks that repairing with reballed RAM would be too costly / difficult.
                                    • NiroPall
                                      • Dec 2018
                                      • 119
                                      • Sri Lanka
                                      Did you flash the BIOS using a programmer?
                                      • emestee
                                        • 228
                                        Dont make assumptions. Start testing the voltages and reset signals.
                                          Lenovo ThinkPad X1 Carbon Notebook X Specification for Upgrade or Repair
                                          This specification for the Lenovo ThinkPad X1 Carbon Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X1 Carbon boardview and X1 Carbon schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
                                          09-07-2024, 06:31 AM
                                          09-07-2024, 07:20 AM
