Pegatron B14Y backlight problem
  • asliyucegsm
    • Jun 2011
    • 347
    • Turkiye
    my friend
    DNS B14Y
    Pegatron B14Y rev: 2.0
    NPCE795LA0DX
    Sr0N9
    SLJ8C
    schema
    there is an image on the external display
    +18volt ok
    +3.3 volt ok
    What signals should I check from Npce
    No data signal in lvds connector
    thanks
  • peste
    • 12593
    • ROMANIA
    Re: Pegatron B14Y backlight problem
    check the video chip..heat the video chip carefully, use the flux paste, this operation is trial ... if everything is ok you will have to do reballing ..
    • Duranitron
      • Jul 2014
      • 544
      • Philippines
      Originally posted by asliyucegsm
      my friend
      DNS B14Y
      NPCE795LA0DX
      Sr0N9
      SLJ8C
      schema
      +18volt ok
      +3.3 volt ok
      thanks
      before you do the suggestion of peste.. try this if the system boots and have a display in the external monitor press F8 to switch to onboard lcd panel..if it displays.. try to reflash your bios with latest bios dump.. if no display using the external monitor try to go to device manager and click the display adapter look for exclamation point. if you see it.. video chip is toasted. if not.. if you can substitute a known compatible working lcd panel try that.. if not.. try the suggestion of peste..
      • asliyucegsm
        • Jun 2011
        • 347
        • Turkiye
        lcd panel.ok
        bios.ok
        integrated graphics and processor
        I heated it up a little bit but it may have deteriorated from the same overheating
        thanks friend
        • Duranitron
          • Jul 2014
          • 544
          • Philippines
          using external monitor go to device manage have you seen dual gpu? maybe one of it fails..no exclamation?
          • Duranitron
            • Jul 2014
            • 544
            • Philippines
            or try to uninstall the video driver use only the basic driver and restart..
            • Dobrowol
              Asus GA402RK keyboard and kb backlight problem
              by Dobrowol
              Hi. I have a problem with Asus ROG GA402RK. The keyboard suddenly stopped working along with the kb backlight. I replaced the keyboard and the ITE KBC chip and the problem is still the same. I don't see any passive elements that look damaged. Does anyone have an idea?
              04-28-2025, 04:30 PM
            • ononos
              LG M2362DP Backlight problem
              by ononos
              hello everyone!
              As the title states i am an owner of an LG flatron M2362DP 23 inch monitor Tv. Since i currently use it as a tv i'm posting the problem on the "troubleshooting tvs and video sources" section.
              I'm from Greece so English isn't my native language, so please forgive me for any mistakes i make. I have basic knowledge in electronics, and although i have a degree, many things have changed since i finished a 2 year coarse (over 30 years ago). Occasionally i repair easy stuff, mostly things that break at home like appliances.
              So i decided to try to...
              03-12-2023, 05:05 AM
            • fanaticgames
              Samsung UE32D4010 Backlight problem, led ok
              by fanaticgames
              hello I have a backlight problem on this TV, if I unplug the cn201 cable the backlight works perfectly and the voltages are 13v if I connect the cn201 cable the backlight goes off and the voltage drops to 12v, I assume it's a motherboard problem, the question is has anyone had a similar problem? I want to understand if the motherboard is repairable or it's not worth wasting time...
              02-22-2023, 09:46 AM
            • Honziq
              Backlight problem - Asus M3200WU, board Gapal LA-L291p
              by Honziq
              I have this All-in-one PC, after SSD change there is no picture. I was found out it is a backlight problem, but LEDs are OK. There is 4 led strings each working on 42,4V, but from board is comming only 5V.
              I was repaired many backlights before but this design i will not understand.
              For me it looks like it is waiting for some signal from screen to start up the backlight or something like this. Nothing seems to be damaged or shorted here.
              Can someone explain me please what to do, what to check?
              Thanks....
              11-20-2024, 01:24 PM
            • grbo92
              Backlight problem Acer LA-031P
              by grbo92
              i have one acer Nitro 5 without backlight on my desk.
              Mainboard model: LA-L031P GH53Z REV 1B
              Attached schematics and boardview are REV 1A, slightly different as REV 1B.
              11411_LA-L031P-Acer_Nitro_5_AN515-45_AN517-41-GH53Z_Rev_ (1).zip
              Repair history: customer cleaned dust and changed thermal paste, shortly after that there was no light
              Notebook boots without problem and shows only image without backlight, HDMI output working. Optical inspection done, no burned or broken components. Tested also with a new display module....
              09-09-2024, 03:49 AM
