Laptop Sony Vaio shutdown every 30 minutes
  • fauzanmint
    • Jun 2018
    • 77
    • Indonesia
    ask for help. I am handling a Sony Vaio laptop mboard code FI2 core i5 hashwel with thoucscreen. the problem is the laptop turns off every 30 minutes (from pressing the button) again and again. standby or working together die on the 30th minute.
    I have tried
    - Flash bios with clean me
    - replaced capacitors 3/5VA, vcc-coore and vga-core
    -resoldering KBC and ICs
    -replaced Thermall sensor TMP709 for Processor and HDD
    -tried with less keyboard, power switch bord, and card
    -reinstall os
    -tried on win pe and stay on bios stay dead 30 minutes
    while running windows i have tried checking the Acin and all_pwrgd pin on kbc has 3.3V and 62.7mV on Peak to peak (normal)
    and not overheating
  • piernov
    • Jan 2016
    • 4435
    • France
    Re: Laptop Sony Vaio shutdown every 30 minutes
    How did you clean ME region? post your dump in BIOS request section and ask for a properly cleaned ME region.
    • peste
      • 12818
      • ROMANIA
      if the processor has been updated here is the problem.
      • fauzanmint
        • Jun 2018
        • 77
        • Indonesia
        the processor is onboard
        • fauzanmint
          • Jun 2018
          • 77
          • Indonesia
          thank you, I 've tried clean by MEInject tool
          • peste
            • 12818
            • ROMANIA
            then post the original bios in the bios section and someone will help you.
            • fauzanmint
              • Jun 2018
              • 77
              • Indonesia
              thank you, I 've flashed with file i got but the problem still same.I tried raplace KBC but unfortunetly still shutdown every 30min.
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                Does it shuts down in exact 30 mins every time??
                If turned on again, does it last for 30 mins or it shuts down a little earlier??
                Can you turn it on instantly after it turns off every time??
                • fauzanmint
                  • Jun 2018
                  • 77
                  • Indonesia
                  yes its axactly turn off every 30mins. if i turn it on its run well for 30mins again.
                  yes i can turn it on efter it turn off. every time.
                  the laptop is like has a timer
                  • fauzanmint
                    • Jun 2018
                    • 77
                    • Indonesia
                    its shutdown suddently like lossing ac connection. but i can turn it on again just by pressing power btn normally
                    • Abu Ali
                      • Aug 2019
                      • 15
                      • Denmark
                      Try taking the bare motherboard out of the laptop - nothing on the board other than the RAM.
                      Connect it only to charger and use external display.
                      Use linux mint live USB boot and leave it running and test.
                      • mcplslg123
                        • Jun 2015
                        • 7262
                        • india
                        Its wierd. All symptoms indicate towards ME-Region issue but you have already tried that. Schematic available for this unit?? It seems some kind of thermal trigger may be at play. Do you get any thermal message on bootscreen just after it has shutdown??
                        • piernov
                          • Jan 2016
                          • 4435
                          • France
                          I don't know if it can cause this kind of problem but maybe it's the ME disable strap.
                          • ravi_1617
                            YY Solutions
                            • Jan 2012
                            • 345
                            • India
                            Reball or replace PCH chip
                            • ravi_1617
                              YY Solutions
                              • Jan 2012
                              • 345
                              • India
                              I too seen exactly same problem In CQ42 .It ran for exactly 21 or 29 minutes.i too posted .
                              • kostas640
                                • Feb 2021
                                • Ελλάδα
                                Hello did you find a solution ? I have the same problem too ! VAIO SVE1511B1EB
                                • PACKETSTORM2
                                  • Jun 2016
                                  • 17
                                  • ALGERIA
                                  i did have this problem before with lenovo G580, fix it by flashing bios without clear me region
                                    Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
                                    This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                    09-06-2024, 05:27 AM
                                    Sony VAIO VGN-FZ31J FZ Specification for Upgrade or Repair
                                    This specification for the Sony VAIO VGN-FZ31J can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the VGN-FZ31J boardview and VGN-FZ31J schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony VAIO VGN-FZ31J...
                                    Sony VAIO SVT1122I4E Hybrid (2-in-1) Tap 11 Specification for Upgrade or Repair
                                    This specification for the Sony VAIO SVT1122I4E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVT1122I4E boardview and SVT1122I4E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                    Sony VAIO VPCM12M1E/W Netbook Specification for Upgrade or Repair
                                    This specification for the Sony VAIO VPCM12M1E/W Netbook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the VAIO VPCM12M1E/W boardview and VAIO VPCM12M1E/W schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                  • Carlos#2003%
                                    Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                                    by Carlos#2003%
                                    Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                                    02-15-2024, 07:52 PM
