gl702vm 6th gen for service - No Post
  • incorrect
    • Nov 2017
    • 22
    • Greece
    greetings all,
    i have a gl702vm 6th gen for service.
    the laptop turns off after 3-4 secs.it doesn't even post.
    i tried some bios dumps but the problem persists.
    the cpu insta overheat but the gpu stays cool.
    i think the laptop turns off because off the cpu insta overheat.
    1.06v on cpu is ok btw.
    any ideas are welcome
  • incorrect
    • Nov 2017
    • 22
    • Greece
    Re: gl702vm 6th gen for service - No Post
    my bad, 1.06v on coils
    • Weelcup
      TopTech
      • Oct 2017
      • 307
      I had similar board with similar issue. It has a 1060 6gb gpu isnt it?
      From my experiance, when the power supply was plugged, the CPU temp was jumping quickly to 80C then the board was cutting the power.
      On cpu rails there is no abnormal diod measures at all. All were just fine. And provide the voltage as it should.
      And because the gpu was cool. I suspected the PCH. And replaced it. But that did not solve the issue.
      So i decided Ok it might be the cpu. And i replaced the cpu with i5-8300H one, which was the only working one i have.
      Guess what, exactly same results. The cpu temp raising to 80C and shuts off.
      Unfortunately, i do not have a gtx1060 chip to test it.
      However, i suspect the gpu ram banks but not the gpu itself. Because when i provide 0.5v to gpu rails it consumes 0.1A and some consumes 0.3A so i believe the GPU os probably ok.
      In contrast, when i provide 0.6v to ram banks rail, it consumes 0.7A which in normal circumstances should only consume 0.1A.
      Now in my case, i did not have time to replace the ram banks. Mainly because if the Ram banks are some how shorted then it is very likely the the gpu chip is defected too.
      Very weired issue. But this was my experience with a similar board. And the chances might be very odd to exactly match your board issue although itvis exactly similar board.
      • incorrect
        • Nov 2017
        • 22
        • Greece
        yes,it is the one with the 1060 6gb gpu.
        thank you very much for the info you shared.
        i believe that if the problem begins from the vram block, the laptop should stay on while no voltage on vram block rails.no?
        i would probably cut the power on gpu rail and check if the laptop stays on.
        • jasko_jacker
          • Oct 2014
          • 1140
          • italy
          Check the pch, is a common issue on these boards
          • Weelcup
            TopTech
            • Oct 2017
            • 307
            No problem
            I will follow up to see your result..
              LCD LED TV Service Menu Codes
              TCL LED TV Service Menu Code
              LG LED TV Service Menu Code
              10-31-2024, 03:58 AM
              ASUS ROG GL702VM-BA131T Notebook Strix Specification for Upgrade or Repair
              This specification for the ASUS ROG GL702VM-BA131T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GL702VM-BA131T boardview and GL702VM-BA131T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
              09-06-2024, 07:29 AM
              ASUS ROG GL702VM-BA309T Notebook Strix Specification for Upgrade or Repair
              This specification for the ASUS ROG GL702VM-BA309T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GL702VM-BA309T boardview and GL702VM-BA309T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
              09-06-2024, 07:25 AM
              09-06-2024, 06:11 AM
              ASUS ROG GL702VM-DS74-HID4 Notebook Strix Specification for Upgrade or Repair
              This specification for the ASUS ROG GL702VM-DS74-HID4 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GL702VM-DS74-HID4 boardview and GL702VM-DS74-HID4 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
              09-06-2024, 06:08 AM
