acer extensa 5635z DA0ZR6MB6E0 REV:E no start
  • poweron
    • May 2019
    • 371
    • italy
    hello, pressing power on / off turns on both led power and power-on, turns the fan for two seconds, turns hd, but the screen remains black, after 5 sec everything turns off, then after another 5 sec it turns on again, everything as before with black screen, I tried to replace the ram but nothing changes, some advice
    I removed the battery but nothing changes, I checked the main voltages and they are all present, I also tried other CPUs but no results
    thank
  • lapfix
    • Mar 2020
    • 2764
    • my workshop
    Re: acer extensa 5635z DA0ZR6MB6E0 REV:E no start
    First make sure your problem NOT on LVDS cable or LED panel.
    Connect your mobo with external monitor and see if there is display.
    Use diode mode on multimeter to take the impedence on all the large inductors .After take some voltage mesurments and post all the results here .
    http://www.s-manuals.com/motherboard/quanta_zr6
    • poweron
      • May 2019
      • 371
      • italy
      ok
      • poweron
        • May 2019
        • 371
        • italy
        even connecting an external monitor remains black, I measured the voltages on the main inductors:
        PL4-PL6 = 0,97v
        PL9 = 1.07v
        PL8 = 1,52v
        PL12 = 5v
        PL13 = 3.3v
        I also measured with the diode tester between inductances and earth by inverting the test leads:
        PL6-PL4 = 50/29
        PL9 = 180/310
        PL8 = 180/310
        PL12 = 1500/148
        PL13 = 1100/148
        • lapfix
          • Mar 2020
          • 2764
          • my workshop
          all seems ok . let's take more measurements :
          U19 all pins .
          DDR3_DRAMRST pin 30 on DDR slot.
          RTC_RST : R544 and R566 both sides .
          U15 all pins.
          LVDS connetor : pin 1/2/3/4/5/11/12.
          Lid Switch HE1.
          PL10 : voltage and impedance
          • poweron
            • May 2019
            • 371
            • italy
            U19:
            pin:
            1=3,3v
            2=3,3v
            3=0
            4=3,3v
            5=3,3v
            U15:
            pin
            1=3,3v
            2=3,3v
            3=0
            4=3,3v
            5=3,3v
            lvds conn:
            pin
            1=18v
            2=18v
            3=0
            4=0
            5=3,3v
            11=0
            12=0
            lid switch he1:
            pin
            1=3,3v
            2=3,3v
            3=0
            rtc_rst:
            r544 = 3,2v/3,2v
            r566 = 3,2v/3,2v
            ddr slot pin30:
            ddr_dramrst = 0v
            • lapfix
              • Mar 2020
              • 2764
              • my workshop
              SO we have some missings volts !
              U1 pins 1/3/4/6 voltages
              ddr_dramrst must be 1.35v...did you try a good known DDR3 Ram .
              you don t answer me about PL10 : voltage and impedance
              • poweron
                • May 2019
                • 371
                • italy
                sorry for PL10, I didn't tell you it's not mounted,
                these are the tensions on U1
                pin 1 = 0
                pin 3 = 0
                pin 4 = 3.3v
                pin 5 = 3.3v
                apparently the LCD_VCC is missing
                • poweron
                  • May 2019
                  • 371
                  • italy
                  perhaps because the LCD_VCC_ON is not present
                  • lapfix
                    • Mar 2020
                    • 2764
                    • my workshop
                    U1 pin 3 test his impedance .
                    Volt R21/R24 both sides
                      • 21917
                      The ram is DDR3 1.5V
                      • poweron
                        • May 2019
                        • 371
                        • italy
                        pin 3 to gnd : 470/1080 reversing + and-
                        r21 not mounted
                        r24 0v-0v
                        I noticed that the rtc vcc is not there and by inserting the 3v battery it drops to 0.5v but from + to ground it is not short
                        • lapfix
                          • Mar 2020
                          • 2764
                          • my workshop
                          The enable signal from GMCH is missing : INT_LVDS_DIGON.
                          Don't forget when you take this voltage from LVDS connector the screen must be connect to the motherboard .
                          U34 all pins .
                          L18 and L39
                          • poweron
                            • May 2019
                            • 371
                            • italy
                            INT_LVDS_DIGON = 0V
                            U34:
                            pin 1 = 3.2v
                            pin 2 = 3.3v
                            pin 4 = 3.3v
                            pin 5 = 3.3v
                            L18 = 1.03v
                            L39 = 3.3v
                            • lapfix
                              • Mar 2020
                              • 2764
                              • my workshop
                              Forget to ask you about this voltages ! :
                              PQ13 / PQ33 / PQ38 / PQ14 / PQ15
                              • poweron
                                • May 2019
                                • 371
                                • italy
                                ok controllo
                                • poweron
                                  • May 2019
                                  • 371
                                  • italy
                                  PQ13:
                                  pin1-2-5-6=5v
                                  pin3=12,8v (in the schematic it's 15v)
                                  pin4=5v
                                  PQ33:
                                  pin123=5v
                                  pin4=12,8v
                                  pin5678=5v
                                  PQ38:
                                  pin123=3,3v
                                  pin4=12,8v
                                  pin5678=3,3v
                                  PQ14:
                                  pin1=3,3v
                                  pin2=12,8v
                                  pin3=3,3v
                                  PQ15:
                                  pin1=3,3v
                                  pin2=12,8v
                                  pin3=3,3v
                                  • poweron
                                    • May 2019
                                    • 371
                                    • italy
                                    we have taken note that the NB does not generate the DDR3_DRAMRST and INT_LVDS_DIGON signals, I wanted to ask if there may be any factor external to the NB that prevents generating those signals or generates them alone?
                                    • poweron
                                      • May 2019
                                      • 371
                                      • italy
                                      I found a similar but functional card, I measured the two voltages at pin 30 = 1.5v(DDR slot) and on the r24 = 3.3v, I also made the backup of the bios and it is different from the others that I also found on the site, I tried this bios on the other cards but the screen does not turn on, so the problem is on the NB or on something that does not allow to generate the two signals
                                      • mcplslg123
                                        • Jun 2015
                                        • 7262
                                        • india
                                        What is the resistance and voltage on PIN 1 of DDR Ram Slot??
                                          ACER Extensa Extensa E264 Extensa E2200 Specification for Upgrade or Repair
                                          This specification for the ACER Extensa Extensa E264 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Extensa Extensa E264 boardview and Extensa Extensa E264 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-12-2024, 03:36 PM
                                          ACER Extensa M2710 Extensa M2 i3-6100 Specification for Upgrade or Repair
                                          This specification for the ACER Extensa M2710 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Extensa M2710 boardview and Extensa M2710 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for ACER...
                                          09-12-2024, 03:30 PM
                                          ACER Extensa M2710 Extensa M2 i5-6400 Specification for Upgrade or Repair
