ACER e5-473g a second goes off
  • String2016
    • Nov 2015
    • 2238
    • philippines
    I have this acer e5-473g A4WAB LA-C341P laptop., the first problem is dead laptop but 19v present on 19v power rail and 3v and 5v alw present on each coil, no i flashed the bios I got here in this forum now when i plugged in orange light present pressing the power button turns on the 1 second goes off,I noticed there is no RSMRST# on pin100 of the kbc no voltage, notice also there is s5, s3 on pin7 and pin8 and no PGOOD on pin10,on pin9 it has only 17v supposed to be 19v of PU501 based on schematics.and also noticed that on pin 27 on the keyboard connector when i plugged the charger alw3.3v is present, but after pressing power button turns on and goes off 3.3v missing on pin27 JKB1 connector. anyone please help
  • String2016
    • Nov 2015
    • 2238
    • philippines
    Re: ACER e5-473g a second goes off
    anyone can help on this please
    • kalilinux25
      • Mar 2018
      • 2093
      • ZAMBOANGA SIBUGAY
      same problem waiting for repsonse here
      • lapfix
        • Mar 2020
        • 2765
        • my workshop
        Better to start from the beginning .
        1- Is there any liquid spill or corrosion observed.
        2- With diode mode test all coils sarching for short and post all the results.
        3- Post your old dump .
        4 -PQ 302/303 Drain , source and gate voltages.
        5- U28 basic requirements
        • kalilinux25
          • Mar 2018
          • 2093
          • ZAMBOANGA SIBUGAY
          is it normal that the board will start but it vey hot? from the heatsink, maybe beacause my board is turning off bcause of the heat?
          • lapfix
            • Mar 2020
            • 2765
            • my workshop
            No it s not normal...try first to search if there s any short to ground,with diode mode post all the result taken from all the coils
            • Sametbey
              • Jan 2021
              • 229
              • Turkey
              Have you tried the bios program. You can check for short circuit on USB data pins. There are not many options other than audio and ethernet chips. the processor may be problematic.
              I'm not happy to be so strong. because it's not humanly
              • DanielDacko
                • Mar 2015
                • 328
                • Macedonia
                I built this file for you, try it and report back for any changes.
                https://www.badcaps.net/forum/showthread.php?p=1046033
                I don't provide help for people using CH341A and a clip.
                • kalilinux25
                  • Mar 2018
                  • 2093
                  • ZAMBOANGA SIBUGAY
                  I tired also sir No chance maybe the cpu processor is faulyt
                  • akorede
                    ENGINEER
                    • Nov 2020
                    • 16
                    • nigeria
                    Any solution on this Acer board???
