Hello
A laptop with the following specifications:
hp pavilion g6-2030se
da0r33mb6e0 rev: e
The device did not turn on before. After troubleshooting, a number of capacitors and a resistor and Icy BQ738 were damaged. After replacing them, the system turned on and there was no problem.
About 20 to 30 minutes after working with the laptop, the system suddenly shuts down without any symptoms.
I checked the circuit again. There were no problems with the inside of the circuit. After 5 minutes, I connected the charger.
The CPU was replaced. The silicone paste was replaced. The temperature is normal. But after a few minutes the system shuts down!
Both BIOS were replaced and the program.
The system turns on again for a few minutes after each shutdown! But then it goes off again after 20 30 minutes.
The 90-watt 120-watt charger was also tested.
VCORE voltage
1.05 V
1.4 V
Three burnt pieces:
pr119
pc217
bq738
da0r33mb6e0 rev: e
VCORE voltage
1.05 V
1.4 V
Three burnt pieces:
pr119
pc217
bq738
