Laptop keeps randomly powering off
  • hp15ab
    • May 2020
    • India
    Hey there!
    I have an HP 15 ab584tx. It was working totally fine until last week. Now, it doesn't turn on for more than a couple of minutes, sometimes less than a minute. It turns on and then, immediately turns off fully. All components turn off, even the power input port light goes off for a second, before coming back on. Sometimes it even makes it as far as the windows desktop screen and works fine for a minute or two, before randomly turning off again. It also sometimes gives me an overheating warning on boot(but doesn't really overheat, more info below).
    Here's what I've tried so far:
    Removing the battery, draining any static power and plugging in the AC cord.
    Opening it up and cleaning it fully, repasting the CPU and GPU.
    Systematically removing each component and testing(each RAM module in alternating slots, HDD, CMOS battery, DVD drive, display unit,WiFi card) without them, one by one.
    Entering the BIOS and letting it idle. (goes off after a couple of minutes here too)
    Checking the temps and fan air flow. (normal)
    Checked each cable for loose connection.
    Booting from a Live linux pen-drive.
    Everything I've tried yields the same result: the laptop turning off after a couple of minutes. I checked the temps via HWMonitor, which I managed to somehow install before it shut off, it was around 45-60 degrees overall, nothing concerning. During another boot I managed to install CPUZ and check the hardware displayed and everything looked perfectly fine(showed both the iGPU and Nvidia GPU and all 16GB of RAM)There was no physical damage to the laptop either.
    When plugged in, it displays an orange light and a white light on the charger port for when the battery is inserted and when the battery is removed, respectively. For the brief moments that it stays alive, it does indicate charging/discharging etc. The charger light stays on. The only time it goes off is when it suddenly dies. At that moment, it goes off for a second before coming back on. I have not checked the voltage of the charger because I don't have an multi-meter. I tried flexing the cord at all points, but there is no disturbance in the output due to it whatsoever. HP also has a diagnostic test menu, and it passed the AC Adapter component test.
    I'm really lost as to what exactly is wrong with it. Since I'm in a high risk COVID zone, I can't go to any service centers for a long time. Any help/input is greatly appreciated!
  • qayyum786
    • Aug 2018
    • 1933
    • INDIA
    Re: Laptop keeps randomly powering off
    1) clean ME REGION
    2) CHECK THERMAL SECTION THROUGHLY
    ( CAPS & RASISTOR VALUE )
    • hp15ab
      • May 2020
      • India
      Originally posted by qayyum786
      1) clean ME REGION
      thanks, I dont have a multimeter right now, but I'll try to get on it asap
      • motormayhem
        Lenovo T460 Only Charges on One Charger
        by motormayhem
        Laptop Question
        I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
        A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
        05-12-2023, 01:46 PM
      • serious_electron
        Strange! Acer laptop not powering on but charging the battery (orange light on when charger and battery plugged in).
        by serious_electron
        Hello Everyone!
        I have an Acer Aspire A315-42 laptop. I generally leave it on for long time by closing down its lid (so it enters the sleep mode). Recently, it rained quite heavily in out area. And the humidity and moisture seem to be high. So one late evening, after I opened the lid and turned on the laptop, it did power on as the blue light turned on but after it booted to the desktop screen, just 5-10 seconds after both the screen and blue light went out and laptop shut down (the blue power light turned orange). And after 2-4 seconds that orange light went off and the laptop died.
        06-28-2025, 02:57 PM
        NVDC charger configuration...
        11-05-2024, 03:28 PM
      • flat-earther
        how to prevent a connected charger from draining battery when not charging?
        by flat-earther
        I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
        So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
        but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
        So the battery is backfeeding the charger and being drained.
        How can I prevent...
        08-07-2025, 01:04 PM
      • flat-earther
        ASUS X54H laptop thinks it's always charging even with charger unplugged
        by flat-earther
        The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
        Windows also shows ''Plugged in'' when charger is not connected.
        This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
        Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
        If I let battery run out and say it has 3% Windows will...
        06-24-2025, 09:32 AM
