820-3435 No power / light
  • lebronballer
    • Apr 2020
    • 10
    Mac Air had a few drops of water spilled on keyboard. I opened it and saw slight corrosion on U7090. So far only cleaned it with a brush and alcohol.
    Measuring voltages Here's what i'm seeing:
    PPDCIN_G3H is giving me 15v (though it cycles between 14.9 to 15.0)
    I also get 15v at the magport and dcin on the board, and also at PP18V5_DCIN_ISOL_R.
    I thought those were supposed to be 18.5V?
    Also, on PPBUS_G3H i only get 3mV @ R7006 which i think should be 8.6V?
    Any ideas where to check next? I'm a beginner, so appreciate all the help.
  • piernov
    • Jan 2016
    • 4439
    • France
    Re: 820-3435 No power / light
    Magsafe2 45W sends out 14.85V as written on the brick.
    Check voltage and resistance to ground on L7095.
    Check resistance to ground and voltage on both sides of F7140.
    • lebronballer
      • Apr 2020
      • 10
      Thanks.
      On L7095- 0.1mV on both sides, 82.5kohm both sides.
      On F7140- I get OL on both sides resistance to ground. And voltage with MagSafe plugged in was 0.7V and continuously dropping.
      I also have 14.9v on c7090 /c7091 pin 1.
      Does this suggest it's just u7090 that's either bad or not making a connection (must stilll have corrosion)?
      • piernov
        • Jan 2016
        • 4439
        • France
        Confirm that pin 6 and pin 8 of U7090 get 14V. Only then you can suspect something wrong with it.
        • lebronballer
          • Apr 2020
          • 10
          Either i cant get the multimeter probes on pin 6/8 or they arent getting a reading, but i do measure 14.9v on both the test points leading to pin 6 and 8 right next to them (P3V42G3H_SHDN_L & PPVIN_G3H_P3V42G3H).
          Do you think first try to heat it up to pull it off and clean then put it back, then replace it if that doesn't work?
          • MobileXT
            • Oct 2012
            • 214
            Do you have a PP3v42_G3H?
            • lebronballer
              • Apr 2020
              • 10
              Nope, nothing coming out of U7090. I measured PP3v42_G3H at L7095 and got nothing (0.1mV).
              • MobileXT
                • Oct 2012
                • 214
                You need to fix your PP3V42_G3h first.
                • MobileXT
                  • Oct 2012
                  • 214
                  Also check for shorted on that power rail. IF you don't have shorted then you can replace U7090
                  • lebronballer
                    • Apr 2020
                    • 10
                    Isn't that originating at U7090? Since i have both the PPVIN_G3H_P3V42G3H & P3V42G3H_SHDN_L coming to the testpoints before pins 6 & 8 there?
                    • MobileXT
                      • Oct 2012
                      • 214
                      Sorry Check first R7006 and R7005
                      • MobileXT
                        • Oct 2012
                        • 214
                        If you have 14.75V at Pin 6 U7090 replace U7090
                        • lebronballer
                          • Apr 2020
                          • 10
                          So i measure 14.9V at the testpoint next to pin 6 U7090. Pin 6 is the one that had corrosion on U7090 and i either dont get a reading on the actual chip, or i cant get the probe right on it so i was using the test point in the image attached.
                          i have 14.9-15v at R7005. I have ~0.7V at R7006 and it keeps dropping over time (maybe to 0, down to 0.4v now).
                          • MobileXT
                            • Oct 2012
                            • 214
                            Your U7090 is dead you need to replace the chip
                            • MobileXT
                              • Oct 2012
                              • 214
                              Check the resistance should be 10 ohms
                              • MobileXT
                                • Oct 2012
                                • 214
                                Put your multimeter at Diode Mode and Red on ground and Black at Pin 6 U7090 or PIN 1 at C7091 check if you have shorted.
                                • lebronballer
                                  • Apr 2020
                                  • 10
                                  Resistance on the resistors look right.
                                  Pin 1 at c7091 in diode mode shows 0.343v. Can't get a reading on the corroded pin 6 of u7090. Guessing that connection is messed up even after I've cleaned it with alcohol.
                                  Do you have to use hot air to do the replacement or can you use a soldering iron for this?
                                  • piernov
                                    • Jan 2016
                                    • 4439
                                    • France
                                    If the probe point, the track or the pad is corroded and broken, replacing the chip won't solve the problem. The problem would be rather solved by running jumper wires where necessary.
                                    You need a hot air station to replace the chip, as well as a microscope to be able to work on those tiny components and traces and assess the damage, and fine multimeter probes. It sounds like you are lacking the proper equipment to perform Macbook logic board repair.
                                    @MobileXT : please read the thread fully and try to understand where the problem lies with the information already given by the original poster before giving misleading advice.
                                    • lebronballer
                                      • Apr 2020
                                      • 10
                                      Thanks piernov!
                                      Yep, i don't have that equipment yet. Though I enjoy DIY and fixing things and would like to have them for any future repairs so i'll probably get them and try it out.
                                        Lithonia Lighting versus Light of America Compact Fluorescent product quality
                                        by sam_sam_sam
                                        I have a Lithonia Lighting 65-Watt Gray Hardwired Compact Fluorescent
                                        I also have back when Light of America had these light bulbs available for yard lights
                                        The issue with Light of America was the blast boards had all most certain board failure while bulbs hardly ever fail
                                        While the Lithonia lighting fixture has all most certain bulb failure
                                        So I have modified the Lithonia lighting fixture to accept the Light of America light bulb and see how long this will last
                                        I have only had this light fixture for not more than a year if it...
                                        07-02-2023, 03:45 PM
                                        LG Gram Ultra-light Weight Notebook Specification for Upgrade or Repair
                                        This specification for the LG Gram Ultra-light Weight Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-light Weight boardview and Ultra-light Weight schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                        09-07-2024, 03:40 AM
                                        LG Gram Ultra-Light Laptop Notebook Specification for Upgrade or Repair
                                        This specification for the LG Gram Ultra-Light Laptop Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-Light Laptop boardview and Ultra-Light Laptop schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                        09-06-2024, 09:10 PM
                                        09-06-2024, 08:40 PM
                                      • serious_electron
                                        Strange! Acer laptop not powering on but charging the battery (orange light on when charger and battery plugged in).
                                        by serious_electron
                                        Hello Everyone!
                                        I have an Acer Aspire A315-42 laptop. I generally leave it on for long time by closing down its lid (so it enters the sleep mode). Recently, it rained quite heavily in out area. And the humidity and moisture seem to be high. So one late evening, after I opened the lid and turned on the laptop, it did power on as the blue light turned on but after it booted to the desktop screen, just 5-10 seconds after both the screen and blue light went out and laptop shut down (the blue power light turned orange). And after 2-4 seconds that orange light went off and the laptop died.
                                        06-28-2025, 02:57 PM
