Acer V5-132p RAM problem. Please help me.
  • erneszto
    • Feb 2020
    • 14
    • Budapest
    Hello all!
    I would like to ask very big help.
    Briefly the story: my girlfrend swap this laptop motherboard and i buy a new one, but when I changed it, when I turn on without RAM only restarting again and again and the screen is blank. But when I place the RAM the laptop is working properly but I cant install any OS!
    I tried a lot of solution what I found on web, but nothing worked.
    What I know at this time:
    I tried different type of RAMs but the laptop is working with only one. With the others it only restrating loop.
    With this the screen turn on, have bios, see usb slots and it seems everything work properly. But don't install OS.
    The BIOS see all RAM but the memtest and memtest86 freeze the laptop and only see wrong all RAM.
    The laptop booting up only mini-xp with HIRENS boot cd in USB stick.
    In the Mini-xp have gpu-z and this wont recognize any information the GPU. But the screen working properly and the resulation changing working too soo I know the gpu working properly. Or Im wrong
    The motherboard Winstron Angel CY MB 48.4lj02
    Thanks to everyone who will ansver it.
  • erneszto
    • Feb 2020
    • 14
    • Budapest
    Re: Acer V5-132p RAM problem. Please help me.
    Schematic:
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3627
      • slovakia
      what u mean cant install os? what os?
      • erneszto
        • Feb 2020
        • 14
        • Budapest
        Hi.
        Windows or Linux or have me factory backup but wont begin istallation only restart win logo.
        • erneszto
          • Feb 2020
          • 14
          • Budapest
          My motherboard:
          • erneszto
            • Feb 2020
            • 14
            • Budapest
            When restarting appear this screen:
              • 21899
              Look at the RAM socket pins, clean up corrosion,crud with liquid flux or ipa alcohol ,try to move the pins and if any move they will need resoldering.
              • ktmmotocross
                Boardkiller
                • Feb 2014
                • 3627
                • slovakia
                did u try another harddisc?
                • erneszto
                  • Feb 2020
                  • 14
                  • Budapest
                  Hi.
                  Thanks Youre ideas.
                  SMDFlea I thought abaut this but I didnt know which liquid is good to use. I will try. Thanks.
                  Ktmmotocross I tried but is The same issu.
                  • erneszto
                    • Feb 2020
                    • 14
                    • Budapest
                    Hi.
                    I tried to clean the sockett and pins but wont changed anithyng.
                    Its seems all PIN soldered. Motherboard with soldered ram with power and power button only restarting blue led blink.
                    Have any idea?
                    Thanks to all.
                    • ktmmotocross
                      Boardkiller
                      • Feb 2014
                      • 3627
                      • slovakia
                      soldered rams was source of many problems. try to reflow it or find how to disable it
                      • erneszto
                        • Feb 2020
                        • 14
                        • Budapest
                        Hi.
                        Thank Your answer.
                        I tried to reflow The RAMs but wont have any changes.
                        But I fund differences between The two motherboards.
                        If You have any ideas why The older one have The two capacitor but The new one dont have?
                        • sicilianul
                          • Jul 2014
                          • 70
                          • Romania
                          Have you tried with another memory?
                          Crucial memories are known for multiple problems
                          • erneszto
                            • Feb 2020
                            • 14
                            • Budapest
                            Hi.
                            Thank Youre reply.
                            Yes I tried lot of Ram but its the same.
                            • erneszto
                              • Feb 2020
                              • 14
                              • Budapest
                              Anyone have idea how to disable soldered Ram? Or unlock advanced bios setting? The bios have this but wont have Advanced tab.
                              • kiraro
                                • Jan 2016
                                • 177
                                • North NY
                                For activate advanced menu try this:
                                1-Enter BIOS.
                                2-Press Fn + Tab. Save and exit.
                                3-Retry enter bios. Unlock Advanced and power menu done.
                                • erneszto
                                  • Feb 2020
                                  • 14
                                  • Budapest
                                  Hi.
                                  Thanks Your answer but this wont working for this fucking bios.
                                  • ktmmotocross
                                    Boardkiller
                                    • Feb 2014
                                    • 3627
                                    • slovakia
                                    im sure that internalrams is problem, but in schem dont find a way how to disable it. try to search for solution or u can find another modules pointing in schem and replace
                                    • kiraro
                                      • Jan 2016
                                      • 177
                                      • North NY
                                      hi, In page 20 of the schematic there is a table of preconfigured internal memory installed , there are three types of memory accepted (in your motherboard it's a second line of the table- you can check with resistors positions also check there resistance values may be one of them faulty ),so if we give an outbox combination the motherboard will not be able to recognize the memory installed ( I think that) no capacity no type , in this case logically the mobo will switch automatically to the dim2 as a principal , and will work only with this one , finally it’s a suggestion, maybe I was wrong, but give it a try...
                                      • erneszto
                                        • Feb 2020
                                        • 14
                                        • Budapest
                                        Hi.
                                        Thanks Your answer.
                                        So lets be clear, I nead to remove this resistors and The mobo wont recognize the soldered Ram?
                                        Im checked the resistance value I get The picture.
                                        • mkdj
                                          Acer Swift won't boot after a Linux install
                                          by mkdj
                                          Dear all,
                                          I have an issue with an Acer Swift laptop which won't boot (Acer Swift SF113-31-C7UK)
                                          History and symptoms:
                                          A friend of mine tried to install Linux on this laptop. After the installation, the PC did not reboot. When pressing the power button, backlight is working, capslock is working. But screen stays black.
                                          What I have done so far:
                                          As I suspected a BIOS issue, I tried to clean the TXE region, following the winraid guide for CSE TXE 3.1. I managed to do all the steps, including the steps involving the signing process with OpenSSH. The...
                                          Today, 04:31 AM
                                          09-06-2024, 05:27 AM
                                          Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook 3 Specification for Upgrade or Repair
                                          This specification for the Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Swift 3 Ultraschlankes Notebook boardview and Acer Swift 3 Ultraschlankes Notebook schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                          09-07-2024, 05:00 AM
                                          Acer Aspire Acer Aspire 7 Charcoal Black Notebook 7 Specification for Upgrade or Repair
                                          This specification for the Acer Aspire Acer Aspire 7 Charcoal Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 7 Charcoal Black boardview and Acer Aspire 7 Charcoal Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                          Acer Nitro Acer Nitro 5 Black Notebook 5 Specification for Upgrade or Repair
                                          This specification for the Acer Nitro Acer Nitro 5 Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Nitro 5 Black boardview and Acer Nitro 5 Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-07-2024, 04:10 AM
