toshiba c55-b861 no screen
  • nabilgo
    • May 2016
    • 303
    • L.A
    hi freinds
    this toshiba laptop when i turn it on it turn on evrything is okay but i gotl black screnn and when i plug the vga cable he show data perfectly and i noticed something the screnn become black when u press the power boutoon i flashed new bios but still same probleme ?????????????
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: toshiba c55-b861 no screen
    What is the mb code?? We need to see if schematic is available or not. LVDS pins need to be measured for voltage.
    • nabilgo
      • May 2016
      • 303
      • L.A
      what is the mb code?? We need to see if schematic is available or not. Lvds pins need to be measured for voltage.
      da0bljm6c0 rev c model blj
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        I dont have that schematic and i'm not sure whether its available. Please tell us how many pins are there on lvds/edp connector-30 or 40 pins?? Is the cpu soldered on mb??
        • nabilgo
          • May 2016
          • 303
          • L.A
          40 pin and the cpu is solder to the motherborad
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            Refer to quanta BDBE circuit-it has 40 pin edp. measure voltage on PIN 1-2/4-5/6/7-8/11/12.You dont have image+backlit on internal screen??
            • nabilgo
              • May 2016
              • 303
              • L.A
              no image but when u turn on pc u can see the screen becoming black
              • nabilgo
                • May 2016
                • 303
                • L.A
                i hope u can givge me some advise
                  VIP Moderator
                  • Aug 2018
                  • 4386
                  • Bulgaria 🇧🇬
                  He gave you advice, did you measure voltage on PIN 1-2/4-5/6/7-8/11/12?
                  Become a Badcaps supporter
                  Thanks to all supporters.​
                  • mcplslg123
                    • Jun 2015
                    • 7262
                    • india
                    @nabiglo, Vesko said it all. Its useless to sit on bunch of advise without actually working on it. Remember, mb is physically in front of your eyes and not mine. With the given clues, you could have surely narrowed down the problem if not solving it.
                    • Ryan.man
                      by Ryan.man
                      02-04-2025, 12:23 PM
                      09-06-2024, 05:27 AM
                    • sigmeyer
                      Toshiba 50UL4B63DG faulty screen?
                      by sigmeyer
                      I got this 50 inch tv the screen starts off with almost nothing visible but the top part of it , and it would slowly kick in and the picture would be visible , but then over time it would go greyish with the top of it mostly intact. I did have instance where the screen would be fucked like that and i would touch the cpu and memory to see if it would react and a couple times it would screech on the speakers and restart. After that it would show a better picture somewhat but afterwards i touch the cpu and not much is achieved. Im wondering is this a screen fault or should i pursue this with a donor...
                      08-30-2025, 08:13 AM
                    • reformatt
                      by reformatt
                      07-31-2025, 08:37 PM
                      09-06-2024, 05:59 AM
