Acer e5-511 with black screen.
  • asem18
    • Oct 2016
    • 112
    • my workshop
    Hello folks.
    acer e5-511 ( la-b211p ) black screen , i have picture on external monitor .
    changed ram same issue..flashing bios too..i change display cable and display same issue .
    all the voltage are ok ..
    PL402 =+3VALWP = 3v
    PL404 = +5VALPW = 5v
    PL502 = VP = 1.3v
    PL802= CPU soc vnn = 0.7v
    PL803 = CPU soc vcc = 0.8v
    PL602 = +1.0VALWP = 1.0 v
    PL302 = BATT+= 3v
    Pin 8 bios = 1.8v
    PLTRST = 3.3v
    DRAMRST = 1.385v
    VTT = 0.690v
    JLVDS conncetor :
    1.23 = 19v
    6 = INVT_PWM_SOC = 0.013v ( t think this is my pb ! )
    7 = EC_BKOFF# = 0.029v
    9.10 = +LCDVDD = 3.3v
    11 = TS_EN_1 = 3.3v
    U64 :
    Pin 2 = DDI1_PWM = 0v
    Pin 4 = INVT_PWM_SOC = 0v
    Pin 5 = +1.8VS
    What should i check too !!
  • piernov
    • Jan 2016
    • 4439
    • France
    Re: Acer e5-511 with black screen.
    Image on internal display? Lid switch working?
    • asem18
      • Oct 2016
      • 112
      • my workshop
      Thank you Piernov for your help.
      as i say before : black screen ...but on external yes ther's picture
      lid switch on power button is OK
      • Techtiger
        • Oct 2014
        • 1602
        • france
        Test ENBKL U61 , ENVDD & PWM single comes from SOC 1.8V
        • asem18
          • Oct 2016
          • 112
          • my workshop
          Thank you techtiger , U61 didn't exist on this mobo...only U62 and U64
          • piernov
            • Jan 2016
            • 4439
            • France
            Image and backlight are not the same thing, you could have image but no backlight, or no image and no backlight at all (in this case the problem is less likely to be in the backlight circuit).
            • asem18
              • Oct 2016
              • 112
              • my workshop
              i know piernov , but here i don t have no backlight . no image...it looks like i haven t screen...nothing happen on it...no dim picture too
                • 21874
                RP45 ? 100K Ohm
                • asem18
                  • Oct 2016
                  • 112
                  • my workshop
                  Thank you SMDflea , no it's 40 kohm.
                    • 21874
                    It should be 100K.Repalce it if you have one on a donor board.
                    • asem18
                      • Oct 2016
                      • 112
                      • my workshop
                      Change Pr45 , but still same issue .
                      taken other measurment on jvlds :
                      6 = INVT_PWM_SOC = 13.2mv
                      7 = EC_BKOFF# = 24.7mv
                      8 = EDP_HPD_CONN = 4mv ( must be 2.5v !)
                      • Techtiger
                        • Oct 2014
                        • 1602
                        • france
                        Check LVDS SDA SCL after check the resistance to GND and the voltage LVDS 31 32 28 29 25 26 and U64 pin 2 4 resistance to GND
                        • asem18
                          • Oct 2016
                          • 112
                          • my workshop
                          Thank you techtiger for your help.
                          U64 resistance to ground on diode mode :
                          PIN 2 = 0.542v
                          Pin 4 = 0.577v
                          LVDS :
                          Pin 25 = Changing from 0.600v to 0.800v
                          Pin 26 = 0.900v and increase
                          Pin 28 = 0.476v
                          Pin 29 = 0.400v and increase
                          Pin 31 = 0.640v and increase
                          Pin 32 = 0499v and increase
                          Pin 21 = SDA = 2.2mv ...Diode mode = 0.030v ( it bips)
                          Pin 22 = SCL = 0.45mv....Diode mode = 0.387v.
                          • Techtiger
                            • Oct 2014
                            • 1602
                            • france
                            PIN 2 = 0.542v
                            Pin 4 = 0.577v
                            LVDS :
                            Pin 28 = 0.476v
                            SDA 0.030 Ohms data line this Signal comes from SOC page9 1.8VS
                            • asem18
                              • Oct 2016
                              • 112
                              • my workshop
                              yes techtiger..i trace his line..SDA_PNL come from Q80 pin 3 that don't exsit on mobo .
                              Q80 :
                              Pin 1 = 1.8v
                              Pin 2 = 1.8v
                              Pin 3 = 5.8mv
                              Pin 4 = 1.8V
                              Pin 5 = 1.8v
                              Pin 6 = 40mv
