asus k43s laptop no 3v and 5v
  • String2016
    • Nov 2015
    • 2238
    • philippines
    I have a asus k43sv rev 3.0, when plugged in the charger 19v rail is present but there is no 3v and 5v on coil, i noticed that RT8206A chip is getting very hot.anyone can help on this please
    • 21880
    Re: asus k43s laptop no 3v and 5v
    Whats your usual plan for dealing with a hot IC like this ? Measure voltage and resistance to GND.
    • String2016
      • Nov 2015
      • 2238
      • philippines
      replaced ic?
      • Techtiger
        • Oct 2014
        • 1602
        • france
        Originally posted by Mulong2019
        replaced ic?
        Check the resistance ( SMDflea ) check all the caps connected to pin
          • 21880
          I was asking @mulong2019 ,i forgot to quote his post in my reply.
          • String2016
            • Nov 2015
            • 2238
            • philippines
            I have attached the photo of caps around the ic the two caps on the left measured 0.00kohms and on the right cap shows OL .
            • String2016
              • Nov 2015
              • 2238
              • philippines
              any help
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                datasheet is available for RT8206A. You need to measure voltage on certain pins like VIN/LDO/EN1/EN2/ENLDO/VOUT/PGOOD. Measure resistance on suspect pins.Usually replacing a hot ic wont solve the issue. The IC is getting hot as some voltage rail is shorted. You need to findout which is the culprit rail. Else, it"ll be sheer wastage of time. Succesful repair can be carried out only if you have a clear & well understood strategy.
                • String2016
                  • Nov 2015
                  • 2238
                  • philippines
                  here is measurement of the RT8206a
                  PIN6 VIN=19V
                  PIN7 LDO=0.27V
                  PIN4 ENLDO=6.27V
                  PIN 14 EN1=0V
                  PIN 27 EN2=0V
                  PIN10 VOUT=0V
                  PIN13 PGOOD1=0V
                  PIN28 PGOOD2=0V
                  does this ic is bad?
                  • Conste
                    • Oct 2018
                    • 235
                    IC is probably not bad, but one of the outputs is shorted
                    Could be Super I/O, had this before
                    • String2016
                      • Nov 2015
                      • 2238
                      • philippines
                      but why is the ic is burning hot? i check the caps connected to the ic no short
                      • mcplslg123
                        • Jun 2015
                        • 7262
                        • india
                        Check +3V EC is shorted or not. What is the resistance on Vout pin??
                        • TiteLive
                          • Jun 2021
                          • FRANCE
                          I have also an issue with a RT8206A device on an ASUS U36SD motherboard:
                            • 21880
                            Its a different model, so its off-topic. Start your own thread please .
