What is this SMD component?
  • 73buick
    • Mar 2011
    • 41
    Does anyone know what the SMD CL2 is in this pic? It looks like a fuse, but not sure. Can't find anything on what CL stands for. It is currently reading at 0 ohms and has no continuity.
    Just fixed this laptop for a client and it worked for a few days and now won't power up. Getting 19V out of the DC jack harness, but only 1V on the battery charge pins. Just trying to narrow down what it could be and came across this CL2 piece which I thought was a possible fuse.
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: What is this SMD component?
    It seems like a filtering Cap not fuse.
    • R_J
      • 9535
      If you can provide, the make, model, or board number, there might be a schematic or other information around.
      • 73buick
        • Mar 2011
        • 41
        Its for a HP 15-DB0011DX
        HP Motherboard part#L20478-601
        PCB# EPV51 LA-G078P, Rev. 1.0
          • 20649
          There`s no schematic available. The part next to it is TSL1 ,if you google "Compal TSL1" for schematics with the same part number you can sometimes find what you`re looking for.
          It could be a 10 pF, 3 kV, 1808 capacitor, i only looked at an la-a994p schematic,i could be completely wrong.
          • R_J
            • 9535
            I would tend to agree it is a capacitor so It won't be the problem
            • dreamflowers09
              • Feb 2012
              • 31
              Anyone having schematics?
              • corrize
                A funny fuse story – Lumix LX100 II
                by corrize
                Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
                I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
                The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
                There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
                And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
                10-19-2023, 09:58 AM
              • jesterace
                Samsung UE46ES8000 Blown fuse but no other signs of short
                by jesterace
                Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
                09-11-2024, 03:14 PM
              • jshhh
                Help replacing fuse on my Mimaki CJV300-160 vinyl printer
                by jshhh
                Hi guys,
                I'm inexperienced with electronics repairs, I've done a little bit of soldering caps and whatnot, but i have a blown fuse on this mimaki printer I got which I have bought a replacement for.
                How do I remove this type of fuse (see picture)...it kinda looks like it would pull out of that bracket but it didn't come at first pull and I didn't want to brute force it incase it's soldered on there like most of the rest of the components.
                Anybody know how to remove this type of fuse?
                (The fuse is toward the bottom of the image labeled F2)...
                06-17-2025, 01:35 AM
              • Babbar
                by Babbar
                04-12-2024, 01:12 AM
              • drykid
                Matsui 175S microwave fuse replacement
                by drykid
                I recently picked up a used Matsui 175S microwave that was powering up (starts, turntable rotates) but not heating. From looking online the most likely culprit was the fuse, but unfortunately in this one the fuse had heated up and fused with the (badly designed) fuse holder and couldn't be removed. I guess this might indicate further issues beyond the fuse itself but at this stage I just want to replace the fuse and see how I go from there.
                Anyway since I couldn't get out the fuse itself the easiest fix was to replace the fuse holder assembly that runs between the...
                12-21-2020, 01:15 PM
