White blinking led on DC jack. Does not start [ HP Probook 440 G1]
  • IamPritesh
    • Aug 2017
    • 356
    • India
    So I had this model on my desk which was short on 19volt. A couple of capacitors where short which was removed and now the board has 3.3 and 19v.
    Now upon plugging in the adapter I get a White blinking led on DC jack and constant white led on the power button. Nothing happens when I press the power button. I do have 3.3 volt on the power power and I also have 3.3volt on the rsmtrst signal on SIO chip.
    I have tried various Bios bin files found on the internet and all of them show the same result.
    I am short of ideas on how to proceed..
    Original Bios and Schematic attached.
  • Conste
    • Oct 2018
    • 235
    Re: White blinking led on DC jack. Does not start [ HP Probook 440 G1]
    Did you try original HP AC adapter?
    • jasko_jacker
      • Oct 2014
      • 1137
      • italy
      Other to use originale ADP investigate the section with bad capacitor to check other issue.
      Check also the EC and pch
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        Likely to be kbc fault.
        • IamPritesh
          • Aug 2017
          • 356
          • India
          Yes I have used the original adapter. What pins do we check to narrow down the problem to a particular section my friends.
          • akorede
            ENGINEER
            • Nov 2020
            • 16
            • nigeria
            any solution to this
            i have an issue on my hp 440 g1 not charging battery
            • Stevedb
              Stevedb
              • Feb 2018
              • 624
              • Belgium
              Did you try with known good battery, 99 % of battery issues are the battery itself.
              • jajo17
                HP Probook 470 G2 - white blinking - ADP_SIGNAL ?
                by jajo17
                Hello, I have this laptop with a bad motherboard. The LED in the socket is blinking white, endless loop. According to the information I found on the internet, this can be caused by several reasons that I am currently investigating.
                1. Damaged BIOS chip - it seems to be fine, CH341a programmer can read it
                2. BIOS RTC voltage shorted to ground - it seems to be fine, around 3V
                3. Damaged adapter identification circuit - I think there is a problem here, but please help explain the function
                What should be the voltage on ADP_SIGNAL when using a 65W HP adapter? My calculation of the voltage divider comes...
                02-28-2025, 05:18 AM
              • ahmarzo
                Hp 15-cs laptop 5 times dc jack blinking white
                by ahmarzo
                I have two laptop hp15- cs1000tx with motherboard part no DAG7BDMB8F0 REV F
                First one was not powering on when battery is connected the first n channel MOSFET was short and after changing the laptop started on power and battery and charging fine
                Second laptop has water damaged on ram ic after cleaning and changing the ic the laptop is working fine now
                But now I have power led continuously blinking 5 times in both the laptop even after shutdown and when it is powered on the led keeps blinking 5 times .both the laptop is charging and working on both battery...
                12-28-2024, 04:46 AM
                HP ProBook ProBook Fortis 14 inch G9 Notebook PC Notebook Specification for Upgrade or Repair
                This specification for the HP ProBook ProBook Fortis 14 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ProBook Fortis 14 inch G9 Notebook PC boardview and ProBook Fortis 14 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
                09-07-2024, 05:50 AM
                HP ProBook Prenosni računalnik ProBook 445R G6 Notebook 400 Specification for Upgrade or Repair
                This specification for the HP ProBook Prenosni računalnik ProBook 445R G6 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Prenosni računalnik ProBook 445R G6 boardview and Prenosni računalnik ProBook 445R G6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
                09-06-2024, 10:51 AM
