Quadro K2100m smd caps
  • Thermaltake
    Brain badcap
    • Aug 2015
    • 335
    • D12
    Hi, I borrow K2100m graphics card to my friend for some testing. And he accidentlly unsolder 2 or 3 smd caps from the gpu chip while he was cleaning thermal paste on chip, and lost them somewhere.
    My question is can someone tell me what size and strength are those smd caps. I also attach photo so you can see better what I'm talking about I circle them with red.
    Thanks.
  • Thermaltake
    Brain badcap
    • Aug 2015
    • 335
    • D12
    Re: Quadro K2100m smd caps
    anyone ?
    • caspian
      • Oct 2015
      • 1591
      • Laptop
      those caps can only be taken from a defective chip of the same model.
      • Thermaltake
        Brain badcap
        • Aug 2015
        • 335
        • D12
        Ah, thats not a good news
        • caspian
          • Oct 2015
          • 1591
          • Laptop
          probably, many such defective chips can be found in the market with a very cheap price.
            master hoarder
            • May 2008
            • 12175
            • Bulgaria
            Those are SMD multi-layer ceramic caps (MLCC). But just call them ceramic caps for simplicity.
            Anyways, as far as specs... I would >guesstimate< they are rated for around or under 1 uF (probably 100-470 nF... or 0.1 to 0.47 uF if you prefer that) and likely 6.3V or thereabouts.
            You should be able to run the GPU without these, though. Worst case, you'll just get garbled image with artifacts or unstable GPU. If that's the case, try some 220-680 nF SMD ceramic caps and see if that works.
            Now, since those caps were damaged, I think it's much more important to inspect the trances on the GPU on top. If any are severely scratched off or cut, don't even bother looking for replacement ceramic caps, as the GPU may be damaged beyond repair from those scratches.
            • rediii
              h???, spurrrn
              • Mar 2018
              • 499
              • somewhere in europe
              thats right!
              • Thermaltake
                Brain badcap
                • Aug 2015
                • 335
                • D12
                I gave graphics card to my friend he soldered the right caps.
                I will test card when I arrive home after work, and let you know if it's working.
                • Thermaltake
                  Brain badcap
                  • Aug 2015
                  • 335
                  • D12
                  Doing test for 1 hour now and everything seems to be OK.
                  Graphics card is working again, woohoho
                    master hoarder
                    • May 2008
                    • 12175
                    • Bulgaria
                    Nice!
                    Glad to hear it's working again!
                      by momaka
                      03-12-2025, 03:42 PM
                    • eryjus
                      by eryjus
                      05-10-2023, 11:21 AM
                    • Paxman_Swede
                      by Paxman_Swede
                      Hello!
                      01-14-2025, 09:51 AM
                      HP Z440 + Quadro K620 2GB i7-6700 Specification for Upgrade or Repair
                      This specification for the HP Z440 + Quadro K620 2GB can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Z440 + Quadro K620 2GB boardview and Z440 + Quadro K620 2GB schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                      09-12-2024, 03:30 PM
                    • captain150
                      by captain150
                      03-16-2025, 07:34 PM
