Dell E5440 completely dead, no LED.
  • Andreasbest
    • Aug 2014
    • 1153
    • Hellas ( Greece )
    Hello!
    I have a E5440 (second hand) that doesn't power on, it's not shortcircuited as the charger's led remains on when i plug it but i have low voltage.
    Here are some measurements i took before and it's as far i can go with my knowledge so any help will be great.
    PL301 17v in both pins instead of 19v
    PU301 0v in pin5
    Thank you in advance!
  • piernov
    • Jan 2016
    • 4435
    • France
    Re: Dell E5440 completely dead, no LED.
    PL301 pin 2 is connected directly to PU301 pin 5 so those measurements are probably wrong.
    First thing is to tell the history of the machine, if it's liquid damaged, give all the symptoms, visual inspection, etc…
    • Andreasbest
      • Aug 2014
      • 1153
      • Hellas ( Greece )
      Yes this is what i thought too but i really don't found connection betwen them even with the ohmeter.
      I count 5 pins from the dot counter clockwise.
      No liquid damage, motherboard looks like new, no LED at all, no battery charging, not any other symptoms of life.
      • piernov
        • Jan 2016
        • 4435
        • France
        Did you try another Dell AC Adapter (with correct power rating)?
        If yes, you can start measuring voltage on inputs/outputs of the 3V/5V regulator PU51.
        Pin 3 VREG3
        Pin 6 EN2
        Pin 8 SW2
        Pin 12 VIN
        Pin 13 VREG5
        Pin 18 SW1
        Pin 20 EN1
        • Andreasbest
          • Aug 2014
          • 1153
          • Hellas ( Greece )
          pin 3 0v
          pin 6 0v
          pin 8 0,24v
          pin 12 17,24v
          pin 13 0v
          pin 18 0,03v
          pin 20 0v
          What do you think?
          • piernov
            • Jan 2016
            • 4435
            • France
            PU51 does get 17V on its power input pin VIN but never creates the LDO outputs VREG3 and VREG5.
            Chip is TPS51225C according to schematics, for which VREG3 and VREG5 should always be enabled.
            Confirm that the chip on the board is indeed TPS51225C
            Measure resistance to ground on PU51 pins:
            Pin 3 VREG3
            Pin 8 SW2
            Pin 13 VREG5
            Pin 18 SW1
            • Andreasbest
              • Aug 2014
              • 1153
              • Hellas ( Greece )
              Yes it's indeed TPS51225C (1225C is written on it)
              Pin 13 is grounded.
              • piernov
                • Jan 2016
                • 4435
                • France
                What's the exact resistance to ground?
                If you have a short to ground there you'll have to find it. You need to inject 1V on this pin with a lab PSU and check what the current consumption is, then search for the component that's heating up.
                • Andreasbest
                  • Aug 2014
                  • 1153
                  • Hellas ( Greece )
                  0,5Ω is the resistance to ground.
                  So it's not the PU51 that is faulty but another component that i must found using vontage injection?
                  • piernov
                    • Jan 2016
                    • 4435
                    • France
                    Just realized that apparently there's only PU51 and PC69 on the +5V_ALW2 line. Weird, but I guess it makes things easy.
                    Remove PC69 first, then if the short to ground is still there remove PU51, and confirm the short to ground is gone.
                    • Andreasbest
                      • Aug 2014
                      • 1153
                      • Hellas ( Greece )
                      • Andreasbest
                        • Aug 2014
                        • 1153
                        • Hellas ( Greece )
                        Ok found it, was right after the pin 13, i removed it, the pc69 is not shortcircuited but the pin 13 remains shortcircuited to ground.
                        So the PU51 is faulty or i need to remove it and check for shortcircuit again?
                        • mcplslg123
                          • Jun 2015
                          • 7262
                          • india
                          Yes, should remove PU51 and check resistance on pin13 again.
                          • Andreasbest
                            • Aug 2014
                            • 1153
                            • Hellas ( Greece )
                            @ piernov & @mcplslg123
                            Just removed the PU51 and the shortcircuit is gone.
                            So it's PU51 broken?
                            (sorry for the delay was on vacation for New year eve)
                            • mcplslg123
                              • Jun 2015
                              • 7262
                              • india
                              Yes, seems like that. Replace the chip and dont put power to mb without this chip.
                              • max-power
                                Dell E6540 laptop completely dead after dssasembly
                                by max-power
                                Hi, I disassemble my laptop to replace the speakers, to access them, you have to remove everything including the heat sink and fan, unscrew the motherboard, lift it up a bit to access the speaker wire.
                                that was not the first time I dissasemble it, i did replace the same speaker a few year ago and I repaste it last year, so I had nothing to worry about. but when I put everything back together, its completely dead.
                                After a bit of investigating, i found one pin of the status led ribbon cable that was unglued from the cable and bend touching another pin, I bend it back at his place...
                                03-24-2025, 08:49 AM
                              • Andreasbest
                                by Andreasbest
                                Hello!
                                I got a Dell E5440 that is completely dead, charger doesn't detect any shortcircuit so remains lit when i plug it on laptop.
                                No signs of life at all, i only detect some heat on PQ4.
                                Plus PQ4 has 19v on pins 1,2,3 & 4 and only 1.8v on the other.
                                I replaced it but no luck, same behavior.
                                Any help appreciated, thank you in advance!!!
                                Schematics and Boardview attached...
                                10-11-2021, 10:02 AM
                              • diamon
                                Dell Latitude 5520 completely dead
                                by diamon
                                I have bought a not complete and defective Dell Latitude 5520 for parts (needed the networkconnector (RJ45) to repair a other board).
                                Have repaired the other board (Dell Latitude 5540) and I wanted to know if I could find out what is wrong with the 5520 board (SouthPeak15 TGL MB 8L 19819-1) and perhaps repair this one also.
                                After connecting the USB-C charger (both USB-C ports on the laptop, does not have an other option) and pressing the power button, nothing happens (no lights or fans, no capslock).
                                Have checked with a thermal camera, and there are a couple of things...
                                03-05-2025, 02:23 PM
                              • Bowline
                                by Bowline
                                06-11-2025, 10:13 AM
                              • Francesc V.
                                Dell dockstation WD15 is dead
                                by Francesc V.
                                Hi:
                                A friend gave me this DELL WD15 dockstation that does nothing. Not detected by computer, no digital output.........just leds shines when it’s plugged in.
                                Here are the findings, followed by good pictures. :-)
                                When pluged in, LED3 glows
                                Measuring some voltage in the circuit.
                                Inductors
                                - PL202 has 5V
                                - PL201 has 3.3V
                                - PL300 has 1V
                                V. Regulators
                                - UT30 has 19v as input and 6V as output. It seems ok.
                                - UT27 (same reference as UT30, has no input/output voltage).
                                Thermal find...
                                07-09-2025, 12:12 AM
