Lenovo IdeaPad 100 board is dead
  • coolerman
    • Aug 2014
    • 21
    • Ελλάδα
    hello guys!
    received this motherboard model nm-a681 for change the jack dc port(change it all ok)after push side power button and is dead(no reaction/no spin fan) nothing is dead
    with multimeter read to pq301 and pq302 have 20v both
    can help me anyone;;?
  • Techtiger
    • Oct 2014
    • 1602
    • france
    Re: Lenovo IdeaPad 100 board is dead
    check the voltage of the first 2 Fets PQ301 PQ302 GATE SOURCE DRAIN after check the voltage of the CLR PR301 both side if you dont get +19V at the PR301 that means you 2 Fets Gate voltage is missing or one of the Fets short
    • Techtiger
      • Oct 2014
      • 1602
      • france
      here is the Schematic check out the page 53
      • coolerman
        • Aug 2014
        • 21
        • Ελλάδα
        check with my polymeter(pq301 and pq 302) and to pr 301 has 20v(is correct voltage i think) both side.
        • Techtiger
          • Oct 2014
          • 1602
          • france
          ok that's good let’s move no find out PJ303 PJ306 this are jumpers and there out put , PU200 is your 3V Regulater IC you need to find out out put voltage of pin 17 , Pu201 is your 5V Regulater IC find out out put voltage of pin 15, UE1 is the SUPER IO CHIP SIO page 44 find out the voltage on pin 71 128 110
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            Check PQ303 located near battery connector. Often, this mb goes dead 'coz of shorted pq303. have found so on 3 occasions.
            • coolerman
              • Aug 2014
              • 21
              • Ελλάδα
              pj303(0v) pj 306(0v)pu200 pin 17(don't have 3v)PU 201 pin 15(have it 5v) pin 128(super i/o 0v)pin 71(super i/o 0v)pin 110 (super i/o 0v)
              check again but don't have mistake for my measurement.
              • coolerman
                • Aug 2014
                • 21
                • Ελλάδα
                Check with polymeter and pq 303(pv507ba) has on side 20v the other side of pin is 0v
                • Techtiger
                  • Oct 2014
                  • 1602
                  • france
                  No supply 0V means +19V is absent in +B change that Fet
                  • coolerman
                    • Aug 2014
                    • 21
                    • Ελλάδα
                    can tell me what is location(and change it this fet)for repair;
                    (sorry but i don't know very good english and i use it translate)
                    • Techtiger
                      • Oct 2014
                      • 1602
                      • france
                      You have to find out a P channel 6 legs forward base mosfet 30V from a spair motherboard
                      • coolerman
                        • Aug 2014
                        • 21
                        • Ελλάδα
                        Ok
                        Hope solve my problem this fet.
                        Change it and see what happens.
                        • mcplslg123
                          • Jun 2015
                          • 7262
                          • india
                          I beleive that's fine. The otherside you are talking about is connected to battery and since battery is disconnected, you are not supposed to get any voltage there.
                          • Techtiger
                            • Oct 2014
                            • 1602
                            • france
                            yep that's correct I miss that it's +B between PR301 PL302 goes to 3/5 Regulator IC
                            • coolerman
                              • Aug 2014
                              • 21
                              • Ελλάδα
                              It's normal this fet (pq303;?)don't replace them.
                              Can check other place and find this problem caused;?
                              • Techtiger
                                • Oct 2014
                                • 1602
                                • france
                                You have to check PJ303 PJ305 getting +B 19V for those 2 jumpers
                                • coolerman
                                  • Aug 2014
                                  • 21
                                  • Ελλάδα
                                  • coolerman
                                    • Aug 2014
                                    • 21
                                    • Ελλάδα
                                    hi gays again
                                    check PJ303(don't have 20v) but to PJ305(have it 20v)
                                    • mcplslg123
                                      • Jun 2015
                                      • 7262
                                      • india
                                      PJ303 SHOULD BE 3V and not 20v. Similarly PJ306 should be 5V but i beleive these voltages will appear only after power on. If there is no shorting on those pads, problem may be elsewhere.
                                      • coolerman
                                        • Aug 2014
                                        • 21
                                        • Ελλάδα
                                        pj 305 have it 5v, pj 303 don't have 3v the pu200(same area) coming 20v but is out pin 16 don't have 3v
                                        and this litl capacitor i thing is short(biping mode)
                                          Lenovo IdeaPad IdeaPad Gaming 3 15IHU6 Ultrabook 3 Specification for Upgrade or Repair
                                          This specification for the Lenovo IdeaPad IdeaPad Gaming 3 15IHU6 Ultrabook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad Gaming 3 15IHU6 boardview and IdeaPad Gaming 3 15IHU6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                                          09-07-2024, 05:20 AM
                                          Lenovo IdeaPad IdeaPad 3 15IML05 Notebook 3 Specification for Upgrade or Repair
                                          This specification for the Lenovo IdeaPad IdeaPad 3 15IML05 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 3 15IML05 boardview and IdeaPad 3 15IML05 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-07-2024, 05:00 AM
                                          Lenovo IdeaPad IdeaPad Gaming 3 15ACH6 Notebook 3 Specification for Upgrade or Repair
                                          This specification for the Lenovo IdeaPad IdeaPad Gaming 3 15ACH6 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad Gaming 3 15ACH6 boardview and IdeaPad Gaming 3 15ACH6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          Lenovo IdeaPad IdeaPad 5 14ITL05 Notebook 5 Specification for Upgrade or Repair
                                          This specification for the Lenovo IdeaPad IdeaPad 5 14ITL05 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 5 14ITL05 boardview and IdeaPad 5 14ITL05 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-07-2024, 04:10 AM
                                          Lenovo IdeaPad IdeaPad 5 15ITL05 Notebook 5 Specification for Upgrade or Repair
                                          This specification for the Lenovo IdeaPad IdeaPad 5 15ITL05 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 5 15ITL05 boardview and IdeaPad 5 15ITL05 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
