Macbook retina Ic rework
  • Eleways
    • Oct 2014
    • 62
    • Italy
    Hi
    We start to repair Macbook pro retina. We have a problem about the CPU/GPU. This product use a SR16T, a CPU and GPU together.
    This component is narrow and long, when we try to rework, the component rises to the ends, to the middle it remains well aligned to the card. The result is a bed rework.
    we use an infrared rework machine, an Achi 6500.
    Any suggestion to rework this component correctly? We try to play with the distance of the head, or by the bottom temperature, without success.
    Thanks for you help
    Luca
  • khaahk
    • Dec 2013
    • 813
    • Estonia
    Re: Macbook retina Ic rework
    The cpu should straighten when reflow temperature is achieved. If mainboard is warping - it is usually due to uneven temperature across the board. Any pictures of the setup? How board is placed etc.
    • Eleways
      • Oct 2014
      • 62
      • Italy
      The board does not flex. The CPU bends to the sides, upwards.
      • khaahk
        • Dec 2013
        • 813
        • Estonia
        Sorry, have never seen this. The cpu is curved the opposite way when cold and not installed on mainboard. It will straighten when temperature goes up. If using lead-free balls then try to reball with leaded balls to lower installation temperature.
        • Eleways
          • Oct 2014
          • 62
          • Italy
          Hi Thanks for the reply.
          The problem we have is the opposite. The CPU is straight, when it is heated it bends to the sides and the bubbles detach from the motherboard. in the center it remains well positioned. When it cools it tends to go back into position, but not completely.
          Thanks Luca
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            Never faced that though i use a hot air bga machine. Seems like bad profile setup.
            • dellxps15
              • Feb 2014
              • 1598
              • italy
              a picture of the problem would help us find what is wrong.
              • Eleways
                • Oct 2014
                • 62
                • Italy
                I don't know how to post a picture. i try but open a window with an http link.
