hp cq58 It work for only one second and then reboots again and work for one second too, and stays that way . not find any volt except 19 volt and 5 & 3.3 volt on power coils and EC chip bios 3.3 volt . no volt on main bios !! I programmed EC + Main bios . what can I do in this problem ?
					hp cq58 no power
 Re: hp cq58 no power
 5V ALW & 3V ALW will appear after switching on this mb. Are you getting that?? 3V on main bios will also appear after switching-so thats not the problem. Are you able to switch it on?? If no, then check basic requirement of KBC IT8518 like LID_SW,3v EC power, RSMRST, DNBswon,EC_rst etc..
			by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
			by iulik17dHello everyone!
 The Asrock A380 low profile card (ID 8086 56A5 - 1849 6006) have an power limit of 45W. Intel removed the possibility to increase power using the software utility, anyway the card is in an proxmox machine that doesn't run windows.
 The same hardware is in another form by the name Asrock A380 Challenger that have the same VRMs and the power limit is at 60W. I searched online and found on another website an .bin bios file from the Challenger variant, that I flashed using an CH341a. Flashng worked well, I put the card in PC and booted. GPUz shows that new device ID is 8086...-
			by Dani_2024Hi and thanks in advance for any input you might provide!
 Last Sunday I was watching a dvd and fell asleep for about half hour, when I awoke the tv screen was black and couldn't get the dvd menu to show, so I changed the input to antenna and had sound but no picture, turned it off. I then got online and found this great site! ....read many troubleshooting tips and this...5 Photos
			by PantherDaveHi all!
			by mkdjDear all,
 I have taken out the motherboard of a Acer TravelMate P214. There is a short to ground on the main power rail (19V). I don't have the schematics or boardview for this board (DAZ8IMB1AA0 REVA). But I have found 4 MOSFETS close to the main power rail : 2 N-Channel and 2 P-Channel.
 I have checked resistance across each of the 4 MOSFETS. I have the following readings:
 Both N-Channel Mosfets: nothing odd
 P-Channel MOSFET number 1:
 source - drain : 117 kOhm
 source - gate: 96 Ohm
 gate - drain: 117 kOhm
 P-Channel MOSFET...
- Loading...
