acer aspire V3 771G VA70
  • zhang
    • Jun 2017
    • 50
    • Indonesia
    Re: acer aspire V3 771G VA70
    Please check pin 48 for sio chip
    me_ac_present
    and resolder sp2219 if it is available to be soldered
    • poweron
      • May 2019
      • 371
      • italy
      me_ac_present
      thank you very much ... only that now it happened to me to make a short with the tip of the tester between pin 11 and 12 of U8100a that it burns a lot, I have to restore the situation, surely I have to replace the qfn then you update, thanks
      • poweron
        • May 2019
        • 371
        • italy
        what can I put in place of the TPS51225 (U8100A)?
          • 21922
          TPS51225C = APW8822C
          https://www.badcaps.net/forum/showthread.php?p=829615
          • poweron
            • May 2019
            • 371
            • italy
            thank you, since I have several main laptops, is there a way to know on which projects a certain integrated is mounted?
            • poweron
              • May 2019
              • 371
              • italy
              #26
              [QUOTE=poweron;904006]these are the voltages on U8800 BQ24725:
              voltage value column: first adapter only - second adapter + battery - third battery only
              pin 1 = 19v 18,8v 11,3v
              pin 2 = 19v 18,8v 11,3v
              pin 3 = 19v 19,3v 0,38v
              pin 4 = 25v 19,3v 0,38v
              pin 5 = 3.2v 3,2v 0v
              pin 6 = 2.6v 2,6v 0v
              pin 7 = 0v 0v 0v
              pin 8 = 3.2v 3,2v 3,2v
              pin 9 = 3.2v 3,2v 3,2v
              pin 10 = 3.0v 3,1v 3,1v
              pin 11 = 3.2v 11,2v 17,3v
              pin 12 = 3.2v 11,3v 11,3v
              pin 13 = 3.2v 11,3v 11,3v
              pin 14 = gnd gnd gnd
              pin 15 = 0v 0v 0v
              pin 16 = 5.9v 6v 0v
              pin 17 = 5.9v 11v 11v
              pin 18 = 3.2v 11,3v 11,3v
              pin 19 = 3.2v 11,3v 11,3v
              pin 20 = 19v 19v 11,2v
              after replacing the U8100 it also turns on with only the adapter and with only the battery, if after inserting the battery the adapter is connected this goes in protection, if instead I insert the battery after connecting the adapter this does not go into protection but does not charge the battery even if the amber LED is on, if at this stage you press on button it turns on but it is the battery that powers it, the problem can be U8800?
              • zhang
                • Jun 2017
                • 50
                • Indonesia
                #27
                how much is the power consumption on bench power supply
                without turning on
                adapter + battery
                and compare it with adapter only
                ( without turning on )
                • mcplslg123
                  • Jun 2015
                  • 7262
                  • india
                  #28
                  check discharge fet, it might be shorted. Your adapter is going in protection mode when battery is connected means battery voltage is reaching on ac voltage points.
                  • poweron
                    • May 2019
                    • 371
                    • italy
                    #29
                    the problem is caused by Q8800 which is shorted between S and D, after its replacement everything works properly, even the battery is charged regularly, I thank everyone for the precious collaboration
                    • frica
                      • Nov 2017
                      • 37
                      • Spain
                      #30
                      +1
                      • frica
                        • Nov 2017
                        • 37
                        • Spain
                        #31
                        Exellent reparation!! I am newbie in electronic repair and I enjoey much when I read a success reparation. But I am a question:
                        The voltage in shorted transistor Q8800 was measured in the message #7. The owner of the laptop measured 19v in Source and in Drain. The short was not discovered in view of these measures. why? Are these values not enough to reveal the shorted situation??.
                        But in a shorted MOSFET what is the typical values of voltage for Drain, Source and Gate?? In this laptop the Gate voltage for Q800 would be also 19 volts?? It is an indicative of short that the voltage in the 3 pins have the same values??
                        Thanks!
                          ACER Aspire Aspire E560 Aspire E6400 Specification for Upgrade or Repair
                          This specification for the ACER Aspire Aspire E560 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire E560 boardview and Aspire Aspire E560 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                          09-12-2024, 03:28 PM
                          ACER Aspire Aspire E700 Aspire E6300 Specification for Upgrade or Repair
                          This specification for the ACER Aspire Aspire E700 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire E700 boardview and Aspire Aspire E700 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                          09-12-2024, 02:30 PM
                          ACER Aspire Aspire M7711 Aspire Q9300 Specification for Upgrade or Repair
                          This specification for the ACER Aspire Aspire M7711 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire M7711 boardview and Aspire Aspire M7711 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                          ACER Aspire Aspire G7200 Predator Defender Aspire 9750 Specification for Upgrade or Repair
                          This specification for the ACER Aspire Aspire G7200 Predator Defender can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire G7200 Predator Defender boardview and Aspire Aspire G7200 Predator Defender schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                          ACER Aspire Aspire M7200 Aspire 805 Specification for Upgrade or Repair
                          This specification for the ACER Aspire Aspire M7200 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire M7200 boardview and Aspire Aspire M7200 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
