Aspire E1-572g / mainboard V5WE2 LA-9531P
  • vannix
    • Mar 2018
    • 74
    • Italy
    Hi, i'm having some problems in troubleshooting this motherboard.
    After a drop (while it was powered-on) the notebook turns on only for 2-3 seconds and then turns off. There is no display.
    Battery charging seems ok, and i get + 3VALW and + 5VALW, but no +3VS and +5VS.
    I noticed that SUSP# is always LOW (but not shorted to gnd), so the U11 (page 38 on schematic) does not power +3VS and +5VS.
    anyone know this problem and/or can help me?
    thank you in advance!
    mainboard: V5WE2 LA-9531P Rev: 1A
    schematic pdf here: https://www.badcaps.net/forum/troubl...atic-boardview
  • Techtiger
    • Oct 2014
    • 1602
    • france
    Re: Aspire E1-572g / mainboard V5WE2 LA-9531P
    Check PU401 pin5/2 , PU402 pin7/2 U11 pin 1234567 , U28 pin 9 67 2 37 6 14 65 95 127 110 112 115 116 100 101 Voltage
    • vannix
      • Mar 2018
      • 74
      • Italy
      hi, thanks for your reply, here are the voltages you request:
      pu401
      pin 2 -> 3.3
      pin 5 -> 3.3
      pu401
      pin 2 -> 3.3
      pin 7 -> 19
      u11
      1->3.3
      2->0
      3->0
      4->5
      5->0
      6->5
      7->5
      u28
      9-> 3.3
      67-> 3.3
      2-> 0
      37-> 2.9
      6-> 0
      14-> 0
      65-> 0
      95-> 0
      127-> 0
      110-> 2.8<->3.3
      112-> 3.3
      115-> 3.3
      116-> 0
      100-> 0
      101-> 0
      • Techtiger
        • Oct 2014
        • 1602
        • france
        pu401
        pin 2 -> 3.3
        pin 5 -> 3.3
        pu401
        pin 2 -> 3.3
        pin 7 -> 19
        PU401 Pin 7 LDO +19V is too high it must be +5V test again ! for the moment leave the U11! RSMRST# 0V The Mob will never power ON check the BIOS chip pin 8 Voltage
        • vannix
          • Mar 2018
          • 74
          • Italy
          you are right, i measure pin 8 (b+)
          pin 7 is 4.45v
          • vannix
            • Mar 2018
            • 74
            • Italy
            the spi flash is not powered, pin 8 is 0v, it depends from +3VS
            without +3vs i can get 3v3 only on the power button and in the lid switch (both tested, and working).
            edit: which component controls the RSMRST# connected to EC_RSMRST#?
            • Techtiger
              • Oct 2014
              • 1602
              • france
              this MB continence 2 BIOS chips main +ec bios page U29 check all pins for Voltage , the 2end bios will powered on S3 or S4 stage, your Adapter is not commination with the SIO Chip U28 pin 65 0V trace it back !
              • Techtiger
                • Oct 2014
                • 1602
                • france
                in this Mob RSMRST signal is generated from Super I/O chip it tells the PCH to wake up signel all Voltages ok
                • vannix
                  • Mar 2018
                  • 74
                  • Italy
                  U29 is unpopulated, it use KB9012 with embedded ec flash, and u29 header is not powered.
                  u28-pin65 is ADP_I. also pu201 is unpopulated
                  i'll check pu301
                  • erbuzzicker
                    • Apr 2018
                    • 42
                    • Italy
                    Hello,I have your same issue. Did you solve it?
                    • vannix
                      • Mar 2018
                      • 74
                      • Italy
                      Hi, no. Still unsolved.
                      A customer brought me another computer with the same motherboard and same problem after his cat broke the keyboard with his fingernails.
                      I think the problem may be the ec (broken or to be reprogrammed, but I don't have the programmer). i'm waiting for another working board for tring to swap the ec.
                      P.S. this guy has solved with bios reflash: https://www.badcaps.net/forum/showth...ighlight=9531p i don't solve with this solution, but you can try...
                        ACER Aspire Aspire X3910 Aspire E5700 Specification for Upgrade or Repair
                        This specification for the ACER Aspire Aspire X3910 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire X3910 boardview and Aspire Aspire X3910 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                        09-12-2024, 03:36 PM
                        ACER Aspire Aspire XC-886 Aspire XC i5-9400 Specification for Upgrade or Repair
                        This specification for the ACER Aspire Aspire XC-886 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire XC-886 boardview and Aspire Aspire XC-886 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                        09-12-2024, 03:30 PM
                        ACER Aspire Aspire XC-330 Aspire XC A4-9120e Specification for Upgrade or Repair
                        This specification for the ACER Aspire Aspire XC-330 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire XC-330 boardview and Aspire Aspire XC-330 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                        ACER Aspire Aspire TC-780 Aspire i5-7400 Specification for Upgrade or Repair
                        This specification for the ACER Aspire Aspire TC-780 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire TC-780 boardview and Aspire Aspire TC-780 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                        09-12-2024, 03:28 PM
                        ACER Aspire Aspire TC-885 Aspire TC i7-8700 Specification for Upgrade or Repair
                        This specification for the ACER Aspire Aspire TC-885 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire TC-885 boardview and Aspire Aspire TC-885 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
