s55t-b
  • ghass
    • Apr 2014
    • 45
    • lebanon
    s55t-b
    toshiba s55t-b when change bios setup from uefi to csm the screen change to black screen and when reprogramm the bios its work but i cant use csm legacy
  • GuiTi
    Need Custom BIOS (UEFI/Dualboot) for Lenovo Chromebook 100e Gen 3
    by GuiTi
    Hey everyone!
    I need help with my Lenovo Chromebook 100e Gen 3.
    Here are the details:
    • Motherboard: LA-L131P
    • MFG Date: 2022/01/07
    • MTM: 82J80001BR
    • MO: MPNXB2103001
    • Factory ID: LI123
    I bought a new Winbond 25Q128FVSG chip.
    The chip currently on the board is the same model but with different ending letters.
    I can’t use the CH341 clip on the chip that’s on the board because it’s too low-profile and doesn’t make proper contact.
    The Chromebook is Google account locked, and I’ve already tried everything.
    I understand that I need to replace or...
    10-14-2025, 08:41 AM
  • mitchw
    HP 14s-fq1010nm Black screen after BIOS update - cannot downgrade
    by mitchw
    Just had a customer bring in a HP 14s-fq1010nm to do some maintenance.
    After updating the BIOS to the latest (F.35) I get black screen (no backlight turning on). However the backlight turns on if I connect an external display to HDMI, but when booting to Windows, both displays remain black.
    After disconnecting internal LCD, and plugging in external display via HDMI, it works on external.
    I tried downgrading it using official method - using an USB drive with older BIOS version, but it fails, saying that the BIOS files are corrupted. I used about 5 different older BIOS versions...
    04-29-2025, 03:45 PM
  • BlueNitesFire
    I need Lenovo yoga 6 13ARE05 bios- broken screen and no bright light on keyboard
    by BlueNitesFire
    So I couldn't remember my bios password and since it was broken screen, I used to connected to the TV via Type C to HDMI. So I decided to remove the Bios chip and reprogram the Bios chip with ch314a.. when I try to solder Bios on the laptop, one of the Bios leg broke off.. I bought a new blank Bios chip so I can programmed by flashing on the bios.
    03-08-2025, 03:49 PM
  • Technodoc
    ASUS G614JZ G634J-PMV-VGT Rog Strix need some bios help, laptop black screen
    by Technodoc
    Asus laptop G614JZ-N3012W Rog Strix with i7
    Mainboard G634J-PMV-VGT
    6050A3441302-MB-A01
    2023-02-10
    Power button works okay....power light goes on
    Red "bottom" leds go on
    Charging led works
    Fans do not spin, capslock key does nothing, screen stays black
    I would like to program the bios again, to rule out a corrupted bios.
    However I run into a size error
    The bios chip is a Winbond 25R256JVEN
    Used my Xgecu T-48 to read the bioschip (using select chip as type XM25QH256B @WSON8, read somewhere...
    02-24-2025, 04:46 AM
  • iZakre
    HP Pavilion 15 bc400ns - Complete Black Screen - Only video on live usb
    by iZakre
    Hello everybody!
    To put you in context I recently replaced the battery from my HP Pavilion 15 bc400ns with a used one, everything was going good. The same day, I decided to update the BIOS, everything went good. The thing occurred after I let the battery drain iddling on Windows 11 for the second time to calibrate it that the screen did not turn on again, the computer was on but the screen did not turn, like it would not wake from hibernation. I decided to restart the computer but got no video.
    The thing is that I had installed TeamViewer and could log into the computer...
    02-19-2023, 02:27 PM
